Meshify S2 Hard tube build
Discussion in 'PC Build Logs' started by Brett240, Jan 11, 2020.
  1. Brett240
    Brett240 Member
    May 11, 2017
    69
    Hi all,
    building my 3rd PC and second water cooled build. at the moment not all specs are decided on though im leaning towards X570 and a 3900X. for now i'll harvest some old parts from my current build, to keep dollars leftover as this build is going to add up
    Specs:
    Case: Fractal Design Meshify S2
    Mobo:
    CPU:
    Mem: 16GB of Giagbyte Aorus 3200 CL16
    PSU: Corsair SF750
    Graphics card: Asus RTX 2080 Turbo
    Storage: 1 x Samsung NVME 500gb 970 evo / 1 x Samsung NVME 970 evo plus 1TB / 1 x 6TB WD blue
    Case Fans: 4 x Fractal prisma 140mm
    Rad fans:
    Radiators: EK 360 slim up top for CPU / EK 280 CE on the bottom for GPU
    Reservoir: Singularity Resonance dual
    Brett240
    Brett240 Member
    May 11, 2017
    69
    Fractal prisma fans, radiators and Resonance in. the resonance will be difficult to hard tube, but thats part of the fun
    clrobbo and Agg like this.
    Brett240
    Brett240 Member
    May 11, 2017
    69
    space between the PSU and bottom rad is a little tight, the cables will probably nudge up against it on their way out. will keep thinking about this. worst case i can drop to a 240 rad.
  4. clrobbo
    clrobbo Member
    Jun 3, 2002
    173
    Wow Brett...……...that res and pump combo takes your main radiator mount away, i.e. the front one !
    Brett240
    Brett240 Member
    May 11, 2017
    69
    It's that way on purpose, I prefer the look without a front rad.
    Top and bottom rads are now in
    clrobbo likes this.
