Need advice
Discussion in 'Newbie Lounge' started by Bayden, Feb 15, 2020.
  1. Bayden
    Bayden New Member
    Feb 14, 2020
    9
  2. havabeer
    havabeer Member
    Dec 12, 2010
    5,381
    have you looked up some PC shops and priced up the individual components your self to see if the price is ok?
  3. cbjaust
    cbjaust Member
    Sep 11, 2003
    1,199
    go for a Ryzen 7 3700X based system.
  4. cbjaust
    cbjaust Member
    Sep 11, 2003
    1,199
    it's compromised on storage speed and mainboard quality and it's a dead end platform. you're better off going for a Ryzen 7 3700X based system.
    Bayden
    Bayden New Member
    Feb 14, 2020
    9
    ok thank you for the advice
    Bayden
    Bayden New Member
    Feb 14, 2020
    9
  7. philquad
    philquad Member
    Jan 22, 2004
    1,080
    nelson bay
    Bayden
    Bayden New Member
    Feb 14, 2020
    9
    Thank you for your help
    Bayden
    Bayden New Member
    Feb 14, 2020
    9
  10. philquad
    philquad Member
    Jan 22, 2004
    1,080
    nelson bay
    dunno, that just shows mine, its up to you, im not the best guy for it, im just showing options, like do you need a $700 graphics card ? this 1 i cheaped out a bit, & no windows included, should check with shop before you buy if its all compatible, eg. motherboard,cpu, ram ? is psu enough ? shopping around can save bucks too. Screenshot_2020-02-16 The Shopping Cart PC Case Gear(1).png
    Bayden
    Bayden New Member
    Feb 14, 2020
    9
    Thank you so much for your help I think I’ll go with a amd Ryzen 7 with a 2070 graphics card for my build
