Most silent 3.5" HDDs for Raid
Discussion in 'Storage & Backup' started by im late, Aug 31, 2017.
  1. im late
    im late Member
    Jan 5, 2012
    1,681
    Canning Vale WA 6155
    I have several devices at home which stream content from my Plex server (my PC which is on 24/7).
    So it was a very silent build.....until I added the 3.5" HDDs.
    They are not too bad...but being the fact they are enterprise drives and 7.2K, they were of course designed to sit in a noisy server room..not in a home PC.. :D
    So, which drives do you guys use to store your content if the drivers are in your PC and you like a silent optimized PC?
    Are WD Reds pretty much the most silent and raid ready?
    Or are there other makes/models you guys use?
  2. NSanity
    NSanity Member
    Mar 11, 2002
    17,968
  3. cbjaust
    cbjaust Member
    Sep 11, 2003
    1,283
    make a separate box for your server and put it another room :thumbup:
    im late
    im late Member
    Jan 5, 2012
    1,681
    I wrote silent HDD..........
    im late
    im late Member
    Jan 5, 2012
    1,681
    Not an option anymore.
  6. McRutch
    McRutch Member
    Jul 10, 2011
    216
    it's always an option, just use your imagination :)
    my NAS is in the ceiling space :lol:
    im late
    im late Member
    Jan 5, 2012
    1,681
    I simply asking if anyone else if they have used drives in their own computers and which ones they went to for silence optimized.
  8. HobartTas
    HobartTas Member
    Jun 22, 2006
    944
    Why did you choose noisy enterprise drives? they are only useful for performance, reliability and for the TLER function in hardware arrays and all of these attributes can be replaced by using much cheaper consumer drives with ZFS. The best drives for noise would be 5400 RPM ones like Hitachi coolspins if you can still find anything like them available followed by any 7200 RPM drives. The manufacturers usually do specify decibel limits in their documentation. Also check if you have the AAM setting available which I had in my Samsung drives and change that to the lowest setting possible (usually 0) as that will reduce head actuator noise.
  9. hippyhippy
    hippyhippy Member
    Apr 1, 2004
    8,449
    if you just running your system for media.. why u need raid?
  10. terrastrife
    terrastrife Member
    Jun 2, 2006
    18,766
    ADL/SA The Monopoly State
    any 5400/5900 rpm drive, if silence is what you're after, go to Bunnings or Clark rubber and buy some foam strips to make some "caps" for the ends of the HDDs then just sit them somewhere, don't use the drive bays, not even with rubber grommets.
    im late
    im late Member
    Jan 5, 2012
    1,681
    I did not "choose", these are what I have now. Will sell them off if I can find suitable drives.
    Thanks for the info.
    im late
    im late Member
    Jan 5, 2012
    1,681
    It does not just hold movies, it holds important data. So I have this raid and cloud.... but this is going off topic now...
  13. callan
    callan Member
    Aug 16, 2001
    4,893
    melbourne
    WD reds get quite noisy when raising a sweat.
    mind you, Whilst I wouldn't go so rural as terrastrife has suggested he is onto something: how a drive is mounted is at least as important as the drive itself when it comes to noise. The trick is getting the drive mounted quietly whilst maintaining ventilation, and in that sense you may do better using 2.5" drives instead. I know you stated you were after 3.5" drives, but 2.5" drives tend to be significantly quieter, (I looked, 2-3dB less: that's a lot) and you can get quite large ones for not a lot more than 3.5" drives if you're not picky (and in your situation I doubt performance is a primary consideration). If the chassis you have only has 3.5" mounts get a cradle.
    Callan
  14. Copie
    Copie Member
    Jul 24, 2009
    13,866
    Newcastle
    If you don't want to go 2.5 inch drives then helium drives are the quietest in that size apart from ssd.
    But the issue isn't drive noise but keeping them cool
    im late
    im late Member
    Jan 5, 2012
    1,681
    Update.
    I just went with a WD Blue 3TB in my HTPC. Very silent. :thumbup:
    And a Verbatim 4TB USB3.0 external connected to my Asus DSL-AC68U (as the backup device).
  16. CAMS
    CAMS Member
    Jun 30, 2001
    1,344
    I have a Seagate 3.5" BarraCuda PRO 10TB that is helium filled and its far from quiet.
  17. ipv6ready
    ipv6ready Member
    Feb 10, 2014
    2,707
    North Sydney
    You can also go for silent case. The foam insulation in the case made a big difference.
    I use coolermaster silencio series as my HTPC/ NAS, nothing fancy but it helps.
    1 x noctua silent fan intake,
    Corsair h60 with silent noctua fans as exhaust
    Asus strix gtx1050ti with zero fan tech.
    Seasonic 400w platinum fanless
    3 x 4tb greens.
    1 x Seagate
    64gb ssd.
    I don’t use raid as I keep a separate offline backup but even in my living room it is very quite.
