[PROJECT] mini hexacopter build and test flight
Discussion in 'Other Toys/Hobbies' started by ShadowBurger, Dec 29, 2016.
  1. ShadowBurger
    ShadowBurger Member
    Feb 19, 2008
    1,975
    UPDATE:
    Re-designed the frame from the ground up:
    I had good fun building my heavy-lift hexacopter, but I felt like the questionable rule of ‘more is better’ needed to be applied to the mini racing multirotors as well. Even if that isn't strictly-speaking true, it had to be a lot of fun. :weirdo: So I queued the music and put together this design:
    The parts are:
    Orange – top plate
    Blue – unibody bottom plate
    Green – back (upright) plate (ignore the green bit with three holes…)
    Yellow – angled camera plate
    I sent it off to get cut, once again using the fantastic service from Paul at BezerkRC (bezerk.com.au). I also asked if he could pocket the bottom bolt holes while machining, to which he thankfully obliged:
    For this project, I needed a solution to where I was going to put 6x ESCs. A 4in1 plus two stand-alones was one option, but when looking for motors I saw these popup for sale, for $9.90AUD each. A steal! They are MultiStar 2205-2350KV with built-in 30A ESCs. They’re about $40 each normally, I got all six for ~$60! They seem to have reasonably good build quality, although they got warmish during testing. Only a proper hard flight will tell if they are good kit. I also picked up some extra pairs of prop adapters which ShoddyKing thankfully sell separately, as the motors were all clock-wise.
    I started by fitting the basic hardware to the frame. Easy!
    The recessed bolt heads – this is why I got the pocketing done.
    As you can see, the battery is held against a smooth surface instead of damaging bolt heads.
    The motors fitted to the frame. Glad not to be messing around with ESC wiring!
    I’m using a PDB which just has two long pads, so it’s easy to fit all six pairs of wires onto it. It also has a built in low-battery/lost model buzzer and BEC. Nifty!
    Once again I’ve re-used a Naze32 Rev6 flight controller. They do the job fine and the features on the PDB mean I’m not missing out on anything (I prefer not to use an OSD).
    Assembled ready for its maiden flight. There’s no camera or VTX fitted at this stage, and the X8R on top is in a temporary location.
    After a bit of a wiring cleanup and the addition of the FPV camera:
    The test flight! Success!
    I'll post back with an actual flight vid once the weather clears up and I've fitted the FPV gear.
    Some info about the build:
    Frame - custom!
    Motors - MultiStar 2205-2350kv with built-in 30A ESC
    Props - 4045 tri-blade
    PDB - multirotorshop.com.au
    Flight controller - naze32 rev6
    R/C receiver - FrSky X8R
    VTX - Foxeer Switcher
    Camera - Foxeer HS1177
  2. tasmik
    tasmik Member
    Oct 12, 2010
    213
    Whats it cost to get a frame made? Thou I'm leaning towards tbs discovery for next build or a 680 alien
    ShadowBurger
    ShadowBurger Member
    Feb 19, 2008
    1,975
    this cost me around the $100 mark. I wanted it to be tough, so I got it done out of 4mm carbon for the base which is pricey. if you're just building something for camera work (like the 2 frames you mentioned) you'd use thinner stuff, 2mm probably, which would give you room to play with a bigger frame. multiple identical items (like arms) reduces the overall cost also as they're easier to produce - my frame is a big uni-body so it wastes a lot of material :thumbdn: i basically paid for a huge square of 4mm carbon
  4. tasmik
    tasmik Member
    Oct 12, 2010
    213
    Yup next planned build is going to be for camera / video stuff.
  5. Agg
    Agg Lord of the Pings
    Jun 16, 2001
    32,170
    A Reported Post Near You
    I know some of the racing guys have gone to hex rather than quad because the smaller props give you more rapid response or something.. looks cool regardless. :)
  6. BluBoy
    BluBoy Member
    Jan 20, 2006
    1,899
    If you ever get bored with making these extreme custom builds, any chance you want to try a low price build us noobs can try at home? Just looking for good bang-for-buck parts that can be ordered online, to give us a taste of flying.
    Love your builds by the way :)
  7. eukaryote:)
    eukaryote:) Member
    Nov 10, 2007
    1,418
    That's cute
    ShadowBurger
    ShadowBurger Member
    Feb 19, 2008
    1,975
    Cheers guys! :D
    Thanks! I've done quite a few regular mini-quad builds but haven't really documented them as they're usually a dime a dozen on the interwebs. Since you've asked, I'll shoot some piccies during the build of the mini-quad I'm about to put together
    ShadowBurger
    ShadowBurger Member
    Feb 19, 2008
    1,975
    The mini-hex got a re-design from the ground up. It's been on my to-do list for a long time and I've only just gotten around to doing it since it costs me about $100 every time I get a frame prototyped. With my R/C Toolbox (the Mule) project and the ongoing development of my heavy-lift hexacopter on the go, it's been hard find the budget for all these toys! :Paranoid:
    I've been loving my new racing mini-quad so I based the new mini-hex design around it: The QuadRacer Kaiser. Big thanks to John from QuadRacer for sharing his designs with me. Basically the new design is just a bottom plate designed to accept the top half of the Kaiser, bringing the footprint for the stack way down and the ease of replacing parts way up; I already have a bunch of Kaiser frames on hand.
    The frame is 20g lighter by comparison, everything fits together great, and it looks tops to boot. Will report back with some vids / pics once it's built! :weirdo:
