Noisy Power Causing Problems
Discussion in 'Electronics & Electrics' started by Xxian.com, Nov 10, 2006.
  1. Xxian.com
    Xxian.com Member
    Mar 16, 2006
    115
    I recently got a 2.4GHz wireless security cam for the house, but as our whole town is on a generator with noisy power, the picture from the receiver is crap, jumping flickering and scrolling.
    It is plugged into a UPS which is on a surge protector - is there anything else I can try to overcome the problem?
  2. nux
    nux Member
    Jan 20, 2002
    16,780
    I wouldn't think noisy power would cause that, the camera would regulate the AC power to DC at 12V or something.
  3. JetspeedCamry
    JetspeedCamry Member
    Dec 26, 2005
    223
    Is there any 2.4GHz networks in the area?
    My little wireless camera's do they same unless I shut down my network.
    Xxian.com
    Xxian.com Member
    Mar 16, 2006
    115
    Both the camera and receiver have separate plugpacks that converts to 8v DC. There is no other wireless anything running in the entire town (besides UHF radios).
    I speculate that it is the power as I noticed while watching tv later last night the same flickering going on, but only just barley visible.
  5. nux
    nux Member
    Jan 20, 2002
    16,780
    Won't have anything to do with power then. Must be interferance from another 2.4GHz source, or it is just a dodgy wireless camera/receiver. You aren't watching the camera on this TV that flickers are you? Tried moving the camera closer?
  6. wabbit
    wabbit Member
    Sep 9, 2003
    406
    Some cordless phones use that band as well. AV senders also. Could be interference from one or more of them.
    Xxian.com
    Xxian.com Member
    Mar 16, 2006
    115
    I didn't think of them, but again, there are only 2 of them within 1km of the camera & receiver - both mine, so I wouldn't think that would be the problem.
  8. LethalCorpse
    LethalCorpse Member
    Mar 23, 2003
    3,760
    Cambridge, Massachusetts
    Noisy mains could cause that sort of flickering, but it's more likely to be RF interference from microwaves, fluoros, etc. You can try getting a power board with a built in mains filter (as opposed to surge protection) as they will remove any RF noise on the AC line.
