OCAU Ryzen Overclocking discussion/ Guide / Owners Thread
Discussion in 'AMD x86 CPUs and chipsets' started by mAJORD, Mar 3, 2017.
  1. Hotrod2go
    Hotrod2go Member
    Jun 17, 2018
    527
    Tas
    OJR, yes for now. Waiting to see when Zen 3 becomes retail.
    OJR likes this.
  2. di_entropy
    di_entropy Member
    1,352
    My new 3800X, sitting stable now with manual OC, CCX0/CCX1 4400/4450MHz @ 1.35V.
    Memory OC'd to 3800 CL16, 1900 Infinity Fabric
    Ryzen 7 3800X
    MSI X570 Tomahawk
    32GB G.Skill TridentZ RGB 3200 CL14 (2x16GB B-die's)
    EVGA 1080Ti
    EK Velocity WB with 1x 360 and 1x 420 rads
    These things are hot and hungry.. not impressed with this EK waterblock although maybe it is a bad mount, reaches up to 87degC stress testing with OCCT, but typically only up to around 75degC while gaming and usual workload.
    I think I could hit 4.5GHz with better cooling and more volts. Going to order one of those new Optimus Foundation blocks.
    https://imgur.com/a/XDMjxbN
    Bolter01 and MUTMAN like this.
  3. darkbastard
    darkbastard Member
    Sep 17, 2004
    830
    Duranbah - near Kingsclif
    Very Nice.
    Those optimus blocks interest me. Never heard of them before but they certainly talk up a good story on their performance and manufacturing. Now it is something I am definitely going to think about. Is there an Australian outlet for them yet?
  4. SKITZ0_000
    SKITZ0_000 Member
    Jul 19, 2003
    1,351
    Tas
    That temp seems high for that voltage, what pump is it, at full speed? The flow is definitely the right way?
  5. di_entropy
    di_entropy Member
    1,352
    They look very well built with optimal design to cover the full Ryzen IHS. Initial user based results are that they perform a few degrees better than the Heatkiller IV Pro blocks which are already top performers. No where to get them in Aus yet, I will order direct.
    Yeah does seem a bit higher than what I was expecting. EK DBAY D5 PWM Pump/Reservoir Combo, inlet/outflow flow is correct on the WB. Pump speed set with min 50% and ramping up to 100% speed at 75degC, same with the rad fans.
    I think I will try a re-mount this weekend.
  6. SKITZ0_000
    SKITZ0_000 Member
    Jul 19, 2003
    1,351
    Tas
    Yeah, your setup looks fine, I think it would be worth testing with the pump pwm at 100% though, at least see if it's worth ramping it a little sooner as pump pressure can make a fair difference.
  7. Bolter01
    Bolter01 Member
    Oct 14, 2008
    624
    Now
    please tell me your flow is running up ^ GPU -> CPU? - just because impingement plate is inlet
    apology if stating obvious just not familiar with that pump res flow -->
  8. Bolter01
    Bolter01 Member
    Oct 14, 2008
    624
    Now
    think it will run a shitload better if you swap those CPU hoses around ;)
    (flow from top down right?) :thumbup:
  9. di_entropy
    di_entropy Member
    1,352
  10. Bolter01
    Bolter01 Member
    Oct 14, 2008
    624
    Now
    Ok cool, just reverse to what I normal do.
    And the GPU block works like that, pictured inlet on right?
    The ones I have used all have inlet on left.
  11. im late
    im late Member
    Jan 5, 2012
    1,711
    Canning Vale WA 6155
    All EK GPU full cover water-blocks require inlet to the left, not to the right - as pictured above - for best cooling performance.
    Example of written instructions from EKWB:
    https://www.ekwb.com/shop/EK-IM/EK-IM-3831109831922.pdf
  12. di_entropy
    di_entropy Member
    1,352
    This is not the same GPU block I am using.
    I have the EK-FC Titan X Pascal - Acetal.
    The instruction manual states "You can use any opening as an inlet/outlet port".
    I might still play around with the loop on the weekend and change the order so it flows Res/Pump > RX360 Front Rad > EX420 Top Rad > CPU > GPU
    Bolter01 likes this.
  13. Bolter01
    Bolter01 Member
    Oct 14, 2008
    624
    Now
    well there you go, sorry man just looked amiss. Ag :thumbup:
    75c gaming does seem pretty warm. I offset my voltage -.075 on 3900X still get full boost, but runs a dam site cooler than stock V
  14. di_entropy
    di_entropy Member
    1,352
    All good, something might still be amiss. :lol: Just verifying everything is correct as per manufacturer instructions, so nothing obvious just yet.
    What temps do you get running OCCT? Are you able to fire up OCCT on the default large test and run it for 10 min and let me know what your max temps are?
  15. Bolter01
    Bolter01 Member
    Oct 14, 2008
    624
    Now
    :thumbup: Gaming wouldn't go over 50 this time of year.
  16. Hotrod2go
    Hotrod2go Member
    Jun 17, 2018
    527
    Tas
    di entropy, what ambient temp is that room the rig is in?
    Any discussion about temps overall must consider this factor.
  17. im late
    im late Member
    Jan 5, 2012
    1,711
    I stand corrected. Apologies for the wrong info.
    If this helps you figure out what is going on, I posted this CBR15 score recently with a $69 Byski CPU block:
    https://imgur.com/ZncSdNU
    Never went over 60 degrees.
    museumman and Bolter01 like this.
  18. Bolter01
    Bolter01 Member
    Oct 14, 2008
    624
    Now
    Very nice OC and timings, best bit is was all done on a X370 ftw! gg
    got a pic of your block somewhere, or same as mine?
  19. im late
    im late Member
    Jan 5, 2012
    1,711
  20. Bolter01
    Bolter01 Member
    Oct 14, 2008
    624
    Now
    yes same block, put it up against ANY other, pure size of cold plate/fin density and free flowing :thumbup:
    the impingement plate & fins literally overlaps the entire IHS - outside that you have water channels around entire outer edge
