SOLVED No 2K/4K avail on 6500XT issue
Discussion in 'Troubleshooting Help' started by vladtepes, Feb 9, 2025.
  1. vladtepes
    vladtepes Member
    Sep 30, 2015
    3,703
    Brisbane, Qld
    My dad just bought a new monitor and the system is telling him the best available resolution is 1920x1080.
    I looked at his system specs and can't see why it can't get higher than that, up to 4K.
    I would have expected it to default to 3840 x 2160.
    System is:
    MOBO: MSI MAG B660 TOMAHAWK WIFI DDR4
    CPU: Intel Core i5-12400F
    GPU: AMD Radeon RX 6500 XT
    Monitor: Samsung 32" ViewFinity S70D UHD Monitor
    Connection via HDMI.
    O/S: Windows 10
    I can't see any inherent incompatibility or reason for the resolution issue.
    I think he used the old HDMI cable so I suggested he find and try the new one which came with the monitor.
    I am hopeful this will fix it.
    If it doesn't are there any suggestions as to what he can try?
    Thanks.
  2. danyell
    danyell Member
    Jan 20, 2003
    2,014
    Kilsyth, 3137
    Display port cable instead?
    vladtepes
    vladtepes Member
    Sep 30, 2015
    3,703
    Brisbane, Qld
    He doesn't have one but I may have a spare so I'll try that.
  4. Agg
    Agg Lord of the Pings
    Jun 16, 2001
    35,366
    A Reported Post Near You
    Standard HDMI cables support 1080i. "High Speed" HDMI cables are needed above that. My bet is on the old cable being, well, old.
    https://www.hdmi.org/resource/cables
    The Standard HDMI cable is designed to handle some earlier consumer applications, and is tested to reliably transmit 1080i or 720p video. Most of these cables have been replaced by the High Speed HDMI Cables but there are still some in the marketplace and consumers should note while fine for some uses, they don’t support the later resolutions, refresh rates and bandwidth requirements.
    danyell and VirtualNinja like this.
    vladtepes
    vladtepes Member
    Sep 30, 2015
    3,703
    Brisbane, Qld
    Yep the HDMI cable solved it.
    Cheers all
    vladtepes
    vladtepes Member
    Sep 30, 2015
    3,703
    Brisbane, Qld
    How do I mark as solved?
  7. Agg
    Jun 16, 2001
    35,366
    I can edit the thread and add the tag.. and have done so now. :) Glad to hear it was an easy fix.
    vladtepes likes this.
    vladtepes
    vladtepes Member
    Sep 30, 2015
    3,703
    Brisbane, Qld
    As an aside I saw my own TV recognised as 60Hz (it's 120Hz native in specs) - seems I have an HDMI2.0 cable and need an HDMI 2.1.
    I'll double my refresh rate and probably not even notice :)
  9. danyell
    danyell Member
    Jan 20, 2003
    2,014
    Kilsyth, 3137
    gaming you will!
    i went back to 60hz, no vrr/g-whatsit temporarily recently; my oh my it sucked
    my son's cheapie monitor at 100hz vrr is amazing vs 60hz vsync on or off, on any monitor
    144/165 is the tits, the e-sports oriented monitors at 360+ must be insane
    OCMunkee likes this.
