NVIDIA GeForce RTX 30 Series | RTX 3090 3080 3070 | Discussion
Discussion in 'Video Cards & Monitors' started by Sphinx2000, Sep 1, 2020.
  1. chook
    chook Member
    Apr 9, 2002
    3,789
  2. Gibbon
    Gibbon grumpy old man
    Jun 30, 2001
    6,297
    2650
    Confirmed ETA = I can confirm you'll get your card before 2025.
    (maybe)
    FatBoy likes this.
  3. The Beast
    The Beast Member
    4,013
    Just so you know, Sony are using liquid metal (of some sort) on every single Playstation 5. I'm sure there are some combinations that are incompatible, but it's not like liquid metal itself is the problem. This is not too dissimlar to using mixed metals in a watercooling loop (like mixing AL with CU).
  4. chook
    chook Member
    Apr 9, 2002
    3,789
    I think it is to do with the IHS as opposed to the actual chip itself.
  5. nCrypt
    nCrypt Member
    Feb 12, 2010
    2,280
    i have always used liquid metal when delidding my intel cpu's, between the die and ihs.
    Have never used it on a GPU before, never seen anyone else use it either. only in cpu delid's
    Most use Thermal Grizzly Kryonought Thermal paste for GPU, and between IHS and cooler.
  6. clackersx
    clackersx Member
    Sep 3, 2013
    16
    Usually on professional/factory uses of liquid metal, they would apply some kind of "diffusion barrier" to copper as well as an actual physical barrier around the sides to prevent "leakage" such as the foam carrier on the PS5 APU, I expect that the PS5 would have a patch of gold or nickel plating on the heatsink.
    Using liquid metal on bare copper kind of sucks, requiring preparation/multiple applications. Liquid metal was used on some 2008 Mac Pro's (Mac Pro 8X), IIRC they used gold as a diffusion barrier on the processor/heatsink and a grease as a "leakage" barrier (prob just dielectric grease).
    stroggos2k likes this.
  7. macktheknife
    macktheknife Member
    Jul 26, 2005
    1,564
    One tip I've seen people use is a small amount of regular thermal paste in a square around where the liquid metal goes.
  8. The Beast
    The Beast Member
    4,013
    I think you're far better off using a varnish (clear nail polish works) around the die to prevent any overspill creating conductivity where it shouldn't. I did this on my 6700k just to be sure, so far so good. Also my temps dropped like crazy, like 30%.
    combatant3219 and macktheknife like this.
  9. Evasive
    Evasive Member
    Mar 22, 2002
    375
    Do ya come from a Land Down Under...
    Stop being so bloody level headed, and get into the drama of it all!
  10. The Beast
    The Beast Member
    4,013
    ZOMG you're right! NVidia cancelling unannounced rumoured SKUs can only mean one thing.... 40Gb 200CU Big Navi confirmed!
  11. Evasive
    Evasive Member
    Mar 22, 2002
    375
    Mind, I always thought that about the '20gb' 3080.
    Zero sense quotient in RAM numbers so close to the 3090.
    16gb 3080 - now that might make sense... big enough increase to appeal to gamers & creators, and also compete with AMD, yet still leaving the 3090 a healthy EP margin.
    Also might be somewhat more reasoned in price, but then again - this is Nvidia, so...
  12. Evasive
    Evasive Member
    Mar 22, 2002
    375
    THERE you are :D
  13. macktheknife
    macktheknife Member
    Jul 26, 2005
    1,564
    Just did a benchmark with rtx on vs off. Did an average of 77 with RTX On and 106 with RTX Off. The minimum was 55 with it on vs 84 with it off. I couldn't tell the difference in the graphics quality tbh.
  14. Frag
    Frag Member
    Feb 22, 2002
    5,141
    https://www.guru3d.com/news-story/nvidia-might-cancel-geforce-rtx-3080-20gb-and-rtx-3070-16gb.html
    Probably better article. And wouldn't say a nothing story, Nvidia is clearly having issues - perhaps and hopefully they will make these cards on TSMC 7nm node -> 3080TI
  15. nCrypt
    nCrypt Member
    Feb 12, 2010
    2,280
  16. macktheknife
    macktheknife Member
    Jul 26, 2005
    1,564
    perhaps a 7nm, non-X memory 16gb 3080 Super card might fit the bill?
  17. nCrypt
    nCrypt Member
    Feb 12, 2010
    2,280
    for 5-10% faster then a 8nm X mem 10GB 3080, knowing nvidia, that card would be $2k-2.5K
    really wouldnt make much sense.
    What would make more sense, is a 3090 Ti, that is 10-15% faster then a 3090, and drop 8nm 3090 to 2.2k, and sell the 3090Ti for 2.8-3.1K
  18. PiNoY
    PiNoY Member
    Jan 29, 2004
    1,276
    doncaster east, vic
    hey bud how’s your 3080 going? Did you end up getting one from the US? For dirt cheap?
    my 1200 card is showing up on Monday can’t wait
  19. Aetherone
    Aetherone Member
    Jan 15, 2002
    8,882
    Adelaide, SA
    Simple doubling of the memory chips (either number or volume), keeping the bus bandwidth the same. AFIK, to do a 16Gb 3080 would require a repeat of the 3.5gb+500mb 970 kerfuffle.
    Not necessarily. Remember the second gen 12Gb Titan X? (as in the first Pascal cored Titan). Pipped by the 11Gb 1080ti, then stomped by the Titan X Pascal. So a 24Gb 3090 beating 20Gb 3080ti has form. Quickly followed by the proper Ampere Titan.
  20. combatant3219
    combatant3219 Member
    Mar 23, 2013
    477
    Blackburn
    Oh yeah, forgot you bought the delid kit off me. Glad to hear you got the results you wanted.
    The Beast likes this.
