SOLVED OC help required
Discussion in 'Troubleshooting Help' started by aussie7, Dec 1, 2018.
  1. aussie7
    aussie7 Member
    Jul 3, 2001
    1,898
    Maroochydore QLD
    I have a new toy and I'm having issues overclocking it :shock:
    For some reason when I set my overclock in bios, it is not shown in cpu-x when I boot into linux :shock:
    gigabyte z370xp sli
    intel i5 8600k
    generic ram 4gb
    Anyone got any ideas why its not working in linux :confused:
    edit added some pics of bios settings and cpu-x
  2. Beavis_Wolf
    Beavis_Wolf Member
    Sep 6, 2007
    71
    Adelaide SA
    What's the RAM and is it rated to run at 2800?
    aussie7
    aussie7 Member
    Jul 3, 2001
    1,898
    Maroochydore QLD
    Ram is Crucial 1 x 4gb DDR4 2400Mhz, It seems to be running at 2760Mhz atm
  4. Beavis_Wolf
    Beavis_Wolf Member
    Sep 6, 2007
    71
    Adelaide SA
    "For some reason when I set my overclock in bios, it is not shown in cpu-x when I boot into linux
    Anyone got any ideas why its not working in windows"
    Can you clarify what you are doing here?
    aussie7
    aussie7 Member
    Jul 3, 2001
    1,898
    Maroochydore QLD
    Sorry typo, should have said linux instead of windows :p
    Basically as the pics in the first post, I set the overclock in the bios and when I boot into linux and start cpu-x it is not showing the overclock
    aussie7
    aussie7 Member
    Jul 3, 2001
    1,898
    Maroochydore QLD
    update got some ram corsair ddr4 @ 2400Mhz and still is not showing the overclock :confused:
  7. philquad
    philquad Member
    Jan 22, 2004
    833
    nelson bay
    isnt coz cpuz is showing the cpu at the variable speed or whatever you call it
    run a stress test & it should peak out
    i think i locked the ratio in somehow in the end when this happened
    aussie7
    aussie7 Member
    Jul 3, 2001
    1,898
    Maroochydore QLD
    Thanks, yes cpu-x is showing the variable speed and volts and when you stress test it goes to the max overclocked speed. I want to disable the variable speed and have it at overclocked speed all the time.
  9. philquad
    philquad Member
    Jan 22, 2004
    833
    nelson bay
    aussie7
    aussie7 Member
    Jul 3, 2001
    1,898
    Maroochydore QLD
    no luck with those settings either :confused:
    aussie7
    aussie7 Member
    Jul 3, 2001
    1,898
    Maroochydore QLD
    solved, its a linux bug as I installed win10 to see what happens and cpu-z displays the overclock settings correctly :p
  12. illdrag0n
    illdrag0n Member
    Mar 8, 2005
    99
    Disable EIST in advanced frequency settings
    aussie7
    aussie7 Member
    Jul 3, 2001
    1,898
    Maroochydore QLD
    Thanks will give it a go :)
