My first custom reservoir (Process and results)
Discussion in 'Modding' started by That's A Doozy, Oct 2, 2017.
  1. That's A Doozy
    That's A Doozy Member
    Oct 1, 2017
    19
    Hi guys. My first post here so I thought I'd make it a good one.
    It's been a dream of mine to build a reservoir and integrate it into the window of a case for some time. I initially went down the path of having someone else (A very well known custom PC builder with a huge Youtube presence) do all of the design work and production for me, but after waiting nine months with no communication from them except to sometimes reply to an email giving me excuses as to why we'd blown out the initial six-week timeframe, I decided to do it myself.
    Here is where it all started. This was done up in paint hastily as a way to try and visualise what I was going for.
    Now, I have some design experience and could have done the next step myself, but as a high school teacher I rarely find the time and since we were in the middle of marking season, I decided to outsource the designing to a fantastic case modder in Italy, FlowMods.
    He was absolutely fantastic and offered me a more than reasonable price.
    From top to bottom it measures at 570mm. Go measure that.
    YOU SEE THAT?! That's absolutely huge!
    So, now I had to source the case and acrylic block for machining.
    The block itself was actually quite cheap, but the shipping. Good lord. It was more than the damn block!
    And yet, it was still the cheapest option I had.
    From Sydney to Canberra it cost me $57 to ship it. The block itself was only $45.
    Here it is, and where it'll be sitting on the case window.
    My next job was to find a CNC shop with the equipment to machine acrylic this size.
    I eventually came across a shop called "Devilish Racing", who despite the name mostly built custom equipment for the Australian Defence Force.
    Naturally, Defence work took priority, so after about two and a half months I dropped by and picked up the freshly machined reservoir, threaded for M4 bolts to hold it to the window and G1/4 for the water cooling connections. He even cut the holes in the window for me, which was nice of him.
    So that was the easy part. Next came the polishing. This stage took about six hours in total.
    I needed a few things.
    600 and 1200 grit sandpaper.
    Kerosene.
    Most people wet sand acrylic with water, but kerosene is more viscous than water, so I drowned my sandpaper in that instead.
    A drill and polishing attachments (Reasonably cheap).
    Brasso.
    WD-40.
    Plastx headlight polish.
    FW1 cleaning wax.
    As you can see, the reservoir was quite cloudy from the CNC process. So my first step was to hit it with my kerosene drenched 600 grit sandpaper. This took about an hour.
    As you can see, it looks much clearer already. Next step, 1200 grit sandpaper and even more kerosene. Another hour :'(
    The improvement was a bit harder to see this time, but it felt MUCH smoother.
    After this came the brasso and drill polishing kit. Thankfully this was nowhere near as physically taxing as the sanding and significantly faster.
    So it looks much clearer now. Brasso is fantastic stuff and was recommended to me by Ross at Devilish Racing (the CNC shop that produced the reservoir). The only problem was that it gunked up the threads. This was something I would have to deal with a little later on.
    So, this is where I used the Plastx. The reservoir was much clearer already, but still cloudy in some areas, especially those the polishing attachments couldn't reach.
    I neglected to take a photo of the reservoir immediately after hitting it with the Plastx, but you can see the impact it had in this photo where I'm cleaning out the threads with WD-40.
    So I found that even though I was doing this part by hand, I couldn't quite clear up the internal corners. I grabbed my Dremel kit and attached the small polishing tools to finish that job. Something I once again forgot to take a photo of.
    But here is the reservoir after, about to get another hit from some Plastx. As you can see, it's already very clean at this point.
    Following this, I gave it a final polish with some FW1 cleaning wax. Naturally, I only applied this to the outside. You don't want wax residue flowing through your loop.
    Here she is, looking crystal clean. Polishing is now complete, thank god.
    So with the polishing out of the way I now had to measure and cut the O-Ring cord to fit. Please ignore my pyjamas.
    You can usually use superglue for this bit, but I opted for an O-Ring connecting specific glue (Sureloc SL406 Cyanoacrylate). Here it is fused together.
    Looks good, hey?
    Nearly done now. The first step of sealing it up was to bolt down a select few of the screws so that everything was lined up. This is the part where I had to be most careful. If I overtightened a single bolt, the entire thing would be ruined. I set my electric screwdriver to its lowest torque setting so that at the slightest touch of resistance it would automatically stop. I lightly tightened each bolt three times after they had been fully inserted so ensure that there would be no leaks. I cannot stress enough how careful you have to be here. As soon as you feel resistance, move on and come back around to it. After tightening every single bolt in the first pass I found that the bolts I'd first done now needed additional tightening.
    Here it is all fastened and ready to begin filling for the leak test.
    SUCCESS!
    Here she is! Finished at last.
    adz, Amfibius, Mujteba and 2 others like this.
  2. radeon_freak
    radeon_freak Member
    Sep 19, 2007
    3,155
    That's awesome! Nice work mate, keen to see the end build :thumbup:
  3. mad_mic3
    mad_mic3 Member
    Jan 18, 2009
    2,417
    Nulkaba
    sweet as:thumbup:
  4. SSJ4
    SSJ4 Member
    May 16, 2017
    811
    Nice work mate. Looking forward to the rest of the build.
    That's A Doozy
    Oct 1, 2017
    19
    Thanks guys.
    I'm planning an obscenely overkill Threadripper build. Just a matter of getting the cash now.
  6. Dingostolemyghz
    Dingostolemyghz Member
    Mar 30, 2011
    766
    It's huge!!!
    That res will hold more coolant than my entire loop did back when i was watercooling.
    That's A Doozy
    Oct 1, 2017
    19
    1100mL to be exact.
  8. Defyant
    Defyant Member
    Mar 11, 2004
    1,363
    Defyant Modded "Tail" Lights!
    nicely done :thumbup: very original idea
  9. Deano_20802
    Deano_20802 Member
    Apr 21, 2009
    426
    Tas
    An awesome result and serious cooling potential! Can't wait for more updates :thumbup:
  10. FlowMods
    FlowMods New Member
    Oct 12, 2017
    1
    Thank you for mentioning me!
    Awesome reservoir!
  11. AllezAllez
    AllezAllez Member
    Mar 21, 2017
    70
    Mind blown..... Thanks so much for posting this!!!
    - The o-ring in particular is so great to know. I always wondered how you'd design a custom block with a specific (I guess standardised) o-ring length. Who knew you could just bond together a custom length!
    - You have literally double the volume of my entire cooling loop in your res alone. Cool...
  12. MaxYenda
    MaxYenda Member
    Jan 13, 2016
    33
    I have an old IPad and it's not showing the photos, just a small box with IMG.
    Is this just a Apple thing?
  13. ginger_nuts
    ginger_nuts Member
    Sep 24, 2011
    1,235
    Morphett Vale, SA
    Love the imagination and originality of this.
    I have a question, and understand if you dont want to post here. But what did the machine shop charge you for the work on the res.?
  14. tunksy
    tunksy Member
    Dec 22, 2010
    378
    SA
    thats bloody awesome
  15. SinistaLad
    SinistaLad Member
    Jul 5, 2016
    26
    Yeppoon
    Got any more photos since the laser etching has been done :D
  16. aussie-revhead
    aussie-revhead Member
    Feb 21, 2005
    19,405
    St Clair 2759
    Very nicely done, you know you set the benchmark for the rest of the build right? Have you got anything else unique planned?
  17. MR CHILLED
    MR CHILLED D'oh!
    Jan 2, 2002
    146,537
    Omicron Persei 8
    Absolutely agree, this was some awesome work :thumbup:
    That's A Doozy
    Oct 1, 2017
    19
    Sorry for the late replies guys. Didn't see there had been any responses.
    He charged me $110 an hour, and it ended up being a four hour job. So $440.
    Have a look here for all the updates:
    https://forums.overclockers.com.au/threads/harvest-bitspower-purist-threadripper-build.1235204/
    Not sure at the moment. I've polished all my Bitspower blocks and will be painting the case too, but the reservoir is the standout feature and I'm not sure I want to draw attention away from it.
    Deano_20802 likes this.
