motherboard-to-power switch connector
Discussion in 'Newbie Lounge' started by kaz3e, Nov 22, 2006.
  1. kaz3e
    kaz3e Member
    Jun 15, 2006
    119
    Hi,
    I'm trying to reusing an old case that has lost the wires connecting the power switch to the motherboard. Is there some place to buy replacment ones or some way to make them?
    Cheers,
    kaz3e.
  2. inspectr
    inspectr Member
    Jan 3, 2002
    759
    Rose Bay NSW
    PM me an address and I can send over a spare pair if you cant get one from the members in Perth - one for the power and one for the reset button (correct?). Big case or a small one?
    I salvage them from every case that gets thrown out.
    kaz3e
    kaz3e Member
    Jun 15, 2006
    119
    It's an AT case use to house a old 486.
    I'm interested in the wiring as I'm thinking of getting one of those military type toggle switches. Can I just connect any two wires?
    thanks inspectr, if i can't get any i'll PM you.
  4. nux
    nux Member
    Jan 20, 2002
    16,780
    If its an AT motherboard and PSU, then you don't connect a wire to the motherboard. It comes from the PSU.
    If its an ATX motherboard, you need a momentary switch to turn it on. Not a toggle switch.
    kaz3e
    kaz3e Member
    Jun 15, 2006
    119
    Yeh I'm going to be using an ATX motherboard & PSU and the toggle switch I'm looking at says it's momentary. Just not sure about connecting it to the motherboard.
    Also if there is more than two connecting points on the switch which ones do I use? :confused:
  6. The Brat Prince
    The Brat Prince Member
    Jun 26, 2004
    498
    run a key along the header until it turns on, that'll find that power switch pins for ya
  7. nux
    nux Member
    Jan 20, 2002
    16,780
    The switch will have 2 or 4 contacts, if it has 4 they're just doubled up. Use a multimeter to test which contacts are switched.
  8. inspectr
    inspectr Member
    Jan 3, 2002
    759
    Rose Bay NSW
  9. nux
    nux Member
    Jan 20, 2002
    16,780
    He wants a momentary switch for an ATX motherboard..
  10. blakeyboysmith
    blakeyboysmith Member
    Dec 11, 2004
    379
    ok there normally two pins on the motherboard that when shorted power everything up..
    you want to connect two wires to these pins and then to a momentary switch.. be it a momentary toggle (i.e it springs back) or a push button so it completes the circuit only when depressed. you can pick up such switches from places like jaycar.
    its pretty simple to wire up. i guess finding an old connector to use on the mobo header to connect the wires to the pins would be the harder part to find.. you could just solder straight to the pins if you wanted to be totally dodgy.
  11. inspectr
    inspectr Member
    Jan 3, 2002
    759
    Rose Bay NSW
    And that is EXACTLY what is pictured there - a momentary switch mated to a bracket that fits into an AT case switch mount.
    The switch that I have here CAME from a transition era case which could be used for either an AT or ATX setup. The beauty of what I am offering is that the switch is designed for the required application and the extension of the switch fits perfectly into the mount of the AT style case, it has a 2 pin connector and is even labelled "POWER SW"
    kaz3e
    kaz3e Member
    Jun 15, 2006
    119
    Thanks for the replies guys.
    I think I'll take you up on that offer Inspectr, PM sending.
