OCAU Guitar Players Club 3
Discussion in 'Musicians' started by sandwichamwin, Jun 11, 2010.
  1. shino
    shino Member
    Nov 9, 2015
    566
    got a new s/h guitar with a rocksmith cable. slight volume with garageband but no sound out of logic pro x.
  2. GoneFishin22
    GoneFishin22 Member
    Jun 28, 2008
    0
    Roll the cable around (is there some split wires) whilst playing a power chord.
  3. Cererus
    Cererus Member
    Jan 14, 2002
    1,579
    ASIO driver will not let other sound sound sources work?
    I have been messing around with Amplitube which is a Amp/stomp pedal/cabinet emulator for the PC
    I am connecting my guitar to this with a rocksmith real tone cable, to make this usable without lag I'm either selecting Windows direct sound (exclusive mode) or ASIO4all drivers.
    My issue is that these driver selections in Amplitube will block any other sound device like media players or Youtube. I would like to have Youtube or downloaded video tutorials running at the same time to practice.
    I understand ASIO shunts the audio signal direct to the sound card bypassing the OS to avoid lag, people are using 3rd party software like https://www.vb-audio.com/Voicemeeter/
    to get around the limitation of ASIO4all and have multiple sound sources.
    I've been messing around with this all weekend but can't get it working and I'm getting out of my depth and frustrated.
    Would anyone be able to help or point me to a tutorial, I have tried a guide form the Amplitube forum using Voicemeeter which is supposed to work with no luck.
    My sys is Win10 1903, using the on-board realtek sound chip, I have tried updating the sound chip drivers.
  4. shino
    shino Member
    Nov 9, 2015
    566
    Suppose a audio intereface like focusrite will make it work....
  5. jclei
    jclei Member
    Mar 1, 2004
    71
    I've heard that's a pretty common issue with those types of cables.
    Better off just buying an audio interface. They can be had pretty cheap these days. Can buy new basic ones for $80
  6. Cererus
    Cererus Member
    Jan 14, 2002
    1,579
    FWIW, I wound up buying a Behringer UCG102 guitar link. Theres even chinese clone versions on ebay that seem to work the same for $10. But I wanted it now so shelled out $50 at an online AUS music store.
    This solved the issue
    spokeydokey likes this.
  7. alexb618
    alexb618 Member
    Dec 15, 2004
    10,330
    adelaide
    ive been playing my acoustic for like 3 weeks now with strings that are in dire need of replacement but i CANNOT BE BOTHERED. ughhhhhhhhh
  8. broccoli
    broccoli Member
    Feb 21, 2010
    21,513
    You need a roadie. :D
  9. alexb618
    alexb618 Member
    Dec 15, 2004
    10,330
    adelaide
    honestly i dont even have an excuse because i am on holidays at the moment but ughhhhhhhh
    could have changed 5 sets in the time ive spent moaning about it here
  10. broccoli
    broccoli Member
    Feb 21, 2010
    21,513
    I like doing it, I like polishing everything and making it all shiny.
  11. alexb618
    alexb618 Member
    Dec 15, 2004
    10,330
    adelaide
    my address is...
  12. broccoli
    broccoli Member
    Feb 21, 2010
    21,513
    hahahaha, if you were local, I'd do it. I used to try to get my guitar teacher to let me do his guitar. He ended up getting it serviced and the guy cleaned it up as part of that.
  13. ndt
    ndt Member
    Sep 13, 2004
    1,588
    Pretty sure the strings on one of my lesser used guitars are like 6 years old at this point.
  14. broccoli
    broccoli Member
    Feb 21, 2010
    21,513
    but they don't just go bung sitting about, do they? I've just dug out one of mine and the strings would be old, it sounds ok to me....
  15. Perko
    Perko Member
    Aug 12, 2011
    4,468
    NW Tasmania
    Depends on the strings and the environment they're in.
    I pulled out my Tele once when it had been in its case for a couple of years with a set of Elixirs on it, and thought I should change them, and I couldn't tell the difference tonally before and after.
    But then my king v uses really heavy D'addario NYXL uncoated strings to run C tuning, and they're as dead as a door nail and start feeling crappy after a month of light use.
  16. Radley
    Radley Member
    Feb 24, 2009
    2,143
    Coffs Harbour
    Strings rust in their packaging after a year or 2 where I live.
  17. broccoli
    broccoli Member
    Feb 21, 2010
    21,513
    oh yes, location makes sense. North/tropical can be harsh on stuff, can't it?
  18. shino
    shino Member
    Nov 9, 2015
    566
    any particular guitar cable you using? or doesn't matter?
  19. ndt
    ndt Member
    Sep 13, 2004
    1,588
    I recently picked up some active pickups to plonk in a guitar I have but found the volume pot hole has been drilled out for a larger gibson style pot but I only have mini 25k pots the active pickups required. So I'm wondering if the higher rating pot will affect tone or just the volume roll off effect? I've read that using the high value pots makes them act like switches with active pickups rather than a pot that rolls off the volume, but if it affects the tone of the pickup seems to be mixed opinions.
  20. Perko
    Perko Member
    Aug 12, 2011
    4,468
    NW Tasmania
    Yeah it's just the (lack of a) volume curve. A pot is a straight connection when it's turned right up. The mixed opinions come from the same people who reckon that quick connect EMGs sound different to the old hard wired ones. I've had both, and those guys have been sniffing way too many corks.
    ndt likes this.
