New System for Overclocking
Discussion in 'Overclocking & Hardware' started by Citgo, Sep 10, 2018.
  1. n2p4u
    n2p4u Member
    Oct 1, 2003
    1,234
    Why not an AMD B450 and AMD 2600 / 2700 processor?
  2. pwlm1975
    pwlm1975 Member
    Apr 18, 2016
    360
    Logan, Qld
    Why?
    Yes of course that card will work under DX11, it just gets better performance from DX12 under certain criteria.
    Citgo
    Citgo New Member
    Sep 5, 2018
    10
    I'm getting the Intel Core i5 8500 3.0GHz 8th Gen. I just found out that the RAM is also not compatible with the CPU as well.
  4. pwlm1975
    pwlm1975 Member
    Apr 18, 2016
    360
    Logan, Qld
    RAM is not dependent on a CPU, it's dependent on the motherboard chipset. Where did you get that information from?
  5. adamsleath
    adamsleath Member
    Oct 17, 2006
    14,130
    Sunnybank Q4109
    pwlm1975 likes this.
  6. pwlm1975
    pwlm1975 Member
    Apr 18, 2016
    360
    Logan, Qld
    To add to adamsleath's post above, whatever RAM you get will work - I've never looked at a QVL, and never had a RAM issue with an Intel system. AMD's Ryzen series has improved compatibility with Series 2, but overclocking stability may be affected by RAM choice. This will not be an issue with your Intel build.
    A B360 or a H370 moherboard will allow your RAM to run at 2666MHz maximum, regardless of whether you buy 3000MHz RAM. It's a limitation of the chipset, not the CPU.
    If you want to run RAM above 2666MHz, you will need to buy a Z370 motherboard, which has capability to run RAM faster than 2666MHz.
    In short: RAM standard speed on the Skylake, Kaby Lake and Coffee Lake platform is 2133MHz. a B360 motherboard will allow you to run RAM at a maximum of 2666MHz (check manufacturer's details). A H370 motherboard will allow you to run RAM at a maximum of 2666MHz. A Z370 motherboard will allow you to run RAM above 2666MHz.
    Citgo
    Citgo New Member
    Sep 5, 2018
    10
  8. Starky
    Starky Member
    Apr 26, 2014
    19
    Tasmania
    That website is garbage and should be ignored.
    pwlm1975 has provided you with sound advice.
  9. adamsleath
    adamsleath Member
    Oct 17, 2006
    14,130
    Sunnybank Q4109
    just a pc builder site..a number of them use the word compatible...it is ddr4 i spose...
  10. M1ck1
    M1ck1 Member
    May 2, 2018
    19
    Ipswich Qld
    Hi Citgo
    As everyone has said, you are unlikely to have problems with RAM and Intel chipsets
    here's a link to Corsair's web site and the vengeance LPX you mentioned
    CMK8GX4M2A2666C16
    https://www.corsair.com/ww/en/Categories/Products/Memory/VENGEANCE®-LPX-8GB-(2x4GB)-DDR4-DRAM-2666MHz-C16-Memory-Kit---Black/p/CMK8GX4M2A2666C16 under specifications it says compatible with Intel 300 series chipsets Corsair tests it, the motherboard maker can't test every kit. If it were an AMD chip The QVL list is the best way to go.
  11. Mr B
    Mr B Member
    Oct 27, 2015
    31
    Any particular reason for this?
    You should be able to use your win7 key to install win10. I did this on a new build recently with an oem key.
    Citgo
    Citgo New Member
    Sep 5, 2018
    10
    I think the free upgrade to Windows 10 already ended. Let me do a hard search.
  13. dasa2
    dasa2 Member
    Feb 5, 2003
    686
    Northern VIC
    Considering your tight budget and wanting to OC I would go with Ryzen 2600.
    It may not be as fast as a overcloked 8600k but it will outdo a i5 8400.
    You can also use stock cooling with the 2600 which will keep the VRM cooler than most aftermarket cooling options.
    https://www.techspot.com/review/1627-core-i5-8400-vs-ryzen-5-2600/
    RAM speed is the best way to get the most out of your CPU as in most games I have found that overclockign Samsung b die beyond 3200c14 brings me higher performance gains than overclocking the CPU itself and the two together stack up to a very noticeable performance increase if you come across a CPU limited section of gameplay.
    Overclocking RAM can be a very slow and tedious posses to get the most out of it by comparison overclocking the CPU is very simple.
    Officially it has been for some time but last i checked it still works.
