Networking/ethernet issue
Discussion in 'Networking, Telephony & Internet' started by dahurldog, Mar 26, 2018.
  1. dahurldog
    dahurldog Member
    Jul 9, 2001
    2,510
    gold coast
    Hi guys
    So I have spent the day trying to work this out but no luck.
    I've got a billon 7800DX and it connects via ethernet cable to a TP-Link SG1008D and a unifi connect AP LR.
    The 7800 connects to the ADSL and my computer plugs directly into it.
    The wifi for the billion has always been fine but lately the ethernet has been all over the place. Today I can unplug everything from the modem except my computer - everything is fine. If I plug in my one connection after the other - the ethernet stops working after a small period of time (1-10minutes).
    During that time, I can connect to the billion wifi and all is normal.
    I did a hard reset of them modem today - same issue remains. I've changed the ethernet ports around etc. No change
    Any thoughts??
    dahurldog
    dahurldog Member
    Jul 9, 2001
    2,510
    gold coast
    Not sure if it could be my computer?
    But if I can use the wifi without any issues and it's purely the ethernet - it's unlikely to be an IP issue right?
  3. fredhoon
    fredhoon Member
    Jun 27, 2003
    2,726
    When it stops working does the link physically drop (no light or constant disconnect / reconnect on the PC)?
    Can you get an IP and access the internet via wifi when the wired port is being flakey?
    Have you tried a different Cat5/6 cable?
    If wireless works but the wired connection to your PC doesn't and you've ruled out a specific router or switch port, I'd troubleshoot the cable next and then the NIC on your PC.
  4. Pugs
    Pugs Member
    Jan 20, 2008
    9,415
    Highbury, SA
    Swap it to the switch if you can...
    Age of computer/ check drivers update if necessary...
  5. splbound
    splbound Member
    Feb 23, 2004
    538
    London / Sydney
    IP address conflict? Are all your devices getting IP's from one single DHCP server? Are any of your wired wireless devices set to use a fixed IP that may conflict with one assigned in your DHCP server range.
    ir0nhide likes this.
    dahurldog
    dahurldog Member
    Jul 9, 2001
    2,510
    gold coast
    So we had a powerout last night, woke up and everything was sweet then same issue after 15 mins.
    I downgraded the billion firmware and moved the plugs around and was sweet again for about an hour.
    Just knocked out again.
    So can use wifi but every device connected via ethernet stops working (computer, switch, wireless AP).
    I don't think anything has a fixed ip - I've never set one
  7. Pugs
    Pugs Member
    Jan 20, 2008
    9,415
    Highbury, SA
    sounds like the 7800 is dying....
  8. Aetherone
    Aetherone Member
    Jan 15, 2002
    8,852
    Adelaide, SA
    How old is the Billion? If its more than a couple of years, I'd bet it will come good with a re-capping.
    dahurldog
    dahurldog Member
    Jul 9, 2001
    2,510
    gold coast
    Recapping?
  10. Aetherone
    Aetherone Member
    Jan 15, 2002
    8,852
    Adelaide, SA
    Replacing the electrolytic capacitors inside the unit. Cheap badly sealed (or badly made) caps age over time and fail. Lots of modem/router devices are not well ventilated which means they run hot and cook the caps to death.
    I've resurrected 1/2 dozen devices with the same symptoms simply by replacing the cooked caps.
  11. cvidler
    cvidler Member
    14,419
    That's fine if you can DIY, if not, it's MUCH cheaper to go by a new device (unless the replacement cost would be thousands$).
  12. Nobby6
    Nobby6 Member
    Oct 25, 2017
    149
    S.E.Q
    must be ruddy old modem :) poor quality eleccies usually dry out after min 10 years, but i guess if its located in a furnace, might dry out sooner :D
  13. Aetherone
    Aetherone Member
    Jan 15, 2002
    8,852
    Adelaide, SA
    Yeah, I'd not want to pay someone to do it, but modems are usually sub-$10 of parts and an hour or less of beer time. Much simpler PCBs and many fewer big power filtering caps than motherboards.
    ROFL, at the peak of the capacitor plague we were seeing brand new boards arriving with caps already swollen, split and leaking.
    https://en.wikipedia.org/wiki/Capacitor_plague
    dahurldog
    dahurldog Member
    Jul 9, 2001
    2,510
    gold coast
    I have borrowed an Asus modem and it seems be going ok.
    Will leave it a day or two before I call it and say the modem is dead and order a new one - but I suspect that will be what I do next.
    I live in an area with a long distance to the exchange, but I do have FTTC coming in the next 6 months (we will see). I believe the boardcom chipset are the best for long distances? I got a better sync speed with my billion than the asus - any cheap varities with the boardcom chipset that will be good with NBN too?
  15. ir0nhide
    ir0nhide Member
    Oct 24, 2003
    4,519
    Smells like something else might be present on the same IP address or maybe 2 DHCP servers.......
  16. TRG.dOinK
    TRG.dOinK Member
    Jun 27, 2002
    4,608
    Melb East
    Sounds like the modem has had it.
    We had a TP Link AC1750 Archer D7 partially die after 2 years. We started to get random disconnects here and there, shortly after it started happening more frequently, and usually had to power cycle the blaming thing to get the connection back. So technically it still works but only until a certain point in time, by the end it was doing it 2-3 times a day. Couldn't find the receipt as it came with a 3yr warranty as well, still sitting in a box / cupboard. Edit, probably should of googled, seems to be a common problem (linky)
    Now using the standard Telstra T-Gateway modem that no one wants, working fine, just no QOS to limit the upload bandwidth and the WiFi isn't as fast.
  17. Nobby6
    Nobby6 Member
    Oct 25, 2017
    149
    S.E.Q
    guess I've been lucky, though I've only been doing electronics since 1978
