modding fan cables to go into a fan controller
Discussion in 'Modding' started by mehkat, Jun 15, 2011.
  1. mehkat
    mehkat (Banned or Deleted)
    May 3, 2010
    1,368
    Well that's basically what I don't want to do - cut and join 3 fan cables onto one header, as I don't want to ruin the fans (I'll do it if it's the only option or ditch the fan controller altogether)
    I have a couple of these
    http://www.pccasegear.com/index.php?main_page=product_info&cPath=19_197&products_id=17451
    not the nice bitfenix ones, something similar
    but they go to molex, which is useless to get to the fan controller.
    Also got one of these
    http://www.pccasegear.com/index.php?main_page=product_info&cPath=19_197&products_id=14690
    also useless, because the header is too short to fit into the connector on the fan controller.
    So can I safely pull off the short header and stick on one that will fit on there and connect that to the molex end of one of those bitfenix things? Essentially it's the same thing right?
    (edit 2: actually at a closer look they are very different - the molex to 3 pin adapter only has black/red, whereas all the other cables are black/red/yellow)
    I can probably use a header off NB cable extensions
    cheers!
    edit: so what I really want is something like that bitfenix thing but with a 3 pin header on the end instead of molex
  2. MoultoMan
    MoultoMan Member
    Dec 19, 2010
    405
    3132 Melbourne Australia
    just snip the wires and solder/twist the wires together to get the combo you want
    mehkat
    May 3, 2010
    1,368
  4. null object
    null object Member
    Jan 3, 2011
    87
    Smarrickville
    mehkat
    May 3, 2010
    1,368
    oh yeah... good spotto, but why on earth would it be that way around when the fan header is male
  6. leithals
    leithals Member
    Feb 23, 2011
    694
    Central Coast 2257
    I looked for exactly these things a while back. If you go to your local PC shop they should have the three pin fan splitters you require (I found mine at the local OrangeIT store). Nobody seemed to stock what was required. I have subsequently purchased some of these, but even they need a modded cable to connect them to a fan controller. They work well though.
  7. Bladen
    Bladen Member
    Jun 11, 2004
    995
    Crazytown, pop 6 bil.
    I think you need two of these or these better looking ones. Two of the first one (daisy chained) is how I run 3 Zalman ZM-F3's off of one Rheobus Extreme fan speed knob.
    mehkat
    May 3, 2010
    1,368
    I have a couple of those the problem is that even though that's the right thing, the header is too short to actually fit into the fan controller
    anyway, it doesn't matter as I've sold the fan controller
    but thanks for helping!
    mehkat
    May 3, 2010
    1,368
  10. Huggy_Bear64
    Huggy_Bear64 Member
    Apr 24, 2010
    3,096
    Melbourne, VIC, 3127
    you want 12v to run them at full speed, or 7v to undervolt and make them quieter...
  11. Cephas
    Cephas Member
    Aug 30, 2002
    364
    As the purchaser of previously mentioned fan controller, thanks for the links :)
    Just need to find out if the BitFenix 3 way connector only passes thru the RPM from one fan, not all 3.
    mehkat
    May 3, 2010
    1,368
    Hey I was just about to pm you but as you're in thread -
    I sent that off platinum at about 5pm so you should get it tomorrow :)
    OK another stupid question re those fan extensions it's just a wire though how does it regulate voltage? I don't really want to undervolt them but I guess 7V would be ok
  13. Huggy_Bear64
    Huggy_Bear64 Member
    Apr 24, 2010
    3,096
    It just wires the fans to the 12v or 5v rails on the PSU...
    You can do it yourself by swapping the wires on any molex>fan cable converter thingy.
    mehkat
    May 3, 2010
    1,368
    Oh cool thanks man
    so I can re-wire it to run at 12V I'll look into this
    cheers
  15. Huggy_Bear64
    Huggy_Bear64 Member
    Apr 24, 2010
    3,096
    not sure how the bitfenix ones are wired, but the the 5v one, in theory, would be easier to change to 12v...
