Multiple Networks
Discussion in 'Networking, Telephony & Internet' started by TheVON, Oct 23, 2017.
Can 2 Networks run on a single PC
  1. Yes
    5 vote(s)
    100.0%
  2. No
    0 vote(s)
    0.0%
  3. Not Sure... MAybe
    0 vote(s)
    0.0%
Multiple votes are allowed.
  1. TheVON
    TheVON Member
    Oct 24, 2006
    26
    1/. Primary 1GBe network -
    IP Range: 192.168.1.1 - 192.168.1.256
    Subnet: 255.255.255.0
    Gateway: 192.168.1.1
    I am setting up a second 10GBe network using 2 x ASUS 10GBe Areion NICs with a Netgear Prosafe 10GBe XS708Ev2 Managed Switch.
    2/. Secondary 10GBe network -
    IP Range: 192.168.0.1 - 192.168.0.256
    Subnet: 255.255.252.0
    Gateway: No Gateway
    ( LAN Only for file transfers )
    I think the Unidentified Network is my problem is there a way to make it Network 2
    can it be changed to this shown below
    I can ping all of these
    Switch: 10GBe IP Address - 192.168.0.239 ( Running in DHCP )
    PC 1: 10GBe IP Address - 192.168.0.210 ASUS 10GBe Areion NIC ( Windows 10 Pro x64 )
    PC 2: 10GBe IP Address - 192.168.0.71 ASUS 10GBe Areion NIC ( Windows 10 Pro x64 )
    NAS: 10GBe IP Address - 192.168.0.60 (Synology 814+ with 4 x 1GB ports ) I bonded 3 ports
    for a 3GBe connection
    I cannot seem to seem to get the shares on PC1 , PC2 & NAS to work ( see pic above )
    hope you can understand all this I am a Noob at multiple networking
    Any Help or Idea's would be greatly Appreciated
    TheVON
  2. evilasdeath
    evilasdeath Member
    Jul 24, 2004
    5,026
    your subnet mask is wrong on network 2 should be 255.255.255.0 not 255.255.252.0
    252.0 actually has a range of 192.168.0.0>192.168.3.255
    which mean your subnets overlap confusing windows
    you also need to make sure file sharing is enabled on the 10gbe interface and probably worth disabling it on the 1gbe unless you have other hosts?
  3. Doc-of-FC
    Doc-of-FC Member
    Aug 30, 2001
    3,396
    I was wondering how you could register 9 bits in an 8 bit register for a .256 ip address ;)
    knoted likes this.
  4. nicholasporison
    nicholasporison Member
    Aug 12, 2016
    180
    Melbourne(Vic), Australia
    wrong subnet mask
    TheVON
    TheVON Member
    Oct 24, 2006
    26
    What would be the correct one to use ?
  6. evilasdeath
    evilasdeath Member
    Jul 24, 2004
    5,026
