Mobos and CPUs for Linux use?
Discussion in 'Other Operating Systems' started by vladtepes, Mar 6, 2019.
  1. GumbyNoTalent
    GumbyNoTalent Member
    Jan 8, 2003
    7,003
    Briz Vegas
    Can I buy the laptop with Linux pre-intalled? NO. So the VENDORs Lenovo and HP don't want to support Linux for this hardware. EDIT which is a good indicator of the cheap chipset being shit because both Lenovo and HP support Linux on lots of things.
    FFS there are more WiFi chipsets that do work vs a few DUMB chipsets that don't even work that well on the supported platform WIN10.
  2. zeggie
    zeggie Member
    Oct 4, 2002
    385
    That doesn't make it sound any easier for new users, literally the basis of my first 2 posts.
    Care to share a list of supported wifi chipsets for OP? Literally also the basis of their thread.
    vladtepes likes this.
  3. zeggie
    zeggie Member
    Oct 4, 2002
    385
    How's your comprehension? I literally said in my first post "Took me about 2 hours but managed to get my new laptop wifi working thanks to some awesome bloke who coded a driver on Github."
    This is out of the realm of new linux users, which others argued otherwise, and have now backtracked saying rah rah Vendor, rah rah use Windows 10. It also isn't the "proper" driver.
    Out.
  4. shredder
    shredder Member
    Dec 26, 2001
    11,213
    Dec 27, 1991
    The takeaway is that one should always check hardware compatibility for any OS (preferably before purchase or implementation).
  5. Quadbox
    Quadbox Member
    6,157
    The advice for wifi chipsets hasnt changed in a decade. Get atheros, or get intel.
  6. flu!d
    flu!d Ubuntu Mate 16.04 LTS
    13,052
    It's a reverse engineered Windows driver and nowhere as good as a driver coded by the open source community with actual support from the hardware vendor.
    This is the point you keep missing, any form of Linux support from Realtek is totally and utterly non existent. Without any documentation or support from the hardware vendor it's almost impossible to create an effective driver.
    Nouveau is the perfect example of this.
    vladtepes
    vladtepes Member
    Sep 30, 2015
    1,979
    Brisbane, Qld
    Precisely and exactly why I started this thread. :D
    zeggie and shredder like this.
  8. gdjacobs
    gdjacobs Member
    Apr 3, 2007
    1,206
    MB, Canada
    I'm not entirely sure what took you two hours. DKMS installs are generally quite easy.
    Absolutely. The best option is if the driver can be licensed in a way that allows inclusion in the kernel tree and is compliant with licensing policies for downstream distributions. Like with Broadcom, these drivers from Realtek sit somewhere between good drivers like the ath5/ath9/ath10 series from Atheros and being stuck with NDISwrapper as in the old days.
  9. GumbyNoTalent
    Jan 8, 2003
    7,003
    Briz Vegas
    The basis of my first reply to you was that any new modern chipset created in the last 5 years and not extending on a previously poor supported chipset has been supported, you are yet to provide the 100s of chipsets you where talking about, just one that is based on a older than 5 year chipset. As for being easy for new users, that is subjective, just because you find it hard to follow instructions that others would take 15mins doesn't mean the whole Linux ecosystem is flawed, and I would bet any new user would have the same dificulties installing drivers with OSX or Windows because they come preinstalled don't need to contend with this issue, so if the new user expects the same experience then they should buy a pre-install device like they have done previously, OR start learning rather then bitching.
  10. zeggie
    zeggie Member
    Oct 4, 2002
    385
  11. waltermitty
    waltermitty Member
    Feb 19, 2016
    902
    BRISBANE
    ac7260 is my pick for cheap/reliable/supported, can be had for $20 on aliexpress, buy a mini pci to pcie wifi adapter if you wanna use it in a desktop scenario
    even has a BT radio if you're that way inclined
  12. flu!d
    13,052
    My Dell workstation uses Broadcom networking chipsets, absoultely faultless.
    Unlike Realtek.
  13. waltermitty
    waltermitty Member
    Feb 19, 2016
    902
    BRISBANE
    There's still some broadcom cards that use the wl driver which is not in kernel, I give them a wide berth
  14. gdjacobs
    gdjacobs Member
    Apr 3, 2007
    1,206
    MB, Canada
    Their gblan adapters are decent, but I found chipsets using the brcmsmac driver to be quite glitchy. Maybe I'm the only one...
    Focus on Atheros, Intel, and Ralink (now Mediatek).
  15. flu!d
    13,052
    Mine's GB LAN, using the tg3 driver. Never missed a beat.
    However, I use Broadcom on this device as that's what the device came equipped with. If I had to purchase a networking adapter it would be Intel, Atheros or Ralink all the way.
  16. GumbyNoTalent
    Jan 8, 2003
    7,003
    Briz Vegas
    Intel anything.
