Need a little help bidirectional LED supply to drive 3 pin LED
Discussion in 'Electronics & Electrics' started by MEX, Feb 11, 2018.
  1. MEX
    MEX Member
    Dec 23, 2001
    1,155
    Perth, WA
    I've got a small electronics problem that's beyond my knowledge.
    I'm swapping in a replacement AMP on a sub, the problem is the led supply on the board if for a 2 pin led that's bidirectional.
    The supply to the led is GND and then the other leg is either -1.7v or +1.9v
    This creates two problems the LED on the front of the sub needs to be brighter than these voltages supplied and the led itself is a 3 pin style led.
    I'm sure there is a fairly simple way with a few components to convert this signal into something that will drive the main LED. I can easily get + or - 12v from the internal PSU
    I'm sure someone with more advanced circuit knowledge would be able to solve this very quickly.
    Regards
    Luke
  2. _zak
    _zak Member
    Oct 12, 2009
    320
    Have you considered just buying a replacement bidirectional LED? There are plenty on Digikey if you search for bidirectional LEDs (example here).
    MEX
    MEX Member
    Dec 23, 2001
    1,155
    Perth, WA
    I had thought about that but their is not enough power voltage coming from the current LED to run the front LED at sufficient brightness or even turn it on.
    Cheers
    Luke
  4. Technics
    Technics Member
    Apr 29, 2002
    852
    Brisbane, AU
    You should be able to do it with a pair of external diodes. Essentially you make the LED part of a bridge rectifier with a shorted output (which is not an issue as current will be limited by the source). Exactly how to wire them depends on if the three pin LED is common anode or common cathode. I suspect the 1.7V and 1.9V measurements are down to the forward voltage of the red and green diodes. This voltage is not what is determining the brightness, that is determined by the current. If the brightness is insufficient you will need to decrease the value of the resistors that are limiting current.
  5. Technics
    Technics Member
    Apr 29, 2002
    852
    Brisbane, AU
    You will probably need to remove the exiting LED. It may have a lower forward voltage than the one on the front. If that is the case it will prevent any current from flowing in the new LED. A photo of everything you're trying to wire up would make helping much easier.
    MEX
    MEX Member
    Dec 23, 2001
    1,155
    Perth, WA
    Thanks for your input Technics,
    I don't have a photo unfortunately and I'm also unable to remove the existing LED due to it being behind a glued PCB.
    I was playing with some circuit software and I think its possible to create a simple circuit with a couple of transistors and resistors to sense the voltages on the existing LED and in turn switch the second LED on appropriately.
    Regards
    Luke
  7. Technics
    Technics Member
    Apr 29, 2002
    852
    Brisbane, AU
    In that case, yes you certainly can do it with transistors and resistors. You would still need to know if the 3 pin LED is common anode or common cathode to design the circuit though.
    MEX
    MEX Member
    Dec 23, 2001
    1,155
    Perth, WA
    Dam I forgot to check that on the LED, I suppose both circuits can be designed. They shouldn't be overly complex.
    Luke
  9. Technics
    Technics Member
    Apr 29, 2002
    852
    Brisbane, AU
    Something like this for common anode.
    For common cathode your swap the supply rails and the NPN for PNP and vice versa.
  10. Technics
    Technics Member
    Apr 29, 2002
    852
    Brisbane, AU
    This should work from a single +12V supply for common anode.
    Edited: Put the wrong one in the first time.
  11. rainwulf
    rainwulf Member
    Jan 20, 2002
    4,068
    bris.qld.aus
    Thats a pretty damn nifty circuit!
    MEX
    MEX Member
    Dec 23, 2001
    1,155
    Perth, WA
    This is great!
    Thank you for the input.
    Once I find some spare time I'll collect the components and see if I can build this!
    Regards
    Luke
