  1. Ravense
    Ravense Member
    May 27, 2014
    41
    Adelaide, Australia
    Speaking of custom cases...
    Mine arrived! Here's some photos of the case and build :D
    Overall really happy with it!!
    museumman, RnR, TomJ and 2 others like this.
  2. Ratzz
    Ratzz Member
    Mar 13, 2013
    10,413
    Cheltenham East 3192
    That is fucking awesome !! Did Gury get the whole case done for you?? I can see his logo all over it..
    It never even occurred to me to ask him, the obvious person, given his location and contacts. How much did the chassis cost? Is the brick inbuilt as well? I can see the power connector.
    Ravense likes this.
  3. Ravense
    Ravense Member
    May 27, 2014
    41
    Adelaide, Australia
    Yeah, he designed it to my spec for me. He did the case and internal PSU. I had no problem with his logo being on it considering the great work he did and how accomodating he was
    Didn’t notice your edit sorry :D
    Chassis cost me $130 USD for designing, manufacturing and everything
    PSU was his usual $170 USD for the complete solution but he designed this one specifically for the case. The brick is built into the chassis and uses it to dissipated heat, sits underneath the GPU. I was concerned about the GPU getting too hot however under full load it’s been sitting at mid 70s so no issue there at all.
  4. Tazor
    Tazor Member
    May 23, 2010
    2,629
    Research, 3095
    Well it's more because NAVi on SFF Lab forums makes a very specific tray part which is designed for SFX, ITX and 2 slot GPU's with all the required bits and bobs.
    There aren't any cases on the market with the same layout that cost less than the tray - Or I'd just buy that xD
  5. demiurge3141
    demiurge3141 Member
    Aug 19, 2005
    2,280
    Melbourne 3073
    Looks awesome. :thumbup::thumbup::thumbup::thumbup::thumbup:
    Ravense likes this.
  6. Multiplexer
    Multiplexer Member
    Feb 26, 2002
    2,127
    Home
  7. Tazor
    Tazor Member
    May 23, 2010
    2,629
    Research, 3095
    Nice iteration, second bottom 92mm fan is a nice addition too as I had to use cable ties lol
    I'm more interested in the Sliger SM series cases, holding out for the larger SM580 currently as it has some great hardware compatibility and is more or less the big daddy of sandwich design chassis :lol:
  8. adamsleath
    adamsleath Member
    Oct 17, 2006
    19,338
    Sunnybank Q 4109
    im growing to like this mini itx stuff. far less wastage of materials, but still a custom build option.
  9. Tazor
    Tazor Member
    May 23, 2010
    2,629
    Research, 3095
    You should jump onto the SFF forums and check out some of the custom projects and builds - there's so many amazing concepts and design ideas out there and so much you can achieve in a tiny space without really that much performance deficit.
    adamsleath likes this.
  10. adamsleath
    adamsleath Member
    Oct 17, 2006
    19,338
    Sunnybank Q 4109
    sff. what's/where's that?
    but yeh i want as small as possible for the next one. i dont really oc. just a tad.
    millen likes this.
  11. millen
    millen Member
    Dec 16, 2013
    268
  12. Tazor
    Tazor Member
    May 23, 2010
    2,629
    Research, 3095
    Yeah Millen has linked the correct place, SFF just stands for Small Form Factor, loosely translates to cases under 20L but you'll find most cases there linger between 6L and 12L and make use of the Console (Motherboard and GPU mounted parallel top to bottom for a slim and tall case) or Sandwich layout (Motherboard and GPU mounted parallel back to back for a slightly wider but shorter overall case with typically better GPU support)
    Would recommend you guys both get involved there as it's a booming community and there are so many talented people creating some pretty incredible designs.
    millen and adamsleath like this.
  13. AllezAllez
    AllezAllez Member
    Mar 21, 2017
    215
    Finally built up my Ghost S1. It wasn't ideal fending off all the jibes from my co-workers about my vaporware case :rolleyes:.
    But it finally arrived and thankfully without any major defects.
    Pros:
    - Build access is amazing. Even better than the M1 which was already very good
    - Makes M1 look enormous!
    - Extremely solid frame
    - Size is perfect. Either for an all air setup or for WC with some modding
    - Panel access is great for cleaning
    Cons:
    - Hard to mod. Steel is hard to work.
    - Some quality issues still. Power button is rubbish, some tooling marks internally, panels straight enough but not befitting price
    - Cost
    - No front facing ports
    Same internals as my Ncase M1 but running an external Hardwarelabs 480 radiator under the desk. HDPlex 400W AC/DC and DC/DC units were used. AC/DC converter is mounted under the desk.
    Thought I'd roll the dice with Primochill Vue. Time will tell I guess!
    Alfonzo, juzz86, Bertross and 6 others like this.
  14. SSJ4
    SSJ4 Member
    May 16, 2017
    1,145
    HOLY MOLY!
    Amazing work.
    AllezAllez likes this.
  15. Tazor
    Tazor Member
    May 23, 2010
    2,629
    Research, 3095
    That's probably the best looking and most original Ghost build I've seen, I absolutely adore Silver/Pink as a theme and you've nailed the tubing runs!
    Out of curiosity, what's the additional PSU unit connected to the HD Plex at the end of the GPU as you mentioned you were using an external AC-DC adapter? Is it some sort of hub device for managing fans/pumps/temps or something?
  16. AllezAllez
    AllezAllez Member
    Mar 21, 2017
    215
    The black unit at the end of the GPU is an Aquacomputer Aquero. It's a fan amp/temp sensor hub. It's able to drive the DDC from its fan header only as well as take USB and sensor readings from other hubs/drivers.
    The real benefit is that it lets you set up virtual sensors like this air/water delta to create smooth input/output fan curves. Far smoother and more accurate than fan curves based on component temperatures.
    Tazor likes this.
  17. Tazor
    Tazor Member
    May 23, 2010
    2,629
    Research, 3095
    Ah makes sense, very cool
    Can we also just take a moment to appreciate your thermometer on the back of the case xD very cool touch - and far more elegant that those chunky units you see in other systems.
  18. Szemen
    Szemen Member
    Sep 20, 2005
    1,079
    Dancase A4 v4 being shipped over! :) Back to SFF since my Core2 Shuttle days.
    I've got a ITX 1080, and a 120mm AIO ready. Just need to wait for Ryzen 3000.
  19. Tazor
    Tazor Member
    May 23, 2010
    2,629
    Research, 3095
    Nice one, V4 has some nice QoL enhancements - just be aware that it no longer includes the 120mm fan mount by default and this will need to be sourced separately so keep an eye on SFFLAB for when it comes up, cos you'll need to be quick.
  20. Szemen
    Szemen Member
    Sep 20, 2005
    1,079
    I do realise that and sucks they haven't got it yet. However since I need to wait for Ryzen, the timing might just work out.
    I have ordered the Asetek 645LT as well so I can go both ways for AIO.
