Need a monitor for trading
Discussion in 'Video Cards & Monitors' started by bondibro, Nov 22, 2017.
  1. bondibro
    bondibro Member
    Jan 18, 2017
    65
    redfern
    As the title states, I need some new monitors for day trading, I currently have a single 34" dell and need something with larger real estate. Looking for recommendations, I also play games (mainly shooters). I had my eyes on the 43" dell but not certain about it, so I am turning to you for recommendations.
    Cheers in advance
  2. havabeer
    havabeer Member
    Dec 12, 2010
    3,011
    Do you have a budget?
    So are you after separate monitors for the trading or are you after just 1?
    bondibro
    bondibro Member
    Jan 18, 2017
    65
    redfern
    I dont really have a budget, I could do 2, but I think I would prefer just a single really large screen.
  4. thedirkdiggler
    thedirkdiggler Member
    May 19, 2006
    336
    bondibro
    bondibro Member
    Jan 18, 2017
    65
    redfern
    Nice looks pretty good. although I think it may be too wide for my needs. I might go with the dell 43"
  6. havabeer
    havabeer Member
    Dec 12, 2010
    3,011
    what res is the dell? and what are your system specs
    bondibro
    bondibro Member
    Jan 18, 2017
    65
    redfern
    The dell is 4k monitor, model number is p4317q.
    My specs are -
    1950x
    64gb ram
    1080 ti
    2tb ssd
    wat are your thoughts?
  8. miicah
    miicah Member
    Jun 3, 2010
    4,682
    Brisbane, QLD
    I would go two monitors.
  9. power
    51,438
    with a 43" 4K screen you can split your screen into 4 1080P work spaces. But you're right a 2nd display is always nice, perhaps the OP is planning on keeping his old monitor?
  10. MR CHILLED
    MR CHILLED D'oh!
    Jan 2, 2002
    127,666
    Canadia
    How about a Philips 40" screen. Under 1K and a good general screen for most applications.
  11. havabeer
    havabeer Member
    Dec 12, 2010
    3,011
    Yep I can highly recommend the 40" (or 43") Phillips monitors. I would go two monitors, at least you can just have your trading stuff constantly up on one, and be doing what ever you want on the other, even playing games
  12. m0n4g3
    m0n4g3 Member
    Aug 5, 2009
    3,446
    Perth, WA
    phillips owner here. REALLY good monitor for the price. looks pretty good for gaming too, although still only 60hz @ 4k... but in saying that, there is no 4k @ 120/144hz yet.
  13. havabeer
    havabeer Member
    Dec 12, 2010
    3,011
    its the lack of g-sync is the only reason i still don't have one for gaming. got the predator 32" instead (largest 4k with g-sync)
    bondibro
    bondibro Member
    Jan 18, 2017
    65
    redfern
    I am looking to replace the 34" but could look to potentially keep it. I will look at a dual monitor setup, If I was going to do that I really want to find 'edge display' to minimize the border
  15. power
    51,438
    The Philips have a very small bezel. Not seen the Del but assume it's a Samsung or something.
  16. MR CHILLED
    MR CHILLED D'oh!
    Jan 2, 2002
    127,666
    Canadia
    Going for less than $500 in good condition you could pick up two and have an awesome setup.
    bondibro
    bondibro Member
    Jan 18, 2017
    65
    redfern
    Thanks, I'll take a look!
  18. DUS x SSJ4 x
    DUS x SSJ4 x Member
    May 16, 2017
    215
    Why not Stack two ultra wides on top of eachother?
    But the 43" doesnt look too bad.
  19. schmoove
    schmoove Member
    Oct 13, 2006
    709
    Asia
    dual portrait ftw!
  20. darkbastard
    darkbastard Member
    Sep 17, 2004
    335
    Duranbah - near Kingsclif
    I have both the Phillips 40" and 43" side by side and the newer IPS screen of the 43" is definitely worth the little bit extra. I often run 4 1920*1080 browser windows and all of them are readable even with my 50+YO nearly going blind eyes.
