Modular PSU Help - New Build
Discussion in 'Newbie Lounge' started by Doughboy, Jun 24, 2022.
  1. Doughboy
    Doughboy Member
    Sep 19, 2007
    642
    Perth - WA
    Hi All
    First time I have built a new system in 7 years and I bought a Silverstone 850W PSU (not my 1st choice, but all I could get)
    It is not very well labeled and I have searched for an instruction manual to no-avail. I am struggling with the PCIe connectors, as they have a weird extension cable on the end and I'm not sure which end is for the card and which end is for the actual PSU. See link below
    https://www.ple.com.au/Products/643...0W-80Plus-Gold-Fully-Modular-ATX-Power-Supply
    Also, the CPU 4 & 8 pin connectors are strange too...
    Specs:
    ASUS TUF Gaming Z690
    i7 12700
    EVGA 3080
    I am seriously thinking about either returning or getting cable extensions
    Any help is appreciated!
  2. jjjc_93
    jjjc_93 Member
    Jul 3, 2009
    3,971
    The PCIE Cables will be 6pin with a separated 2 pin (6+2 setup) on the end where they go to the GPU.
    The 4/8pin CPU will be 4+4 on the motherboard side.
    They should be keyed so that you can't actually get it wrong.
    Doughboy likes this.
    Doughboy
    Doughboy Member
    Sep 19, 2007
    642
    Perth - WA
    Thanks for the response. I am not sure if these ones are keyed(?) Could be wrong
  4. O-B-E-L-I-X
    O-B-E-L-I-X Member
    Jul 11, 2008
    977
    SYD, 2036
  5. Groff
    Groff Member
    Jun 22, 2012
    402
    NSW
    Check this pic out
    https://i.stack.imgur.com/Spsgx.png
    Shows the ATX standard of EPS (CPU) and PCIe (GPU) plugs
