need help with WD raptor
Discussion in 'Overclocking & Hardware' started by Gaddo, Jul 19, 2011.
  1. Gaddo
    Gaddo Member
    Jul 21, 2010
    23
    hi guys i bought a brand new WD raptor 600 gb Today and i am having problems
    my system is a i7 920 gax58a-udr3 850w ps gtx560ti SLI 12G RAM
    now i have been running a 64gb solid state drive for 14mth no problem's but room was becoming an issue.
    i disonnected every think ssd extra drive ect then connected raptor installed windows installed motherbaord driver and then started to install nvidia drivers at differnt points i get the blue screen memory dump thingy
    i have tried everythink put OC back to normal tried differnt sata cables tried differnt sata port's every think my mat said it sounds like a hard ware failer but when i reconnect my solid state boom not a problem oc running what ever i ask of it bc2 game prime anythink.
    i have formatted and reinstalled window 4 time what could this problem be need help
    thanks in advance Gaddo
  2. Airquarious
    Airquarious Member
    Aug 31, 2001
    1,801
    Galaxy near you!
    Try a different NV driver.
    Gaddo
    Gaddo Member
    Jul 21, 2010
    23
    on a couple of reinstalls i hadnt even got to the drivers being installed and it was doing it?
  4. Airquarious
    Airquarious Member
    Aug 31, 2001
    1,801
    Galaxy near you!
    OK. So, windows install goes good? Only when you try to install other things then it goes bad?
    Gaddo
    Gaddo Member
    Jul 21, 2010
    23
    well yer kind of, one of the times it was doing it after i had installed things the other time before i had done anythink im relly confussed as if there was anther problem then surely it would do it wth my normal solid state drive
  6. Airquarious
    Airquarious Member
    Aug 31, 2001
    1,801
    Galaxy near you!
    Gaddo
    Gaddo Member
    Jul 21, 2010
    23
  8. Airquarious
    Airquarious Member
    Aug 31, 2001
    1,801
    Galaxy near you!
    Did you install a printer driver?
  9. Airquarious
    Airquarious Member
    Aug 31, 2001
    1,801
    Galaxy near you!
    Do you have a printer connected?
    Gaddo
    Gaddo Member
    Jul 21, 2010
    23
    I do have a printer but it is wireless and i had not installed it yet i did plug a western digital external hard drive in each time to get some drivers ect and when i plugged it in three things tryed to auto install 2 passed one failed could that be it even though i have unplugged them windows may be trying to open it whats your thoughts ??
  11. Airquarious
    Airquarious Member
    Aug 31, 2001
    1,801
    Galaxy near you!
