SOLVED No reason BSOD's ?? every boot ?! help
Discussion in 'Troubleshooting Help' started by crocodaVe, May 29, 2015.
  1. crocodaVe
    crocodaVe Member
    Dec 9, 2011
    534
    ACT, 2600
    Hi fellas,
    Built a year ago. this one
    SSD boots Win7 ultimate. quick boot gadgets, wi-fi, LCD & CCC.
    OK. when I'm using it.
    Any or none screensavers will blue screen dump on re-awake.
    Got it set at 10mins power saver both. tried arranging power save options but no good. Same crash.
    crocodaVe
    crocodaVe Member
    Dec 9, 2011
    534
    ACT, 2600
    All at stock. no clocking.
  3. C-BuZz
    C-BuZz Member
    Jan 24, 2002
    5,122
    Melb, East
    I'm struggling to understand your typing & what's going on in general. Can you just clarify exactly what's happening ?
  4. power
    60,976
    what's in the event logs relating to the crash?
  5. O-B-E-L-I-X
    O-B-E-L-I-X Member
    Jul 11, 2008
    962
    SYD, 2036
    Try to update the M/B BIOS and Firmware on the SSD, had this happen on some laptops with some SSD's, usually, older ones. Perhaps adjusting/changing the sleep S1, S3 ect. state might fix this...
  6. RyoSaeba
    RyoSaeba Member
    Sep 11, 2001
    12,577
    Bad RAM. Trust me on this one. :thumbup:
  7. power
    60,976
    I'd back this diagnosis. :thumbup:
    crocodaVe
    crocodaVe Member
    Dec 9, 2011
    534
    ACT, 2600
    ram is now g.skill 2x4. 2133mhz. thanks fellas will check.
  9. Akh-Horus
    Akh-Horus Member
    Feb 8, 2008
    10,806
    Western Vic
    Mem test results?
  10. Bold Eagle
    Bold Eagle Member
    Jun 28, 2008
    9,767
    Also with BSOD try and run either BlueScreenView or WhoCrashed and show us the output. Just cut and paste the "Crash Dump Analysis" into the thread.
  11. Paulie_AU
    Paulie_AU Member
    Nov 29, 2013
    3,465
    Not sure about your issue but I followed your link to your build and found the link to acrylics online who end up being just near me it seems... so thanks for posting.:thumbup:
    crocodaVe
    crocodaVe Member
    Dec 9, 2011
    534
    ACT, 2600
    Problem solved. It was a power save option. - turn screen off after 10 mins.
    disabled that and all is good. I just stick with a screensaver as it's not on for more than 2 hours a day. Thanks for all your help :thumbup:
    -- champion acrylic place too Paulie. Glad you found 'em
  13. qwertylesh
    qwertylesh Member
    Aug 21, 2007
    8,700
    Is it only screentimeout that causes it or screentimeout when paired with resume from S3 sleep?
    Resume from S3 instability surely would be a bios issue, are there no updates for that msi model?
    crocodaVe
    crocodaVe Member
    Dec 9, 2011
    534
    ACT, 2600
    Exactly right! Updated bios and sorted the S3. Timeout resumes now. :)
  15. qwertylesh
    qwertylesh Member
    Aug 21, 2007
    8,700
    awesome, now its properly solved, no workarounds :thumbup:
  16. O-B-E-L-I-X
    O-B-E-L-I-X Member
    Jul 11, 2008
    962
    SYD, 2036
    This is what I have suggested ~12 days ago...;)
  17. power
    60,976
    good fix, makes you wonder what they changed to make it not shit the bed.
    Reminds me of the bad old days where BIOS updates down clocked RAM due to instabilities.
  18. qwertylesh
    qwertylesh Member
    Aug 21, 2007
    8,700
    makes you wonder yeah.
    sometimes you can figure out what it was specifically borking based on the kernel panic stop code.
    whether it was resuming with unstable memory settings, or a bad clock/multi value, or not resuming stable disk access.
    at least its fixed up now, just do a checkdisk post-fix and your golden. :)
    crocodaVe
    crocodaVe Member
    Dec 9, 2011
    534
    ACT, 2600
    Fully right. Should have listened.
  20. callan
    callan Member
    Aug 16, 2001
    4,850
    melbourne
    Possibly related: I had 2 machines (both Core2 duos) which would not resume from sleep/hibernation once I'd installed an SSD - and in both instances they would crash with the PC speaker beeping hard on. One was an ASUS all in one PC, the other a Dell inspirion notebook. BIOS updates were not available for either, and I just lived with it. (disabled sleep & hibernate, and just shut them down when not in use)
    Curiously, though the problem did not occur if imaged the disk to a physical hard disk and ran an HDD instead, and both were perfectly happy on SSD's once I upgraded them to Windows 8.1 (from Windows 7)
    Hmm.
    Good to see the OP has fixed the problem.
    Callan
