NBN UPLOAD speed issues?
Discussion in 'Networking, Telephony & Internet' started by Vo0do0, Jul 15, 2019.
  1. Vo0do0
    Vo0do0 Member
    Oct 6, 2003
    144
    Hey all,
    i apologize in advance if this is the wrong forums area.
    Since Thursday 11th - ive been noticdin upload speed issues on our NBN.
    We are Telstra FTTC 100/40 unlimited data
    First time i noticed it was after installing a new modem, I speed-tested to check this hardware and its showing 95-98 mbit down and 5mbit up.. almost like it is capped or throttled..checked everything obvious. QOS, cables etc.. finally assumed it was new modem related and plugged old one back in . . and getting the same result ..97down 5 up, isolated myself from the home network and still get 97 down 5 up.
    Isolated myself even more and bypassed everything and plugged into the NTD (white box thingy) and get 97down 5 up. tested directly from the NTD using a different computer and still get 97 down 5 up .
    Other people are having the same issue.. not just on Telstra. ABB also and Voda, but all are FTTC
    wondering if anyone has any further ideas i could try. . or where i could take this ..everything possible has been factory reset/ defaults. . nothing is helping.
    talking to Telstra is stressful/pointless. most of the monkeys in Philippines have no clue...the last guy i spoke to told me 5mbit is within their range of "acceptable speed" for a 40mbit upload speed.. i find that answer not only offensive but also un-acceptable ..
    We are on this particular speed tier not for the download speed but the upload speed....
    If i could get a 50mbit down 40 mbit up i would.
    Anyone shed any light on this ? or anyone else having similiar issues..
    Most of the other users having this issue are FTTC and Telstra customers..
    cheers
    V
  2. caspian
    caspian Member
    Mar 11, 2002
    10,262
    ping me your address details.
    [edit] hi all, for anyone reading, please note that this issue is specific to FTTC and does not affect any other technology.
  3. antman84
    antman84 New Member
    Jul 16, 2019
    4
    Yep! I am with Telstra FTTC in Adelaide and am having the same issues as you describe - except I am on the 50/20 plan (not 100/40) like yourself.
    Since around the 8th or 9th of July my uploads have been 5Mbps - previously were a respectable 18Mbps.
  4. caspian
    caspian Member
    Mar 11, 2002
    10,262
    can I ask how long you've had the service connected, and whether this has always been an issue, or if it started sometime afterwards?
  5. r8response
    r8response Member
    Jun 9, 2004
    6,446
    Sunshine Coast
    Seen this issue mentioned on Whirlpool a few times over the past week or so. Both Telstra and AussieBB people having upload issues with FTTC connections
  6. caspian
    caspian Member
    Mar 11, 2002
    10,262
    thank you for pointing that out.
    anyone else with similar experiences - sudden drop in FTTC upstream throughput - please reply, with ISP, location (suburb/town will do fine) and date you noticed.
    TIA.
  7. SpudBoy
    SpudBoy Member
    Jul 30, 2001
    5,286
    Under the Bed.
    AussieBB over HFC here. solid ~37-39Mbps upstream for me.
    I'd consider 5 to be absolutely unacceptable for both a 50/20 and a 100/40 plan. Realistically I would think ~15 and ~30 for each should be expected.
  8. antman84
    antman84 New Member
    Jul 16, 2019
    4
    Hi Caspian,
    Full details follow:
    • Telstra FTTC 50/20 customer since January 2019.
    • Since then averaging 47-48 Mbps download and 16-18 Mbps upload
    • Since Wednesday 10 July 2019, upload speed is consistently maxing out between 4.8 and 5.2 Mbps
    • Have tried:
      • Power cycling NCD
      • Power cycling Telstra modem (Smart Modem Gen 2)
      • Resetting NCD (using pin and ‘reset’ hole)
      • Factory resetting Telstra modem
      • Testing using TP Link Archer D7 modem
      • Plugging the NCD directly into my desktop PC
      • Tested all of the above over wifi (iPhone)
    • None of the above resulted in any change - each attempt and test gave 47-48 down and 4.8 - 5.1 up (approx)
    For full completeness, Telstra technician is coming tomorrow morning (17 July) between 8am and 12pm.
    Cheers!
  9. caspian
    caspian Member
    Mar 11, 2002
    10,262
    excellent, thank you.
  10. JSmithDTV
    JSmithDTV Member
    Jun 13, 2018
    2,891
    Algol, Perseus
  11. supasaiyan
    supasaiyan Member
    Nov 17, 2006
    4,516
    3000
    Any Telstra customers with this issue, pm your username
  12. voxace
    voxace Member
    Aug 9, 2002
    499
    North Coast, NSW
    This has been happening to me too on Foxtel 100/40 for the last few days.
    Vo0do0
    Vo0do0 Member
    Oct 6, 2003
    144
  14. antman84
    antman84 New Member
    Jul 16, 2019
    4
    Yes indeed. The NBN gods must be shining on me too.
    I am back up to my usual fast upload speeds. Just got 47.4 Mbps down and 18.4 Mbps.
    Thanks Vo0do0 - seems like your good luck rubbed off on me and my NBN.
    Vo0do0 likes this.
    Vo0do0
    Vo0do0 Member
    Oct 6, 2003
    144
  16. caspian
    caspian Member
    Mar 11, 2002
    10,262
    thanks for your help validating the fix, gentlemen. leave it with me. ;-)
  17. voxace
    voxace Member
    Aug 9, 2002
    499
    North Coast, NSW
    Mine is still playing up, sometimes I can't even post to message boards, upload photos etc. On speedtest I just got 95 download, 0.00 upload.
    Vo0do0
    Vo0do0 Member
    Oct 6, 2003
    144
    Hi Voxace
    Hang in there, sounds like theres a fix incoming if you are affected by the same issue
  19. caspian
    caspian Member
    Mar 11, 2002
    10,262
    in the meantime, ping me your service location details for an expedited fix.
  20. supasaiyan
    supasaiyan Member
    Nov 17, 2006
    4,516
    3000
    caspian what's the issue? out of curiousity
