Mini PC for small cluster
Discussion in 'Portable & Small Form Factor' started by koss, Jul 5, 2019.
  1. koss
    koss Member
    Mar 6, 2009
    5,826
    Vic
    I am looking for a cheap 4 core Mini PC that can take 8GB of RAM, to make up a small cluster to learn Kubernetes and Docker Swarm on. I was going to use 4 x Raspberry Pi 4s, but someone in another thread suggested that I should be doing this on x86 hardware.
    I see on Amazon a bunch of Celeron based PCs a few of which can have 8GB RAM, is that state of the art atm in low budget Mini PCs?
    https://www.amazon.com.au/Qotom-Fanless-Celeron-Wireless-Industrial/dp/B0149YB7RC
  2. Phido
    Phido Member
    Jun 20, 2003
    6,039
    Dark City
    ASRock DESKMINI A300W is quite popular
    https://www.techspot.com/review/1816-asrock-deskmini-a300/
    2 x 16 Gb Sodimms https://www.mwave.com.au/product/crucial-16gb-1x-16gb-ddr4-2400mhz-sodimm-memory-ab80357
    3400G https://www.techspot.com/review/1878-amd-ryzen-3400g/
    A 1 or 2tb ssd.
    Quite a powerful mini system, but Ryzen stuff is so cheap now, if you wanted to go lower end you could.
    The intel stuff is pretty simular as they are based around celeron and I think are limited in max memory to 8gb.
  3. T1tan
    T1tan Member
    May 8, 2002
    5,950
    2605 / caaaaanbwa
    I built an ASRock a310 to act as a low power esxi server. 9400 + 32gb ram + qvo.
    You can spool up multiple VMs pretty quickly. Lower end CPU stuff would do the job. A second hand nuc could do a similar job.
