NZXT X61 CPU Speed
Discussion in 'Troubleshooting Help' started by DanWA, Oct 1, 2019.
  1. DanWA
    DanWA Member
    Oct 15, 2006
    1,445
    W.A
    This one has me baffled
    I have a NZXT X61 on a Z270F and i cannot get the CPU speed out of it in BIOS or software
    I have tried the header plugged into CPU_FAN, CPU_OPT and AIO Pump
    The header i am using is the 3 pin one that comes direct out of the block not the radiator/fan side
  2. mesaoz
    mesaoz Member
    Jan 15, 2015
    7,911
    South East QLD
    Fans should go into the cpu headers and pump should go into the pump header.
    The 3 pin cable coming from the block is the pump power and control (DC) so make sure it's set to DC and not PWM in bios
    DanWA
    DanWA Member
    Oct 15, 2006
    1,445
    W.A
    So the 3 pin one from the block into CPU_OPT?
    All the youtube videos had it going into CPU_FAN header :(
    Will have a look at BIOS for a DC/PWN option after work
    Thanks
  4. mesaoz
    mesaoz Member
    Jan 15, 2015
    7,911
    South East QLD
    the cable coming from the block is for the pump, so if it lists cpu_opt as an optional pump header then yeah use that.
  5. terrastrife
    terrastrife Member
    Jun 2, 2006
    18,814
    ADL/SA The Monopoly State
    hmmm
    3 pin header which is for RPM goes to CPU FAN (legit no idea if it ges power from here because WHYYYY doesn't it also have sata?)
    SATA powers the pump and fans
    fans tail off the pump
    USB for CAM control.
