NVIDIA GeForce RTX 30 Series | RTX 3090 3080 3070 3060 3050 | Discussion
Discussion in 'Video Cards & Monitors' started by Sphinx, Sep 1, 2020.
  1. Locutus of Borg
    Locutus of Borg Member
    May 14, 2003
    113
    Queanbeyan, NSW
    My PCCG eBay 3080 Xtreme Order just got cancelled...GRRRRR
  2. raincloudx
    raincloudx Member
    Dec 18, 2007
    2,109
    Victoria
    Oh FFS that sucks, guess PCCG didn't mean to put the listing up?
  3. Locutus of Borg
    May 14, 2003
    113
    Queanbeyan, NSW
    "The seller cancelled this order because: I'm out of stock or the item is damaged.
    They sent a refund to your original payment method"
    Well, in good news, my Alienware monitor has shipped.
  4. pH@tTm@N
    pH@tTm@N Member
    2,305
    BRISBANE
  5. lithos
    lithos Member
    Oct 2, 2010
    6,530
    Yeah!
    Lotta crossover between architect and ID - hell, those old guys like Frankie Lloyd and Ivanoff (the Sandgroper Modernist!) used to design the furniture that was to go into their houses. But fuck it, someone who's reasoning and justification for their design is more than "I love greebles".
    Those Singularity cases are borderline taking the piss, too. "Billet"? Well, yes, I guess technically 4mm thick sheet stock could, in the strictest sense, because considered "billet". Like how one of those pre-sliced sandwich slices of Coon could, technically, be considered a "block" of cheese. And that's what Singularity appears to be doing. They're just using sheet aluminium...just very thick sheet aluminium. It's still all bolted together when it needs to turn a corner.
    Same goes with their machining - yes, it's CNC, but it's only one-axis, by the look of it: straight down, at one angle. It's not anything that couldn't be done with a stamp or punch.
  6. Locutus of Borg
    May 14, 2003
    113
    Queanbeyan, NSW
    pH@tTm@N likes this.
  7. jekel
    jekel Member
    Jul 24, 2004
    1,014
    man that sux, wonder if any buyers will get them from those sales....
  8. The Beast
    The Beast Member
    5,138
    I've been looking at it for the past couple of hours, seriously considered it to save the effort of me having to block my FTW3 Ultra (when I get it).
    Problem is, it's basically a $600 for waterblock.... on a 2x8pin card.... with no resale value to non-custom water cooling folk.
    If I could flip my FTW3 Ultra for $1600 it might be worth it, but I would feel like a mongrel doing that, so I won't.
  9. azz
    azz Member
    Nov 23, 2002
    3,884
    Heidelberg, Melbourne
    The block design looks much simpler than the better blocks out there, only worth it if you want the bling...
  10. afcca
    afcca Member
    Jul 16, 2003
    1,427
    The Bottom of a Fish Tank Near You
    So, my 3060ti arrived today. Did a fresh driver install using DDU.. and I haven't gotten a huge gain over my GTX970 in the primary two games I play - Overwatch and WoW, both sitting around 70fps in 1440p which is pretty much the same as what I had before at the same settings strangely enough. WoW has been pretty all over the place since Shadowlands launch of course with it's updated textures and all that and did sometimes dip quite low, but I was kind of expecting a bit more from a 5 year upgrade when the card isn't even using 50% loading and the cpu isn't hitting 20% either.
    (5820k for reference)
    Skramit likes this.
  11. The Beast
    The Beast Member
    5,138
    3060Ti should get you between 2080 Super and 2080Ti performance at 1440p. Something else going on if you can't see a change compared to a GTX970!
    Edit: If the GPU is at 50% load you might want to check there isn't something else limiting. Vsync? Framerate limiter?
    combatant3219 likes this.
  12. elcarter1
    elcarter1 Member
    Feb 24, 2007
    860
  13. mesaoz
    mesaoz Member
    Jan 15, 2015
    8,381
    South East QLD
    if your GPU isn't going past 50% load you probably have a frame cap operating somewhere - if you have overwatch set to 60hz or on a 60hz display it's default setting will cap you at 70fps
  14. MR CHILLED
    MR CHILLED D'oh!
    Jan 2, 2002
    162,432
    Omicron Persei 8
    3070 series shortages according to Gamer Meld.
    Timestamp start: 5:07
  15. metalrain
    metalrain Member
    Aug 24, 2008
    2,769
    Adelaide, SA
    Ayyy, after nearly about 5 emails back and forth, I finally got my COD BLOPS CW game code. EVGA wanted an actual tax invoice, no need for a picture of the box.
    AdamMB23 likes this.
  16. MR CHILLED
    MR CHILLED D'oh!
    Jan 2, 2002
    162,432
    Omicron Persei 8
    Is that all? I had to provide scans of not only that but the barcode on the back of the card and also a picture of the entire back of the card.
    metalrain likes this.
  17. th3_hawk
    th3_hawk Member
    Jun 4, 2005
    2,605
    Kilsyth 3137
    I've just moved up to 3440 x 1440 for my gaming monitor and the 2060 Super doesn't do too badly, but my son's 1060 6GB is starting to let him down. The plan at this point is to hand down the 2060 Super and upgrade my card (since I'm paying for it and all :p ).
    The 3060Ti seemed to be the obvious choice but reviews are a little all over the place in recommending it at this sort of res and the jump to a 3070 isn't much more and is probably worth it... but then the 6800XT comes in as a competitor at that price too.
    Mind you, this is all theoretical for now since you can't really buy any of them right now anyway. Plan B is to keep an eye out for a 2080 Super as someone else upgrades at a decent price... but if a 3060Ti matches the 2080 Super it's likely to be at about the same price.
  18. Luno
    Luno Member
    Aug 5, 2020
    576
    The reference 6800xt aib’s are that price point but not the regular aib’s being more in the 1300-1700 price point in line with 3080’s. As far as the 3060ti it does seem to be in line with the 2080 supers possibly even close to 2080ti
  19. Spyder6052
    Spyder6052 Member
    Nov 15, 2006
    1,264
    Woodroffe NT
    good to see "some" manufacturers lifting their game..... MSI on the other hand....
  20. metalrain
    metalrain Member
    Aug 24, 2008
    2,769
    Adelaide, SA
    Oh screw that. If I had to pull out my GPU for that, I would have just given up :wired:
    MR CHILLED likes this.
