Need help with new WC build!
Discussion in 'Extreme and Water Cooling' started by MIC89N, Oct 6, 2021.
  1. OP
    MIC89N
    MIC89N Member
    Jan 12, 2012
    46
    I’ve got the latest bios. Yes my flow direction and flow rate is good. Don’t have another gpu I’ve sold them.
    MIC89N
    MIC89N Member
    Jan 12, 2012
    46
    Here are some shots of the system
    jekel likes this.
  3. Will S
    Will S Member
    Aug 15, 2003
    6,261
    Coniston (Wollongong)
    very nice looking system but nice is not good enough when its not working ...ouch
    The Flt240 has output from centre and input from ( looking from front ) the right port , it looks like you have output in the centre port unless you have a reverse flow ie. flt240 to top rad to cpu to gpu to bottom rad to flt240......
    If memtest fails then somehow get your hands on a cheapo GPU ( no waterblock and run softtube ( or is you have hardtube left) run from bottom rad to cpu ) . About the only way is to isolate these problems by swapping parts
    You have the flow right for the CPU which means you are running flow in a clockwise run so would check the flt 240 out
    MIC89N
    MIC89N Member
    Jan 12, 2012
    46
    Thanks for the detailed response mate. So I’ve got the outlet to top rad > cpu > gpu > bottom rad > inlet of res. Is that not the correct way? The black ek zmt tubing runs to the top rad in the back on the case.
  5. Wacko02
    Wacko02 Member
    May 26, 2003
    1,050
    A hard shutdown like that, and not being able to restart straight away kinda points to a power issue of some sort IMO. Maybe start with some cable checks and potentially even borrow a spare PSU to test it out with? Also check that the PSU fan is working and getting airflow to it.
  6. The Beast
    The Beast Member
    5,137
    Definitely sounds like a PSU issue. I had a Corsair 1200 that would occasionally trip when triggered by a specific load on the GPU (1080Ti at the time), really hard to detect why. I my case certain explosions in Rocket League would cause a hard power off. There was clearly heaps of headroom on the PSU, and it was a good model, just had an issue. Eventually (18 months or so) the PSU just popped one day and was dead (4 years old total). I got a new one (under RMA) and haven't had an issue since.
    MIC89N
    MIC89N Member
    Jan 12, 2012
    46
    Memory test passed. Yeah I might see if I can test another psu put. The Beast what do you think of my loop layout any issues?
  8. woja
    woja Member
    Feb 18, 2004
    680
    What's the hotspot temperature like? I'd still think either PSU issue, whether it's to do with the PSU itself or maybe one of the cables is not fully seated or damaged and making it shit the bed when it's drawing power
    MIC89N
    MIC89N Member
    Jan 12, 2012
    46
    When you say Hotspot temperature what part of you referring to sorry.
    MIC89N
    MIC89N Member
    Jan 12, 2012
    46
    The PSU seems completely fine temp wise and the fans working well. I've taken off the cable mod pcie and 24pin power extenders for the moment to see if they are the issue. I've got an 850w Corsair I might try if this fails, hopefully not as the cpu power plug is fiddly.
  11. juzz86
    juzz86 Member
    Nov 15, 2013
    2,245
    Forth, NW TAS
    I'd swap over to the Corsair at your next hard shut mate - fans running and PSU temps won't really show you what's going on, that comes from monitoring your voltages and currents :thumbup:
    Usually you've run into an inbuilt protection if you need to cycle the hard power switch on the back of the PSU to resume operation. Could be over-voltage, over-temperature or over-current - which it shouldn't be, as you're good for about 83A on the 12V rail in the SFX-L 1000W.
  12. Will S
    Will S Member
    Aug 15, 2003
    6,261
    so you have it counterclockwise .......so it looks right
    Had a Silverstone Premium 1000 and its now good for running the pump when I set up a cooling loop.......it wasn't reliable
  13. woja
    woja Member
    Feb 18, 2004
    680
    Hotspot on your 3090. Sometimes it could indicate the mount not being so great
    MIC89N
    MIC89N Member
    Jan 12, 2012
    46
    I've done that now. See what happens. The only other thing i could think about i have the LianLi fan controller taped to the blank side of the PSU.
    MIC89N
    MIC89N Member
    Jan 12, 2012
    46
    I have the Asus 3090 EKWB edition. So you would hope it's all good. I've heard the memory on the back of the card can get quite hot.
  16. woja
    woja Member
    Feb 18, 2004
    680
    Install HWinfo and check it in comparison to the GPU Core temperature
    MIC89N
    MIC89N Member
    Jan 12, 2012
    46
    Had it installed, didn't have a look closely enough to see those gpu temps. Thanks man. Currently Lost Ark is playing and that's what I am getting.
  18. woja
    woja Member
    Feb 18, 2004
    680
    Temps look fine!
    MIC89N
    MIC89N Member
    Jan 12, 2012
    46
    Yeah, i honestly think it's something to do with the PSU or the case shorting it. I'm just going to leave it on with the Corsair for a while and see. If that's the case I'll just open a warranty on the PSU. Frustrating as i was playing around with Bios settings for ages, thinking it was the CPU.
  20. Will S
    Will S Member
    Aug 15, 2003
    6,261
    Usually happens with cheap PSU's but the one you had wasn't cheap.
