New/First WC build, Lian Li 011
Discussion in 'Extreme and Water Cooling' started by Rod M, Nov 10, 2018.
  1. juzz86
    juzz86 Member
    Nov 15, 2013
    915
    Forth, TAS
    It might be a fair pump mate, just a bit of an unknown. The circuit board is definitely different to a true D5, from these photos. The ceramic bearing shaft is also a different shape and shorter than in the true D5.
    You'd get a second-hand D5 in the forums here around that price :thumbup:
    Rod M likes this.
    Rod M
    Rod M Member
    3,270
    Rod M
    Rod M Member
    3,270
    Build has started
    Rod M
    Rod M Member
    3,270
    Res is in.
    juzz86 likes this.
    Rod M
    Rod M Member
    3,270
    Rod M
    Rod M Member
    3,270
    MB and gpu are in. Just planning the pipe layout.
    Rod M
    Rod M Member
    3,270
    I got this 980ti second hand with no instructions and no markings on the block. I assume the bottom point is the line in?
    Rod M
    Rod M Member
    3,270
    Almost done.
  9. SSJ4
    SSJ4 Member
    May 16, 2017
    578
    Looking good mate!
    Rod M
    Rod M Member
    3,270
    It's Alive :)
    juzz86 likes this.
    Rod M
    Rod M Member
    3,270
    All working well.
    No leaks and seems to be cooling well.
    In bf5 CPU sits at 51deg and gpu at 43deg.
    980ti is a decent little bump against the r9 290 I had before. Can oc it to 1482mhz
    juzz86 likes this.
  12. juzz86
    juzz86 Member
    Nov 15, 2013
    915
    Forth, TAS
    Looks tidy mate, lovely work. Clear tube/res offsets everything nicely :thumbup:
    Rod M likes this.
  13. aa1320
    aa1320 Member
    Jun 15, 2009
    61
    you are smart that not doing 360 rad at side. There is a stupid bracket that used for front panel cable management blocking the radiator and I had to cut mine one to fit the Alphacool radiator. I have no idea how Lian Li claims it would fit 360 rad at default.
