Need Help for Youtube Covers!
Discussion in 'Musicians' started by shanetsh, Oct 25, 2012.
  1. shanetsh
    shanetsh Member
    Jul 24, 2010
    257
    So basically, i've been trying to do some covers and bought a pretty decent mic and sound interface..
    However i cant seem to get the EQ and compression right for my vocals..
    Any suggestion where i can learn more about this?
    here's my test run on a cover:
    http://www.youtube.com/watch?v=db3__34cEhU
    please like and share if you like it!
  2. krappo
    krappo Member
    Aug 25, 2008
    807
    Little Island
    very Nice :) :thumbup:
    shanetsh
    shanetsh Member
    Jul 24, 2010
    257
    thanks man.. its my first recording with this setup..
    i srsly dont know how to fine tune it.. hopefully some gurus here can help and shed some light into this.. XD
    shanetsh
    shanetsh Member
    Jul 24, 2010
    257
    bump... pls help me out here guys
  5. ea_recoil
    ea_recoil Member
    Aug 17, 2002
    532
    Sounds fine to me! Listened though Yammy MSP5's at work.
    I'm sure there's plenty of guides out there to help shape your vocal sound but I don't think there's any real right or wrong way to EQ vocals.. its just whatever you think sounds best against the rest of the mix
  6. BigandY
    BigandY Member
    Apr 1, 2003
    8,155
    There's a bit of clipping in there, and you need to compress it more.
    Did you apply any reverb or is that the natural resonance of the room? I don't like it - you're sitting next to a big ole' glass wall which won't help. Can you hang some cloth or curtains over the glass?
    edit: Listen to your cover of Georgia on my Mind and then this one - this recording sound quite flat & tinny in comparison. Again, tighten the compression up and fiddle with the EQ. Have you gated it at all? I would suggest it.
