Need help with Sounds
Discussion in 'Troubleshooting Help' started by baby_ute, Jun 12, 2019.
  1. baby_ute
    baby_ute Member
    Oct 25, 2008
    521
    Sydney, Eels Territory
    Hi guys got a Zotax X58 that i just got of a mate and i am only getting sound from microphone playback only, no so sound from window booting ETC.
    Thing i've tried;
    install realtek driver from MB website
    Update reaktek drivers
    Uninstall realtek and reinstall driver(both with new and old)
    Using DDU to remove realtek and let window self fine a driver(still no sound) then install realtek again
    Update window to current updates and repeat all set above.
    Is there anything left to tried? any help is appreciated
  2. havabeer
    havabeer Member
    Dec 12, 2010
    4,638
    I had a lightning storm take out the sound on a mobo of mine once. A $2 usb sound card from eBay fixed it.
    In the actual app are you setting the ports as actual speaker out puts?
    pwlm1975 likes this.
  3. pwlm1975
    pwlm1975 Member
    Apr 18, 2016
    349
    Logan, Qld
    Got to agree with havabeer, my personal experience with the older boards is that when things start to go, sound is often one of the first things. Get a cheap sound card and see if it works OK.
    baby_ute
    baby_ute Member
    Oct 25, 2008
    521
    Ya its detect the port, getting sound bar indicator just nothing out of the speaker
    Okay, ill try and fine a sound card, its just odd that i get sound from mic playback and no sound from nothing else
  5. pwlm1975
    pwlm1975 Member
    Apr 18, 2016
    349
    Logan, Qld
    Is that from the rear audio or the front case audio?
    baby_ute
    baby_ute Member
    Oct 25, 2008
    521
    rear ports
