Need a small PCB made
Discussion in 'Electronics & Electrics' started by crvee8, Jul 28, 2018.
  1. crvee8
    crvee8 New Member
    Jul 27, 2018
    3
    hi,
    I was wondering if anyone on here could please help me. I have a PDF file of a simple 2 tone oscillator PCB board that I would like, so I can build the circuit. Unfortunately it isn't a gerber file so I was wondering if anyone on here could either redraw the board or produce the board for me. I only need one board. Naturally I would pay for all costs incurred. I lack the technical skills required to redraw or produce the board myself, and I don't want to buy all chemicals and the PCB just to make one board. Hoping someone could help me out and I could email the PDF.
  2. CacTuar
    CacTuar Member
    Aug 28, 2005
    444
    Does your PDF show all the traces? You could try fritzing and give it a go yourself. It's really easy if it's a small / simple board.
    Then you could send the drawings to somewhere like dirtypcbs.com. They're pretty cheap and I've never had a problem with them.
    crvee8
    crvee8 New Member
    Jul 27, 2018
    3
    Hi, The PDF shows all the traces. I had a look at some software on the net but it appears a bit daunting to a beginner like myself.
  4. SLATYE
    SLATYE SLATYE, not SLAYTE
    Nov 11, 2002
    26,849
    Only one way to stop being a beginner...
    I use KiCAD (free/open-source) and once you get over the initial learning phase it's very straightforward to use. I've had boards made by Elecrow and JLCPCB (both because they were the cheapest I could find at the time) and they've been perfect.
    If you really don't want to learn how to do the PCB yourself, I'm happy to draw it up in KiCAD - but not this week. If you send me a PM on the 5th of August then I could have a look at it.
    crvee8
    crvee8 New Member
    Jul 27, 2018
    3
    Thanks for you kind offer. If I don't have any luck I will PM you after the 5th.
  6. heller44
    heller44 Member
    Jul 24, 2001
    833
    perth, SOR
    Does it need to be a pcb?
    For a one off, if it is reasonably simple, veroboard is the go.
  7. Paul west
    Paul west New Member
    Feb 27, 2020
    7
    Hi Bloke.. Are you still able to do a small board drawing. Im pushed for time and don't have the ability to learn the program in the time frame I have, cheers Paul.
  8. blankpaper
    blankpaper Member
    Feb 1, 2013
    1,138
    Maybe a good idea to take your mobile number out of the post.
  9. Paul west
    Feb 27, 2020
    7
    thx
  10. ShadowBurger
    ShadowBurger Member
    Feb 19, 2008
    1,942
    pm me your pdf and ill see if it's something I have time to whip up for you. i can either send it off to be made for you or send you back the gerber to get made yourself
  11. SLATYE
    Nov 11, 2002
    26,849
    Feel free to send me a PM with the specs, but it'll have to be a very small PCB because I'm working on my own PCB currently.
  12. Paul west
    Feb 27, 2020
    7
    HI, I have a small circuit board that I need a gerber file for. Any chance of being able to draw one up plz? cheers
  13. ShadowBurger
    ShadowBurger Member
    Feb 19, 2008
    1,942
    Yes:
  14. Paul west
    Feb 27, 2020
    7
    Hi,, did the pdf come through ok? Is it possible to do anything with it? Happy to compensate for the time used..cheers
  15. ShadowBurger
    ShadowBurger Member
    Feb 19, 2008
    1,942
    I haven't got a PM from you
  16. Paul west
    Feb 27, 2020
    7
    ahh. sent an email. just trying to work out how to put a file in here.
  17. Paul west
    Feb 27, 2020
    7
  18. Paul west
    Feb 27, 2020
    7
    howdy. how is the best way to get the pdf and photos into a pm to you? regards Paul
  19. ShadowBurger
    ShadowBurger Member
    Feb 19, 2008
    1,942
    click on my username
    go start a conversation
    I don't know where you sent an email to...
