NVIDIA GeForce RTX 30 Series | RTX 3090 3080 3070 3060 3050 | Discussion
Discussion in 'Video Cards & Monitors' started by Sphinx, Sep 1, 2020.
  1. MR CHILLED
    MR CHILLED D'oh!
    Jan 2, 2002
    162,450
    Omicron Persei 8
    Head, nail, hit. Yeah and that was actually what happened to me, ah fuk, gotta take it out now! :lol:
    metalrain likes this.
  2. metalrain
    metalrain Member
    Aug 24, 2008
    2,770
    Adelaide, SA
    In my situation, I would have to unplug EVERYTHING and un-screw the GPU brace/bracket from the whole system and do some yoga to gently twist and pull it out. What would normally take about 30 seconds to remove for normal cases is a 15 minute job for me.
    MR CHILLED likes this.
  3. wintermute000
    wintermute000 Member
    Jan 23, 2011
    2,565
    I reckon stretch for the 3070 unless power/thermals/space is an issue and if you're happy with a 2080 Super then obviously not. As a 2060 Super / 1440p owner as well, I don't think the leap to a 3060Ti would be enough.
  4. th3_hawk
    th3_hawk Member
    Jun 4, 2005
    2,605
    Kilsyth 3137
    That's what I'm thinking too, but I need to upgrade the 1060 so it's either another second hand 2060 Super if I can find one or spend a little more and pass my 2060 Super down.
    Or to put it another way, would you spend ~$350 or so to upgrade a 2060 Super to a 3060 Ti ?
  5. wintermute000
    Jan 23, 2011
    2,565
    If you put that to me in 2016 I would have laughed but this is the post-Turing pricing era..... lol
    Well if you need it now then you don't have much of a choice
  6. ashenIC
    ashenIC Member
    Sep 21, 2019
    187
    Pre-ordered. Now the wait.
  7. metalrain
    metalrain Member
    Aug 24, 2008
    2,770
    Adelaide, SA
    What you go for?
  8. ashenIC
    ashenIC Member
    Sep 21, 2019
    187
    EVGA 3080 Ultra. Not my first pick, but...
    heslo and metalrain like this.
  9. FatBoy
    FatBoy Member
    1,170
    Gold Coast
    At stock high 70s
    undervolted 65.
    coming from a 1080ti that ran
    60ish degrees, this is hot.
  10. metalrain
    metalrain Member
    Aug 24, 2008
    2,770
    Adelaide, SA
    From what I can see, unless you're going to for the $1,700+ units, there are more and more EVGA GPUs popping up in people's hands more than any other RTX 3080. With releases like these, we don't really have much of a choice of which specific GPU we can get our hands on.
    ashenIC likes this.
  11. Phido
    Phido Member
    Jun 20, 2003
    7,766
    Dark City
    Doubtful of 6800xt reference at $1050 happening for most people.. Looks like stock may be able to fill back orders, may... Most likely new deliveries will be AIB and they are at the same price as the 3080 AIB boards $1200-$1400. The 6800's do occasionally appear. Again, I wouldn't bet on reference 6800 staying around long at RRP.. You might get lucky and buy from someone who just wants to sell to cover costs.
    Reference designs will fade away quite quickly. AIB will be more expensive.
    3060ti is about as fast as a 2080 super? The issue with that is is better at things like ray tracing, but isn't really fast enough to use it usefully. DLSS might help with the extra res.... If you can grab a $650-$700 3060ti IMO thats a reasonable deal, would be a reasonable upgrade.
    Luno likes this.
  12. Maco88
    Maco88 Member
    Oct 21, 2010
    229
    Was that during gaming or a Timespy [ or similar] run???
  13. afcca
    afcca Member
    Jul 16, 2003
    1,427
    The Bottom of a Fish Tank Near You
    I've checked the framecap stuff and everything's turned off that I can see, it does jump up to over 100fps in certain areas and in others I've noticed the GPU load does actually go up to 99% but the framerate doesn't go below 57ish. The Monitor is a 60hz display so that might be the overwatch case but I couldn't really find any settings in there about that. I had a quick look in an old version of 3DMark that I still have installed from forever ago that I ran not long ago which brought the 970 to below 20fps on one test and the 3060 crushes it at over 90fps so there's definitely a big improvement in the card, I'm just kinda surprised there isn't a bigger jump in frames.
  14. jjjc_93
    jjjc_93 Member
    Jul 3, 2009
    3,971
    The 5820k is a haswell CPU from 2014.. If you are not utilising the whole GPU that might be why mate. 20% utilisation of a 6 core cpu does sound extremely low for modern titles (my 5900x will often enough hit that) but I am not familiar with overwatch or wow metrics. Try running 3dmark and check the graphics test score against others with similar GPUs to see if its being used properly there. A 970 to a 3060ti should be night and day.
  15. self_slaughter
    self_slaughter Member
    Dec 12, 2010
    1,801
    Yeah, total percentage is a completely useless cpu metric. If the GPU aint running at or damn near 100%, something else (most likely cpu, or frame limiter) is holding it back.
    Think of it like this, With 12 logical cores, Maxing out one thread (in this case, say the main game thread everything else waits on) would only read as like 8% cpu usage, yet leave the GPU doing nothing as the rest of the game can't go any faster anyway.
    For a laugh, tomb raider (2013) shows 3% cpu usage during a benchmark with a 5950x at 4.5GHz. 300-520 fps with a 1080ti at 1080p. rofl
  16. karun
    karun Member
    Nov 8, 2011
    137
    I'm not even going to bother buying a new one anymore since I can still play most games with a Nvidia 1080.
    nope likes this.
  17. metalrain
    metalrain Member
    Aug 24, 2008
    2,770
    Adelaide, SA
    Should be fine if you're not interested in RT.
    nope likes this.
  18. nope
    nope Member
    May 8, 2012
    4,262
    Tipshitswitchitin Queeersland
    https://twitter.com/GoFlying8/status/1335856080711110658
    MSI Chinese mainland factory was stolen, stolen 40 boxes RTX3090, the total value of 2200000RMB ......
    MSI has been officially announced and informed to the police ,Reward of 100000 RMB for reporting effective information.
    hahahah holy fuck some madmen lifted half a million dollars of shit gpus!?
    Luno likes this.
  19. self_slaughter
    Dec 12, 2010
    1,801
    We can't scalp em directly, so we'll just say they were stolen, claim insurance AND scalp them anyway. WINNING! $$$$$
    nope likes this.
  20. metalrain
    metalrain Member
    Aug 24, 2008
    2,770
    Adelaide, SA
    nope, devolutionary and Trizae like this.
