Motherboard for i7 8700k
Discussion in 'Intel x86 CPUs and chipsets' started by Digidave, Feb 21, 2019.
  1. Digidave
    Digidave Member
    Jan 23, 2018
    20
    Need assistance in selecting a motherboard for the following CPU from Umart:
    i7 8700k
    I only want to run 1 graphics card (not interesting in SLI)
    32GB Ram
    ______________________________
    Dual Channel Ram? Will 2X16GB Dual Ram only be detected as 16GB
    What Ram should I get?
    Appreciate any help and happy to answer questions.
    Not going to need much more than 1 SDD and Secondary Drive. Nothing too fancy for this build. Only going to run a 1080 Ultra Wide 144G sync with budget high end Galax GTX 1080. I know it could run 2K - but figured for a budget 1080 card is best to max out on ultra smooth game play all the way up with fasted frames and refresh as possible??? Not wishing to spend $1200-1500 on a higher end comparable 2K monitor and then again on Graphics equal to the resulting selected monitor and card setup. I doubt the budget 1080 would run as effectively on a higher end 2K monitor. I know it could do it ... but If I went 2K I would buy a more expensive video card. Welcome your thoughts.
    But for now ... I am not sure what Motherboard???????
  2. DarkSnipa
    DarkSnipa Member
    May 13, 2017
    425
    For 8700K I am not sure what your budget is, but as most good Z370 boards are discontinued picking from Umart's Z390 something like Gigabyte Z390 Aorus Elite/Pro with beefy VRM will suit you nicely if you are serious in CPU overclocking but not serious in memory overclocking and you do not mind Gigabyte's unintuitive BIOS.
    Digidave
    Digidave Member
    Jan 23, 2018
    20
    Thank You. That helps.
    ~Cheers.
  4. philquad
    philquad Member
    Jan 22, 2004
    859
    nelson bay
    Digidave
    Digidave Member
    Jan 23, 2018
    20
    Thanks ... I can't beleive they are charging up to $60 extra on a Motherboard already priced over $220 for a necessity such a WIFI. I'd rather buy the $300 gigabyte board."
    WOW - Just looked at a $300 Gigabyte board without WIFI ??????? Hmmmm ... I am going to have to rethink things as it seems the Industry is exploiting things a little too much to my liking. I have been out of the game for a while, but thought wifi used to be standard on many boards over 200 ... at least you got it with a 250+ MB. The PC building game seems to be lacking for me now.
    32GB ram minimum for me ... but yea ... that ram is indeed a good budget option.
    Digidave
    Digidave Member
    Jan 23, 2018
    20
    For the price this Asus Board looks Good enough for my purposes. I am still getting over the high prices on inbuilt wifi and just cant justify supporting it.
    Do you think a cheap WiFi card will do in this Asus board and also could the PCI-e Wifi Card be effectively installed low enough (without effecting priority of slot placement) not to interfere with Graphics cooling?
  7. philquad
    philquad Member
    Jan 22, 2004
    859
    nelson bay
    dont quote me but unless your overclocking etc you could get away with a lot cheaper board, like h370 maybe, think its compatible
    & wi-fly, i cant see how onboard wireless can be much different then say a card or usb job
    i buy them $10 usb things on ebay as long as your only within short range of the router
    think onboard wi-fi is aimed at mini-itx boards for whatever reason
    Digidave
    https://www.umart.com.au/TP-LINK-TL...-2T2R--2-4GHz--802-11n-g-b--2-det_22368G.html
    stick 1 of these down the bottom.
  8. demiurge3141
    demiurge3141 Member
    Aug 19, 2005
    1,347
    Melbourne 3073
    MSI Z370-A pro, $158 from MSY.
