SOLVED Netgear Nighthawk M2 networked to a switch?
Discussion in 'Troubleshooting Help' started by slavewone, Jun 13, 2019.
  1. slavewone
    slavewone Member
    Jul 9, 2002
    1,923
    B.Mtns2774 Status:Unhappy
    I’m trying to add wired network ports to a Netgear Nighthawk M2 by adding a switch, router, I don’t mind, I’m prepared to buy it.
    I’ve googled and googled and there doesn’t seem to be an exact answer with so many people having no luck and some having it just work.
    Can someone give me a solution that will just work?
  2. zippo87
    zippo87 Member
    339
    Bray Park QLD
    to run a wired network on my night hawk , i have to turn it off plug the network cable in then turn it back on , only way it will pickup the wired network
  3. CAPT-Irrelevant
    CAPT-Irrelevant Member
    Sep 7, 2007
    6,144
    Apparently this model is relatively new to the market, less than 6 months old. What are the odds it could have a locked down firmware?
  4. power
    58,494
    a switch will just work, don't use a router.
    slavewone
    slavewone Member
    Jul 9, 2002
    1,923
    Would I have any extra luck with a travel router to share it to a switch if the switch doesn’t “just work”?
    I’ve tried an old tplink modem in both the wan and regular ports with/without the dhcp on. Didn’t have high expectation, wasn’t disappointed.
  6. Sphinx2000
    Sphinx2000 Member
    Sep 16, 2001
    7,507
    The Nighthawk is a modem + router already, just connect to a switch and any connected ethernet devices should also get an IP address via DHCP and then Internet access.
    slavewone
    slavewone Member
    Jul 9, 2002
    1,923
    Thanks for the encouragement. The possibility of locked down firmware had me spooked.
    Trailed with the dumbest switch I already own- Netgear XAV1004 and it works! Now have encouragement to buy something.
