noctua d14 highish temps
Discussion in 'Overclocking & Hardware' started by desudesu, Nov 22, 2011.
  1. desudesu
    desudesu Member
    Oct 23, 2008
    532
    Sydney 2111
    hi guys
    just wondering i have tried mounting the noctua in different orientation exhaust up instead of front to back.
    but even with this my temps seem to idle around 45 on idle i find this a bit high on days when its about 25 ambient. under load about 60 which i find is ok but im just not sure if im getting the paste on correctly.
    i tried out the smudge the paste over the heatsink before attaching to the MB.
    oh i forgot to mention this is with HT off in bios so if that was one it would be higher.
    any ideas on how i should fix this before i think of moving to WC.
    thanks
  2. Madengineer
    Madengineer Member
    May 27, 2011
    14,354
    hmmm. 60 under load is pretty good......tbh, i wouldnt be concerned about the 45degree idle.....and it all depends how many volts your pumping through it, and the max recommended volts.
    desudesu
    desudesu Member
    Oct 23, 2008
    532
    Sydney 2111
    atm i think im only setting about 1.2v in the bios but i get a reading of about 1.18v in cpu-z.
    so the voltage is a bit low while the temps still stay up there.
    i have no idea but oh well might think of going to the xspc kit but ill have to see how hot the summer will get this system to.
  4. Copie
    Copie Member
    Jul 24, 2009
    13,868
    Newcastle
    Those temps are pretty good, assuming its the rig in your sig.
    Idle temps honestly mean diddly squat, most people who have low idle temps have speedstep enabled, meaning its downclocked to nothing when at idle.
    Going to water wont really gain you much at all.
  5. fang_laluna
    fang_laluna Member
    Sep 5, 2009
    1,183
    That's quite a good temp for 4 ghz dude. Mine went to 70ish @ 4GHz with 1.25vcore.
    desudesu
    desudesu Member
    Oct 23, 2008
    532
    Sydney 2111
    oh my bad forgot to change my sig,
    but yea ive done the overclock now to 4ghz and its about 76 max by using prime, but not sure how stable it is did a 10min prime so i can use the computer for now.
    vcore now is 1.275 in bios but only 1.248 using LLC1
    atleast i got rid of the problem with the random freezing overnight
  7. pittster
    pittster Member
    Mar 25, 2011
    1,010
    Newcastle
    Yeah its not insane temps just make sure fans are spinning at 1200-1300rpm
    I get idle temp of 28deg @1.00V 1.6Ghz & full load prime 60deg @1.31V 4.4ghz
    If i didn't have speed step on my idle temps would be higher.
    A E8500 i had with a zalman 9700NT running at 4Ghz daily @1.3V idled at near 40 deg and it did that for 3 years straight so i wouldn't worry to much you have one of the best air coolers around.
    desudesu
    desudesu Member
    Oct 23, 2008
    532
    Sydney 2111
    i am finding it that either the location of the case being under my desk just doesnt let all the hot air escape from the case quick enough. but i tried 4ghz before and never primed it or anything and the computer ran fine with only 1.25v in bios. but the moment i prime it BSOD so i guess it had some issues.
    gonna see how the computer handles itself over the hot summer days.
  9. AUST_DeVinE
    AUST_DeVinE Member
    Nov 9, 2010
    559
    Townsville
    poor case circulation is one massive problem.
    idle CPU should only be 5 deg hotter then room ambiant, but if the air in your case isnt flowing fresh then you will see what your seeing now.
    take the side of your comp and point a pedistal fan at it and see what happens
