need FREENAS help
Discussion in 'Troubleshooting Help' started by ae00711, Nov 20, 2018.
  1. ae00711
    ae00711 Member
    Apr 9, 2013
    1,281
    probably should go in storage subsection, but my problem is not really HDD related.... I think.
    put together a freenas box (running latest version):
    Xeon X3450
    Supermicro X8SIF mobo
    4x 4GB ECC+REG
    Intel SSD for OS
    2x 2TB hitachi in mirror
    everything was running fine for a few hours, started transferring files over to mirror (don't worry, I have bu), now the stupid thing isn't connected to network supposedly. Can't login, transfer was interrupted. NIC activity lights say it's ok, plugging in a monitor to rig shows no error messages etc.
    Is there some kind of dumb power saving feature that has kicked in?
    I have no idea where to start :(
    ae00711
    ae00711 Member
    Apr 9, 2013
    1,281
    ha! in my internet travels I stumbled across a user experiencing similar issues... turns out it is/was a power saving feature that I enabled in BIOS. Changing it back solved everything
