NVME SSD's that run cooler than 960Evo
Discussion in 'Storage & Backup' started by bobster, Aug 27, 2018.
  1. bobster
    bobster Member
    Nov 11, 2011
    1,024
    Hi,
    My 500GB 960 Evo is peaking at 83 degrees and averaging 72 in games (ITX build), does anyone know of any fast NVME drives that run cooler
  2. Doc-of-FC
    Doc-of-FC Member
    Aug 30, 2001
    3,278
    • OPERATING TEMPERATURE
      0°C to 70°C (Measured by SMART Temperature. Proper airflow recommended)
    Ref: Samsung website.
    Keep the SSD, create a deflector or channel from paper / plastic to direct airflow over the SSD if possible or look to override the fan speeds using software to boost the airflow.
    For $0 you can be more creative, surely.
    12volt 40mm fan running on 5volts an option?
  3. Beavis_Wolf
    Beavis_Wolf Member
    Sep 6, 2007
    77
    Adelaide SA
    Checked my 970Evo 256 M2 while gaming Wildlands ( only game on it besides W7) using AIDA64 the temp only go up to 39C.
    This is a full size case with heaps of airflow
  4. PsydFX
    PsydFX Member
    Jan 1, 2011
    3,353
    From memory, the Pro series are supposed to run cooler - but obviously cost quite a bit more. I’ll see if I can dig up the link.
    bobster likes this.
  5. Rattus P Rattus
    Rattus P Rattus Member
    May 25, 2010
    31
    You could take the sticker off the top and buy some small (1cm x 1cm ish) heatsinks on eBay and stick them on there with some thermal adhesive, that'd get the temps down a fair bit.
  6. PsydFX
    PsydFX Member
    Jan 1, 2011
    3,353
    These are the reviews that I’d read.
    970 EVO / 970 PRO
    If you compare the temperature graphs from both reviews you’ll see that both the EVO and PRO will still reach 80 degrees under load, but with the EVO, the performance drop off as a result of DTG occurs much earlier, and has a significantly higher performance impact, compared to the PRO.
    Graphs also show differences between the 960 and 970.
  7. cvidler
    cvidler Member
    11,772
    there's M.2 sized specific heat sinks available, also as mentioned see if you can adjust airflow.
    NVME's all seem to run pretty warm.
  8. coolroy
    coolroy Member
    2,759
    Typically heat sinks added to nvme ssd's do not help much/if at all with heat removal, whilst good air flow over the same device will have a substantially lower temperatures.
  9. cvidler
    cvidler Member
    11,772
    heatsinks still need some airflow, a heatsink in hot stagnant air isn't going to work very well.
    NSanity likes this.
    bobster
    bobster Member
    Nov 11, 2011
    1,024
    Temps were higher with a heat sync
  11. issa2006
    issa2006 Member
    Feb 4, 2006
    3,147
    AUSTRALIA (ADL)
    hi
    iv got a 5$ heat sink on 1 of 2x m.2 in raid 0, the one cooled via heat sink much cooler (iv got a 80mm fan blowing down on matx board,and video card + card slots too. and 1/2 speed, some air flow helps
    i testem them when they where in non raid (got heat info from program).
    a normal m.2 ssd sata iii runs cooler + slower
    bobster
    bobster Member
    Nov 11, 2011
    1,024
    I swapped to 970 Evo and that gets hotter hahaha but for some silly reason the MB heatsink works well 970 Evo...
  13. MR CHILLED
    MR CHILLED D'oh!
    Jan 2, 2002
    137,093
    Omicron Persei 8
    Perhaps temps not being reported correctly. Will let you know tonight when I install a new 960 1TB nvme.
    bobster likes this.
  14. MR CHILLED
    MR CHILLED D'oh!
    Jan 2, 2002
    137,093
    Omicron Persei 8
    Two 960 drives....250G and 1TB.
    Will edit scores tonight under load.
    bobster likes this.
  15. PsydFX
    PsydFX Member
    Jan 1, 2011
    3,353
    Try again after a significant load.
    bobster
    bobster Member
    Nov 11, 2011
    1,024
    Let us know the result and what MB?
    MR CHILLED likes this.
  17. Butcher9_9
    Butcher9_9 Member
    Aug 5, 2006
    2,051
    Perth , East Vic Park
    I have 2x 960 EVOs as well, one near a fan and another not in direct flow (both with DIY heat sinks). The one with flow is pretty much at ambient while the other 20C higher.
    As for stress , Mine dont get very high at all, After running 3X 2GB ATTO Runs and 2X HD Tune benchmarks in a row on each drive, the drive with flow went up 13C while the No Flow drive went up 21C.
    bobster
    bobster Member
    Nov 11, 2011
    1,024
    Those are memory temps, controller gets a lot hotter
  19. BuuBox
    BuuBox Member
    May 7, 2003
    9,254
    I've got a Plextor M8Pe(G) which seems to run pretty cool.
  20. terrastrife
    terrastrife Member
    Jun 2, 2006
    18,418
    ADL/SA The Monopoly State
    They are little ARM CPUs without any heatsink, like almost all ARM CPUS, they start to throttle at 70C, if you want one that runs cooler, buy a slower one or install a heatsink on the CPU.
