Modding a case
Discussion in 'Modding' started by Damianb, Nov 5, 2008.
  1. Damianb
    Damianb Member
    Feb 12, 2007
    1,852
    Ok so me and a mate are going to mod his case and stuff. because we want something to do during the holidays.
    We're going to change his current LED fans colours. so we're buying purple LEDs and doing whole new wiring and putting a switch to turn just the LED's on & off.
    we're using these LED's. there are so many numbers in the specs so i was wondering. what is the Voltage number we should take note of?
    We were going to use a switch like this and i was looking at setting up the wiring like this:
    The circles are LED's...
    Will this work?
    Thanks
    DamianB
  2. C0L0N3L
    C0L0N3L Member
    Apr 18, 2006
    697
    that would work but i dont think series is the most effective way of wiring it.. i think you would be 2v short with that circuit.. and the line up the top seems pointless to me...
    disclaimer: I'm not 100% sure if what I said is correct..
    Damianb
    Damianb Member
    Feb 12, 2007
    1,852
    yeah the line up the top seems to be a mistake by me. lol
    What would be a more effective way to wire it?
  4. C0L0N3L
    C0L0N3L Member
    Apr 18, 2006
    697
    umm.. reading your post again... are your changing the colour of the LED's in LED fans or making LED fans?
    parallel would be better i think..
    so with out drawing a diagram
    ____~_____+___+__+__+
    ___________-___-__-__-
    ~ resistor not sure what you need depends if you use 5 or 12v
    _+_
    _-_ = LED.. very crude but you should get the idea...
  5. slamaa
    slamaa Member
    Jun 1, 2006
    2,064
    Reservoir, VIC
    He Has wired it in a series/parallel conbination, each row of LED's is in series and each row is set parallel to each other.
    Just remove the wire from the top, it will be fine, You also need a resistor in front of each row of series LEDs
  6. C0L0N3L
    C0L0N3L Member
    Apr 18, 2006
    697
    are you sure he needs a resistor if they are in series?
    I know how he wired it... but I'm pretty sure they wouldn't be as bright as they could be in series..
  7. slamaa
    slamaa Member
    Jun 1, 2006
    2,064
    Reservoir, VIC
    Damianb
    Damianb Member
    Feb 12, 2007
    1,852
    Yeah i was thinking. due to them being series/parallell there would be 12v to each parallel
    seeing as there are 4 LED's on each parallel then there will be 3v supplied to each LED correct?
    Also in the description for the switch it says 12v. so i'm assuming that means it uses 12v. if so, will this work?
  9. C0L0N3L
    C0L0N3L Member
    Apr 18, 2006
    697
    yep that sounds about right adding a resistor in there would make them really dull.
    yeah the switch is 12v i believe so yeah that circuit is looking good without the extra line
    Damianb
    Damianb Member
    Feb 12, 2007
    1,852
    if their rated voltage is like 3.3-3.7v and 3v is sent through them. will they still work properly?
  11. C0L0N3L
    C0L0N3L Member
    Apr 18, 2006
    697
    yep they will just be a little dull.. wont be that much of a difference but it would be noticeable.. if you did it in parallel they would all be bright.
    Damianb
    Damianb Member
    Feb 12, 2007
    1,852
    Problem with parallel it will be a lot harder actually wiring it. so we'll go with slaamas design
    Should we just get the weakest resistor we can? or not bother?
  13. C0L0N3L
    C0L0N3L Member
    Apr 18, 2006
    697
    i wouldn't bother... i dont see how either are any different in wiring but yeah.. good luck and have fun
  14. Ephphatha
    Ephphatha Member
    Mar 3, 2006
    108
    Bathurst NSW
    I'd wire it with five parallel runs of three LED's and a 50ohm resistor in series. I miscounted and didn't realise you had sixteen already. Do you really need sixteen? You can stick with four runs of four, but I wouldn't advise it. eight runs of two LED's would be better, but then you will need eight 166ohm resistors.
    It'll stop them drawing too much current and burning out.
    The lamp in the switch will be fine though, it already has an included current limiting resistor.
    Edit: All this is assuming you're running the lights off a 12v PSU rail.
    Damianb
    Damianb Member
    Feb 12, 2007
    1,852
    Yeah. i think i've changed my mind again and i'm going with eight runs of 2 leds.
    If i do it like this
    How do i wire in the switch?
    sorry about all the nooby questions. i really should've paid more attention in physics when we learnt all this stuff. lol
  16. C0L0N3L
    C0L0N3L Member
    Apr 18, 2006
    697
    you wire those up and put the switch on either side.
    I don't think there is much else on the switch so I don't think it will mater which side of the circuit you put it on or which wires are on which side.. you just need it to open and close the circuit.
  17. onoff312
    onoff312 (Banned or Deleted)
    Apr 22, 2008
    813
    Or you could get put one 220 ohm in and have it substitute for them all. Might be cheaper - you don't need 8.
    Damianb
    Damianb Member
    Feb 12, 2007
    1,852
    Yeah i spoke to my physics teacher and that's what he said we should do.
    I'll give you updates on this in the next few weeks when it gets up and going.
  19. Ephphatha
    Ephphatha Member
    Mar 3, 2006
    108
    Bathurst NSW
    Time for a little gimp drawing I think.
    The five lines on the right are contacts for the switch, I am using this image as a reference.
    If you want the switch light to be always on, wire it like so.
    If you want the switch to light up only when the rest of the lights are on, wire it like this.
    I would suggest using 180ohm 1/4w resistors instead of 220ohm 1/2w resistors. The resistors will be dissipating 1/8W so you should be fine unless they get extremely hot from other sources. If you get 1/2W resistors, it doesn't matter as long as they are the right resistance.
    Your LED's pull 30mA and operate at 3.5V. The required resistance is Voltage drop [5V] (Which is given by Supply Voltage [12V] minus the sum of the Forward voltage of your components [3.5V x 2]) divided by the current required in amps [0.03]. This comes out to 166ohms.
    The heat dissipated is given by the Voltage drop multiplied by the current draw, which is 0.15 Watts in that example.
    Given that there is no 166ohm resistor, the next highest is the 180ohm. That will give you a slightly lower current supply or voltage, and thus will dissipate more heat. (0.16 watts or so).
    I would not advise using one resistor, it will have 0.03 * 8 amps running through it and will certainly burn out the moment you turn the circuit on unless you get a 5W resistor. Besides, you can buy a strip of ten 1/4W resistors for 50 cents at leading edge.
    Edit Edit: I'm a little rusty on this, but I'm fairly sure that the other reason using one resistor for a set of parallel components was not advised is because if any part of the circuit has less resistance than the other paths it will draw a greater percentage of current. If one loop fails, then the other seven loops suddenly have to deal with the current. Pretty much, using one resistor means the weakest link will die faster, and when it does the rest of the circuit will suffer (the next weakest will die even faster, the next weakest after that will die even faster, once four loops are down the rest of the LED's will burn out almost instantly).
    Edit: I apologise in advance for any factual errors, I haven't had to do any electronic work for a while.
    Damianb
    Damianb Member
    Feb 12, 2007
    1,852
    Ok great. thanks
    We've decided to have the switch light to be always on
    What if it was done like this:
    Would that work?
    Voltage drop = 12 - 3.5
    / .03 = 283.3 ohm
