Mixed Ethernet over Power adaptors
Discussion in 'Networking, Telephony & Internet' started by Ravennoir, May 10, 2010.
  1. Ravennoir
    Ravennoir Member
    May 1, 2007
    6,505
    Hey Everyone,
    I currently have two Ethernet over Power adaptors and I need to get more
    Does anyone know if I have to get the same ones (same model) or will they work with each other
    thanks
    Raven
  2. Heywood
    Heywood Member
    Dec 25, 2001
    457
    What do you currently have, and what are you proposing to add to your network?
    If they are standards based like HomePlug you can probably get them to inter-operate without much drama...
    Ravennoir
    Ravennoir Member
    May 1, 2007
    6,505
    I currently have two Netgear 200Mbps adaptors
    they connect my PS3 to the rest of the network
    im moving to a new place, and the phone jacks are in a very good place
    So I want to connect the router to the computer via one set and the PS3 to the network via another
  4. g00nster
    g00nster Member
    Sep 10, 2004
    352
    i've got 4-5 of the belkin ones running at any one time.
    They just work abit slowly.
    Ravennoir
    Ravennoir Member
    May 1, 2007
    6,505
    What I mean though, is can i buy the Belkin ones (say) and get them to work with my Netgear ones
  6. g00nster
    g00nster Member
    Sep 10, 2004
    352
    from what i can tell, the 85mb plugs talk to the 85mb plugs and the 200mbit plugs talk to the 200mbit plugs.
    there's a standard so i believe they should all play nice.
  7. Jemz0r
    Jemz0r Member
    Feb 26, 2002
    151
    Taipei
    Ok.. let me summarise.
    There are two competing chipset solutions for EoP.
    HomePlug 85 (Intellon)
    HomePlug 200 AV (Intellon)
    DS2 200Mbps (DS2)
    Different brands may use different solutions.
    Eg: Billion, NetComm, Belkin are Intellon, Netgear has used both Intellon and DS2
    So please check for the "HomePlug" sign to know if it is Intellon.
    In terms of compatibility....
    HomePlug 200 will connect with HomePlug 85, but speed of all EoP devices will drop to 85Mbps speeds.
    HomePlug and DS2 are incompatible.
    So if you want guarantee, better to get same brand/models. Unless you are certain they use the same chipsets.
  8. pongie
    pongie Member
    Dec 1, 2004
    1,050
    Sydney 2166
    slightly off topic but is there any advatanges/disadvantages between the two chipset?
    DS2 200Mbps (DS2)
  9. Jemz0r
    Jemz0r Member
    Feb 26, 2002
    151
    Taipei
    In terms of features, they are about the same.
    I find DS2 has better range and can work with more interference.
    Due to work, I have both devices to test with. I've encountered some instances where a pair of DS2's will work okay'ish, but the Intellons can't even connect.
    But due to the way the market unfolded, there are more Intellon products available.
    Kinda like VHS vs Betamax..
