Mini-ITX Build
Discussion in 'Portable & Small Form Factor' started by trash, Mar 28, 2011.
Tags:
  1. trash
    trash Member
    Feb 6, 2005
    306
    Darling Downs QLD
    I am entering into the realm of doing a proper mini-itx gaming machine.
    I have the following parts:
    Lian Li PC-Q08 (from holdenfanatic)
    Intel i5-750 (from KurRuPtViSioNs)
    Gigabyte H55N-USB3 (from KurRuPtViSioNs)
    Corsair 2x4GB DDR3-1600 (PCCG)
    Corsair H50 (from cavanor)
    Samsung 1tb x 2
    OCZ Vertex II 60gb
    Sony DVD-R/W
    Sapphire 6870
    Corsair HX-650
    Some of the parts are left over from my previous gaming machine. I tried to get as much as I could off OCAU members, but I couldn't get hold of any RAM from members!!
    Photos:
    Case
    There is a mess of USB-3 cables. There are pass through cables from the front USB ports which can connect to the mobo rear USB ports or connect to the USB female to mobo header cable.
    At the moment all I have done is pull the case apart. I will update with further pictures and any trials and tribulations that I come across.
  2. sloder
    sloder Member
    Apr 1, 2006
    119
    cool, looks almost the same as mine except i have jammed an HD6870 in there.
    Will be interesting to see how the Corsair H50 is going to fit.
  3. magicalsteve
    magicalsteve Member
    Dec 13, 2006
    133
    OP says HD6970 but it's a 6870 :)
    trash
    trash Member
    Feb 6, 2005
    306
    Darling Downs QLD
    My mistake. It is a 6870 as in the photo. I wish it was a 6970!
    trash
    trash Member
    Feb 6, 2005
    306
    Darling Downs QLD
    Drives Mounted
    The case is a bit of a bugger to get the CD/DVD and a 2.5" drive mounted. In the end I just removed the whole mount from the case.
    SSD Mounted
    SSD and DVD mounted. There is not much room between the two drives.
    2 x 1tb Samsung drives mounted. There are rubber grommets on the cage and the thumb screws come with the case.
    SSD and DVD mounted inside the case. Nothing special here.
    To get this mount out of the case there are two screws on either side. Once they are removed the whole mount comes out.
    So after a day of interruptions from my 1 year old son, all I have managed to achieve is mount the drives. My plan was to get everything finished in a day! How things change.
    I am thinking of removing the front USB3 assembly from the case and replacing it with USB2. There are USB3 ports on the rear of the motherboard and as of yet I have nothing that is USB3.
  6. KurRuPtViSioNs
    KurRuPtViSioNs Member
    Dec 14, 2006
    99
    Looking good! Wish my case would fit my HX650..
    Put my new rig together on the weekend and found out that I forgot to send your I/O plate.. Will get that to you this weekend!
    trash
    trash Member
    Feb 6, 2005
    306
    Darling Downs QLD
    Minor Mods
    Today I removed the front clear 140mm fan from the case. The next thing to go was the 4 bright blue LED that are on the fan. My plan is to have the case on the desk and I didn't want the bright LEDs to take away from my monitor.
    The back plate for the H50 needs a slight mod to clear some ICs on the back. Chips are circled below.
    I took to the back plate with a very sharp craft knife and just shaved the plastic until it cleared the ICs. Not the best job or photo, but it does the trick.
    Now time to mount the back plate!!
    trash
    trash Member
    Feb 6, 2005
    306
    Darling Downs QLD
    Testing
    I have test mounted the H50 retention and the back plate clears the IC. It does not look like it is on straight, that is because it isn't!
    Secured the front to make sure that everything lines up correctly, which it does. Any ideas as to what speeds I can expect from that CPU?
  9. Reaper_1994
    Reaper_1994 Member
    Mar 24, 2010
    2,039
    Townsville, QLD
    looks great. subbed. i can't wait for the finished build :)
  10. millsy_c
    millsy_c Member
    Mar 31, 2007
    12,488
    Running identical core system specs (except 4gb ram) and it rips along very nicely, I think you'll be very pleased :)
