My little powerhouse project (mini-ITX performance)
Discussion in 'Overclocking & Hardware' started by Statts, Jul 22, 2009.
  1. Statts
    Statts RIP
    Aug 29, 2004
    2,504
    Radelaide, SA
    Hi all.
    just thought I would make a thread on the progress of building my mini-ITX desktop system. The system will be used for gaming, Uni work (including CAD), browsing, burning, you know, usual shit.
    So the system comprises of:
    Zotac 9300-ITX WiFi motherboard
    Intel Q9450 CPU
    4GB Crucial Ballistix DDR2-800
    Gainward HD4870 Golden Sample
    Silverstone SG05B case
    So here's some pics so far.
    So that's where it is up to at the moment.
    Next steps are:
    Fit slim DVD burner
    Fit Coolermaster Gemini II CPU heatsink without fans (passive) as per HERE
    Shorten, tidy and sleeve all cables once the heatsink is in and I know where I am at.
    Get an SSD to fill the 2.5" drive bay
    Anyway, discuss, criticise, whatever :)
  2. Pipster
    Pipster Member
    Sep 23, 2008
    584
    nice!!! looks quite good, whats the performance like?
  3. millsy
    millsy Member
    Mar 31, 2007
    12,758
    That's sweet, is the IGP an nvidia one or an ati one?
    Statts
    Statts RIP
    Aug 29, 2004
    2,504
    Radelaide, SA
    Installing Windows at the moment
    nVidia GeForce 9300
  5. Robinho_Skills
    Robinho_Skills Member
    Apr 14, 2009
    75
    Im thinking of doing the same thing but with a Phenom II 810 will this still be fine ??
    Also are you using the stock 300w power supply? Is it possible to swap this out for a Thermaltake 550w power supply
  6. fallout_man
    fallout_man Member
    Mar 20, 2006
    156
    How much components can the 300W SFX in the case support?
    The TFX 300W unit used in the SG05/SG06 was selected and tuned by SilverStone engineers for improved quietness and performance (300W continuous power at 50C). It has dedicated +12V rail for graphics card (16A, peak 19A) to provide more than enough power for any 9" long dual slot graphics cards. We actually do not recommend using off the shelf SFX PSUs at this time as they may not be designed to work well in the SG05/SG06 environment as we have done with the included unit.
    As a reference, here is a list of components used in the SG05 development system´╝Ü
    Intel Core 2 Quad 9550 95W CPU
    MSI IM-Q35 DO Industrial Mini-ITX motherboard
    Corsair TWIN2X2048-6400C5DX DDR2 memory
    *AMD Radeon HD4850 graphics card*
    WD Raptor 150GB + VelociRaptor 300GB 10,000rpm hard drives
    Slim Blu-ray drive
    *The Radeon HD4850 was the highest powered card that can fit inside the SG05 at the time of development (more than NVIDIA GTS 250, which is a dual slot design.)
    http://www.silverstonetek.com/qa/qa_contents.php?pno=SG05&area=usa
  7. fallout_man
    fallout_man Member
    Mar 20, 2006
    156
    hm is the 4870 the best card you can get to fit in this?
    the best nvidia i can find is 250 :(
  8. eklipze
    eklipze Member
    May 2, 2007
    842
    nevermind, fallout_man's post answered my question.
  9. quickshot84
    quickshot84 Member
    Jan 15, 2008
    925
    Melb, Vic
    wow. that is the most awesome little pc ive ever seen!
    how much did the mobo set you back?
    edit: nvm, 291 from mwave. pricey but you're making me tempted to sell my lanbox and build something smaller like that T__T
    Statts
    Statts RIP
    Aug 29, 2004
    2,504
    Radelaide, SA
    The only reason it is not listing some of the better cards is the PSU's lack of a second 6pin PCI-E power cable. Molex to PCI-E fixes that.
    You can fit anything up to 9.5" with power connectors on top, or 9" with power connectors on the end of the card. Other than that, there is a really easy mode involving cutting out the front of the metal section of the case (on the left of the 120mm fan) behind the front panel which gives you nearly another inch of space length-wise.
    Have read of a GTX285 installed this way.
  11. Dorz
    Dorz Member
    Jan 22, 2007
    1,817
    holy hell statts, upgrading again! looks sweet man.
  12. phantom220
    phantom220 Member
    Aug 29, 2007
    789
    Perth, Australia
    Wow, very impressive. Would be excellent for LANs I'd imagine. Could you post some temps when you get it together please?
    Statts
    Statts RIP
    Aug 29, 2004
    2,504
    Radelaide, SA
    More of a sidegrade LOL. mostly same components.
    Will do....
  14. GoofyHSK
    GoofyHSK Bracket Mastah
    Mar 3, 2002
    1,567
    Adelaide Hills
    bastard
    bastard
    bastard
    bastard
    bastard
    bastard
    bastard
    bastard
    bastard
    Statts
    Statts RIP
    Aug 29, 2004
    2,504
    Radelaide, SA
    OK, update time!
    Just finished putting it back together after installing the slim optical drive and the new heatsink. Didnt get around to shortening or sleeving any cables yet, will have to do that when I do the GPU heatsink.
    Anyway, pictures beat talking.
    The Gemini II installed on the board. Poor little thing gets dwarfed!
    Top view of the heatsink on the board.
    Really tight clearance between RAM and heatpipes. Forget changing RAM with heatsink in place. :lol:
    Installed in the case, you can see how big this thing is, but the best is yet to come.
    Clearance between HDD (left) and PSU (right) is minimal, but good news is the PSU has a 92mm fan sucking air through the heatsink.
    Reasonably happy with the cabling so far. At least everything is out of the way of airflow through the heatsink.
    Slim DVD burner installed. And home to where I hid all the wiring :lol:
    New front view with DVD burner.
    Next step is getting a cooler for the 4870 and undervolting the CPU in preparation for Summer (just to be safe).
    Statts
    Statts RIP
    Aug 29, 2004
    2,504
    Radelaide, SA
    Don't be hatin' :lol:
  17. Utetopia
    Utetopia Member
    Jun 18, 2004
    2,680
    BNE/TWMBA
    Awesome PC. How hot does the HDD get?
  18. Smashedcrab
    Smashedcrab Member
    Jan 22, 2009
    176
    Nice and compact:thumbup: will be keen to see what temps it runs?:confused:
  19. malloc
    malloc Member
    Dec 15, 2005
    529
    that is awesome. I can't believe how well that Gemini II fits - it's like it was made for it.
  20. quickshot84
    quickshot84 Member
    Jan 15, 2008
    925
    Melb, Vic
    lol. you've inspired me to sell my current lanbox (TT lanbox lite) and put something like that together :thumbup:
    Fantastic pics and lol @ the cooler, bigger than the mobo!
