Need advice on replacing radiator fan on my Gigabyte 1080ti waterforce
Discussion in 'Video Cards & Monitors' started by Ap0c, Jan 2, 2019.
  1. Ap0c
    Ap0c Member
    Apr 29, 2003
    1,079
    Melbourne, 3136
    https://www.gigabyte.com/Graphics-Card/GV-N108TAORUSX-W-11GD-rev-10-11#kf
    So it would appear the bearing in my graphics cards AIO watercooling fan is toast as the fan is making loud rattling noise. I want to replace it so I pull the cover off the gpu to see if I could just unplug the fan and plug a new on in but the 4 pin connector is merged with the pump power as well. https://imgur.com/gallery/loe815W
    Is it easy to feed the pump wires into a new fan header? I’ve never played around with rewiring fan headers before.
    Or does anyone have another idea to replace the fan? Thanks in advance
  2. havabeer
    havabeer Member
    Dec 12, 2010
    4,187
    Email gigabyte, see if they'll just give you a new fan. If you explain the situation they may even rma it for you for free (if out of warranty)
  3. straiton
    straiton Member
    Feb 12, 2003
    417
    most fans have a little rubber/plastic seal plug that is under a sticker.Dig the plug out add a few drops of oil and refit.
  4. AstinGC90
    AstinGC90 Member
    Nov 6, 2013
    581
    FNQ
    Pretty sure those things have a 4 year warranty so you almost certainly are covered.
