Monitor without DP
Discussion in 'Video Cards & Monitors' started by C.Y, Sep 18, 2020.
  1. C.Y
    C.Y Member
    Jun 11, 2020
    45
    Hi All
    I just wanted to double check my understanding.
    I have a triple monitor (144hz) setup but one of the monitors only has DVI or HDMI.
    Currently on a RX580 which can support the above ... but with all the hooha that is going on regarding new GPU's at the moment ... its probably the right time to upgrade.
    However given most higher grade GPU's have 3 DP's ..... my options are
    1. Find a card that can support DVI
    2. Replace the said monitor with a monitor that has DP
    My understanding is the DVI to DP cables only work one way (DVI as output into DP as input and not the other way around)
    Is this correct ??
    TIA
  2. 335 GT
    335 GT Member
    Aug 3, 2019
    1,126
    W.A.
    Cables aren't directional. It's just electrons flowing down a wire.
    So use that cable or an adapter.
  3. kogi
    kogi Member
    Jan 23, 2003
    4,880
    2031
    I have some ebay dp to hdmi cables and they work. Bear in mind there are 4k specific ones if u want 4k
  4. Sir Didymus
    Sir Didymus Member
    234
    DP to DVI adapters are common and cheap. Going from DVI to DP is different as you need an active adapter to process the signal into DP.
    Cables can absolutely be directional because the ports are expecting different signals. It's not just a matter of making the physical connection.
    Reins likes this.
  5. 335 GT
    335 GT Member
    Aug 3, 2019
    1,126
    W.A.
    Yes.
    I misread his post.
  6. Goosegamer
    Goosegamer Member
    Aug 16, 2010
    541
    Harkness, 3337
    I’m confused? Most gpu’s I have seen coming out have a HDMI option as well, couldn’t you use a HDMI cable with the monitor that is HDMI/DVI only?
  7. MR CHILLED
    MR CHILLED D'oh!
    Jan 2, 2002
    156,218
    Omicron Persei 8
    Just grab an HDMI to DVI cable for the monitor that has that, they are cheap enough. As above you will have an hdmi output port on the new card.
  8. Sphinx2000
    Sphinx2000 Member
    Sep 16, 2001
    9,555
    Incorrect. DP to DVI adaptors and cables are certainly a thing, I use them all the time for clients who have OEM workstations that only feature DP.
  9. power
    65,255
    i buy DP-HDMI cables in lots of 50 from fleabay for work.
    just get some off eBay .
  10. nav
    nav Member
    Aug 20, 2001
    4,219
    melbourne
    Yea, as suggested grab them off Ebay. I've had problems achieving 4K (and above) resolution with some DP cables though, something to look out for.
    -nav.
  11. power
    65,255
    yeah i'd make sure you can push what you want through them we only use them for 1080P.
    C.Y
    C.Y Member
    Jun 11, 2020
    45
    Thanks all for the replies ... much appreciated
