Monitor recommendation (Narrowed it down to 2 i like)
Discussion in 'Video Cards & Monitors' started by Pr3dator8, Oct 7, 2019.
  1. Pr3dator8
    Pr3dator8 Member
    Dec 28, 2009
    386
    Lane Cove 2066
    Hey all. Im downsizing my monitor. Going for a 32inch 4k with HDR10. Mostly used for gaming on my ps4 pro and mostly FPS games. Ive narrowed it down to two option i like, both kind of at opposite ends of the price range. Ideally id go the cheaper option but Im worried if i go that route that there might be some key features id be missing out on and how that would effect my specific use.
    LG 32UD99
    LG 32UK55
    Thanks heaps in advance :)
  2. elvis
    elvis Old school old fool
    37,892
    Appears that the UD99 is an IPS panel, and the UK55 is a VA panel.
  3. macktheknife
    macktheknife Member
    Jul 26, 2005
    736
    Out of those two I'd get the 32UD99-W... but personally, the X34P is the same price as that and it's a better monitor except for the HDR.
    Pr3dator8
    Pr3dator8 Member
    Dec 28, 2009
    386
    Lane Cove 2066
    not a fan of ultrawide. especially for primarily console gaming
    macktheknife likes this.
  5. luke o
    luke o Member
    Jun 15, 2003
    3,524
    WA
    Why get a monitor for console gaming? The VA panel would probably be the better choice. The IPS one if you do photo or video editing, better colour reproduction but slower response times.
  6. elvis
    37,892
    Typically they have lower lag.
    Pr3dator8
    Pr3dator8 Member
    Dec 28, 2009
    386
    Lane Cove 2066
    That and also i game at a desk so i sit fairly close
    elvis likes this.
  8. Sphinx2000
    Sphinx2000 Member
    Sep 16, 2001
    7,873
    The IPS panel would be my pick, There is a reason it's nearly twice the price of the VA model.
    I just prefer IPS colour over VA speed, if only slower by 1ms.
    elvis likes this.
  9. elvis
    37,892
    Ditto. OLED is the colour king, but there are other downsides to that tech (pros and cons, always). If I'm playing on LCD, then I want an IPS panel.
    That's fair enough. Modern tellies are getting massive, so if you're not sitting way back on a couch, they can be way too big.
