MythTV General Discussion and Support
Discussion in 'Other Operating Systems' started by Dedge, Apr 10, 2007.
  1. Blinky
    Blinky Member
    Jul 4, 2001
    2,607
    Brisbane CBD
    Mythbuntu is both an instal or live use.
    http://cdimage.ubuntu.com/mythbuntu/releases/16.04/release/
  2. cvidler
    cvidler Member
    13,516
  3. Blinky
    Blinky Member
    Jul 4, 2001
    2,607
    Brisbane CBD
    Is shepherd still available?
  4. kreegor
    kreegor Member
    Apr 24, 2007
    4,995
  5. Blinky
    Blinky Member
    Jul 4, 2001
    2,607
    Brisbane CBD
    Anybody running their shiny new Raspberry Pi 4 as a backend?
  6. daehenoc
    daehenoc Member
    Nov 4, 2005
    2,564
    Mt Gravatt E, BNE, QLD
    Wow, really? There's that much power in them? Awesome.
    I finally got the new shepherd installed, it was trivial and I should have done it months ago, duur.
  7. cvidler
    cvidler Member
    13,516
    if you're not transcoding/ad detecting, there's not much grunt required, it's just writing an unmodified TS stream to storage.
  8. The Sentinel
    The Sentinel Member
    Jan 30, 2002
    2,795
    I'm having some fun (trouble) with Myth so thought I'd mention it on here in case someone had experienced something similar.
    Have been having some dropout issues and figured now would be a good time to do a fresh install and reload of DB. (Original install is from more tan 4 years ago)
    Reinstall went fine. DB restore went o.k. Config logs good back in Myth.
    When looking in the upcoming recordings however, there are no rules are listed.
    Also, I can longer press "S" on the guide to record things.
    I also appear to be unable start recording when I am watching TV, too.
    i.e. pressing the "S" button to convert the live-tv into a recording.
    Also if scheduling it as a recording, recording does not start.
    (This may not be related to the recording rules going missing but thought it worth mentioning here)
    If I run a select command against the "record" table then they all show up without issue.
    Have done a DB rebuild but no issues were found.
    Have also run the backend in debug mode but didn't see anything worthy of taking a second look.
    FWIW am running backend under Ubuntu Server 18.04 and MariaDB for SQL. Myth reinstall was save version (v30).
    Any ideas folks?
  9. HyRax1
    HyRax1 ¡Viva la Resolutión!
    7,918
    At a desk
    Did you remap your keys? I've always pressed R to record live TV.
  10. The Sentinel
    The Sentinel Member
    Jan 30, 2002
    2,795
    Sorry yep. That should be an R to record (S to bring up the guide).
    I originally thought it was just the key mapping not working.
    I then noticed that if you press the menu key when viewing the guide and go on and schedule a recording from there, nothing gets set and it doesn't show up on the guide with a letter indicating that program is set to or currently recording. (Typically an "R" in the program guide).
  11. HyRax1
    7,918
    At a desk
    That's... weird. Did a quick test on my 0.29 install and R is definitely working.
    Can you do any recordings at all? Maybe the key is working, but something is preventing recording in general? Permissions to the Recording table? Disk?
  12. The Sentinel
    The Sentinel Member
    Jan 30, 2002
    2,795
    Sorted it out.
    I'm embarrassed to say it was due to there being no EPG successfully loaded (Shepherd) since the DB was restored. (You can't press "R" to record something that has no EPG!!)
    Strange thing was that the guide initially appeared but after going back to it after posting here, it was gone.
    The kicker that made me realise what when I Saw that previous recording rules were there but no upcoming recordings were shown.
  13. HyRax1
    7,918
    At a desk
    It's always something simple. :)
  14. daehenoc
    daehenoc Member
    Nov 4, 2005
    2,564
    Hey all, can anyone recommend an antenna repair company in Brisbane? None of my digital TV or PlayTV tuners can get a signal, and the person I used to have my antenna installed eight years ago seems to have gone out of business!
    There are tons of antenna repair businesses around Brisbane, I would love to hear your experience with any of them!
  15. gmphoto
    gmphoto Member
    Jun 23, 2002
    113
    Brisbane, Australia
    Used these guys many years ago. They quoted over the phone, took a bit longer than he had thought but stuck to the original quote. They were excellent then but no guarantee they are good now but they still get good google reviews fwiw. In Red Hill.
    https://g.page/local-bloke-antenna-services?share
    My review
    https://goo.gl/maps/jJxvhBRMH6VrUaLeA
    daehenoc likes this.
  16. daehenoc
    daehenoc Member
    Nov 4, 2005
    2,564
    Played phone tag a bit, Brendon is coming this afternoon at 4pm!
  17. The Brad
    The Brad Member
    Apr 17, 2007
    5,011
    Sydney, for now?
    You won't be repairing an antenna, you might have yours re-oriented but more than likely replaced.
  18. daehenoc
    daehenoc Member
    Nov 4, 2005
    2,564
    You're right The Brad, the antenna didn't require repairing, but the booster had died and needed to be replaced!
    Brandon came right on 4pm, smashed out the job and was done! I recommend Brandon from "Local Bloke Antenna Services", he was great!
  19. treblid
    treblid Member
    Sep 6, 2004
    341
    Not sure what happened but having heaps of problems with VDPAU playback in the master branch for the past 3-4 months.
    So I replaced my aging two frontends (Q6600 and Core2D) with a AM6 Plus android box (replaced Q6600) and a Pi4/4GB (Core2D). It's amazing how things have miniaturized, become cheaper and more powerful in just a decade or so.
    The Pi4 with the ArgonONE case is simply amazing. This case appears to allow for a IR LED but I can't seem to find any documention/reference on how to do that yet.
    Still undecided if I should use the MythTV App or Kodi with the MythTV plugin. Love my new setup, and can finally do some uncluttering.
  20. Quadbox
    Quadbox Member
    6,397
    Does mythtv support nvdec? vdpau's kinda deprecated after all, ffmpeg's run way better with nvdec for quite a while now (especially for high bitrate 4k stuff using hevc or vp9)
