not many USB ports?
Discussion in 'Overclocking & Hardware' started by Sledge, Sep 2, 2018.
  1. Sledge
    Sledge Member
    Aug 22, 2002
    7,462
    So why is it in this day and age, that quite a few mobos still only have like 6 USB ports?
    Everything plugs in to them these days, so why don't even the cheapest ones have like 12 or more ports?
    When i upgrade next i'll be wanting something with at least that many so i don't have to piss fart around to plug something in..
  2. Ratzz
    Ratzz Member
    Mar 13, 2013
    7,607
    Cheltenham East 3192
    I think those most likely to want a bunch of USB ports are running NAS instead. The manufacturers cater to the market, there is only so much PCB real estate to work with I guess.
    Those that do use a lot of USB devices generally just buy a hub anyway, most devices are low demand or only used sometimes, its not like a hub really maxes a port out often anyway.
  3. waltermitty
    waltermitty Member
    Feb 19, 2016
    814
    BRISBANE
    What's the hubbub about buying a hub?
    Bold Eagle likes this.
  4. Copie
    Copie Member
    Jul 24, 2009
    13,289
    Newcastle
    Why do you have so many USB devices? You should have like 4, keyboard + mouse, external audio (optional) and microphone.
    Sledge
    Sledge Member
    Aug 22, 2002
    7,462
    Messy with even more cables laying around...
    and external HDD, Camera, phone, joystick, USB stick (x2 if you're going from one to the other), Card reader, fanatec wireless receiver, probably more i'm forgetting...
  6. pwlm1975
    pwlm1975 Member
    Apr 18, 2016
    299
    Logan, Qld
    Why not buy a 5- or 6-port USB hub and stick it into your PC (assuming your case has 5 1/4" drive bay to accommodate one)? Surely your camera, external HDD, USB storage isn't plugged in 24/7 or used frequently at the same time?
    Front ports for USB storage (sticks) and card reader as required (my USB card reader is only plugged in when required).
    Maybe a PCIe USB card instead of you want more ports at the back. These days the board makers have to accommodate USB3, USB-C, DP, HDMI, Optical and component audio and others I can't remember. Maybe the ATX standard needs to look at the I/O size to allow more.
  7. havabeer
    havabeer Member
    Dec 12, 2010
    4,325
    don't you have to have enough lanes to supprt 12 devices all plugged in at once.
    really you could have 12 SSD's hanging off that bad boy expecting it to power and copy data in and out of it.
  8. caspian
    caspian Member
    Mar 11, 2002
    9,622
    why does my new laptop only have 2 USB ports??
    Sledge likes this.
    Sledge
    Sledge Member
    Aug 22, 2002
    7,462
    Good question!!
    That's ridiculous for a laptop to only have 2
    maybe for a tablet that might be ok.. but not a laptop
  10. Hater
    Hater Member
    Nov 19, 2012
    3,092
    If it was a new $5000 Apple laptop, you'd get... 1 :)
  11. power
    56,711
  12. cvidler
    cvidler Member
    11,682
    pov laptop, I've got 4 :p
    3 type-A, and a type-C (which replaced the miniDP, which I'm not happy about, got to get a port-multiplier/dock thing to get a DP port back).
    But yeah, as covered OP needs to shop around to find the board that meets with the requirements he has, they are out there. Not all of them will be ports on the back, many will be headers on the board to plug into either case ports or addon (5.25" bay devices).
  13. caspian
    caspian Member
    Mar 11, 2002
    9,622
    Dell 7390 i7... at least it has a USB-C I can connect a hub to.
    Sledge
    Sledge Member
    Aug 22, 2002
    7,462
    Yes majority available now have only 4-6 with only a few having more...
    when i'm ready to upgrade i will check out the current crop... (need GPU first)
    And that chart is showing maximum it supports.... not how many are actually on the board.
  15. power
    56,711
    start with chipset then look at corresponding boards.
    that said, i've never seen anything with a ludicrous amount of USB ports.
  16. melatonin
    melatonin Member
    Dec 13, 2012
    357
    Comp sitting at my feat has 12 USB total, 4 on the front, 8 on the rear, but it's an old comp, i5 650.
  17. Tazor
    Tazor Member
    May 23, 2010
    2,169
    Canterbury, 3126
    I use 2 USB ports on my PC. 1 is for an external Hub mounted on the side of my desk for more convenient access and cable management, the other powers my DAC.
  18. Ratzz
    Ratzz Member
    Mar 13, 2013
    7,607
    I have two USB 2, used for wired keyboard and wireless mouse. I have 3 USB 3.0, one has a charge/data cable for my phone hanging out of it, the other two are unused currently. I have a USB C port, unused.
    For quick plugins, I have a pair of USB 3.0 on the front panel.
    I could of course run external drives or whatever from the 2 spare IO ports, or a 4 port hub I have in the drawer... or buy a hub with many more ports if I really needed it of course.
    I see no need for more USB ports.
  19. cvidler
    cvidler Member
    11,682
    Ratzz has spoken.
    /invariance\ likes this.
  20. self_slaughter
    self_slaughter Member
    Dec 12, 2010
    1,393
    4165
    Crosshair VI hero comes to mind if you must have a bootload of rear usb ports directly on the motherboard.
    God knows how the lanes etc are split up to support that and what else you lose out on because of it though.
    Edit: Looks like there's only one usb header for a 2xfront panel usb ports, So everything has to be done from the back... but could be handy if you aren't constantly swapping plugs and just want everything in all the time.
    OJR and Sledge like this.
