OCAU Ryzen Overclocking discussion/ Guide / Owners Thread
Discussion in 'AMD x86 CPUs and chipsets' started by mAJORD, Mar 3, 2017.
  1. Sgt Bilko
    Sgt Bilko Member
    Mar 5, 2015
    914
    Canberra(ish)
    Happy to hear it! :D
    the_antipop likes this.
  2. the_antipop
    the_antipop Member
    Jun 11, 2005
    1,705
    Gold Coast
    Haha - well, me again. New issue.
    For some reason, my overclock is never going past 3.65ghz. In my BIOS settings, I set my overclock to something like 3.85 or 3.8, and restart, it boots straight back up, however it has auto switched to 3.65... Has anyone ever had this issue? I have reset the bios defaults, reset cmos - but everytime I change the cpu core clock to anything above 3.65, it just auto defaults back down to it... I can change everything else fine (cpu voltage offset, ram overclock and ram voltage).
  3. OJR
    OJR Member
    Jan 19, 2013
    3,479
    I had a similar issue with Crosshair VI extreme. It was a BIOS issue. Asus eventually released a BIOS that fixed it. Are you running the latest BIOS?
  4. the_antipop
    the_antipop Member
    Jun 11, 2005
    1,705
    Gold Coast
    Yeah running the latest bios. Was tinkering til the late last night, and I think I fixed it. Seems that when you select the “Asus Optimal” setting it auto switches to 3.65ghz. Changing it back to normal, it enables a higher overclock. Interesting.
  5. Rod M
    Rod M Member
    3,273
    is using Prime 95 still a good way to test an oc?
  6. MUTMAN
    MUTMAN Member
    5,798
    4109
    Prime will always be a good test of part of the cpu but not all of it.
    IBT was another good one, as is looping of 3dmark etc
    You could run MemTest too
    But, doesnt Ryzen Master have a torture test built-in?
    Rod M likes this.
  7. Sgt Bilko
    Sgt Bilko Member
    Mar 5, 2015
    914
    Canberra(ish)
    Realbench will be my go to for quite some time, there's a bit of everything in there :)
    Rod M likes this.
  8. OJR
    OJR Member
    Jan 19, 2013
    3,479
    Prime95 blend test is still my go to. If it passes that for an hour it’s going to be stable for anything else you might throw at it work wise.
    Rod M likes this.
  9. Plonkflopped
    Plonkflopped Member
    Feb 3, 2012
    285
    2700 non x OC guide on a b450 board ? My google skills suck.
  10. OJR
    OJR Member
    Jan 19, 2013
    3,479
    there is no need to overclock. they overclock themselves if your cooling and power delivery is decent.
    WRX_STi likes this.
  11. shirl
    shirl Member
    Aug 24, 2003
    216
    sydney
    my 1700 tops out at 3965mhz voltage to achieve wasnt worth it,it turbos to 3750mhz stock volts so it will stay there cbf tinkering any more..
  12. WRX_STi
    WRX_STi Member
    Sep 6, 2001
    1,705
    Cairns
    Exactly, I get 4.3 GHZ on my 2600X doing nothing,
    When I try manual overlock I think 4200 is about it. I let the AMD do its thing.
  13. OJR
    OJR Member
    Jan 19, 2013
    3,479
    My 2700X was boosting up to 4385 on some cores.
  14. glnn_23
    glnn_23 Member
    Jan 19, 2012
    418
    Picked up a 2700x and Asus x470 itx board yesterday. Used the stock cooler first then chucked it in a bigger case with a few rads and it helped a bit.
    Seems to be going ok so far.
    1dongchen and museumman like this.
  15. darkbastard
    darkbastard Member
    Sep 17, 2004
    491
    Duranbah - near Kingsclif
    That’s a decent memory clock as well Ginn.
    Nice result especially on an itx board.
    Doesn’t it take the 9900k 4.7 or 5ghz on all cores to break 2000 in cinebench????
    1dongchen likes this.
  16. glnn_23
    glnn_23 Member
    Jan 19, 2012
    418
    Not sure on how the 9900k is at 5Ghz. Tried 4.5Ghz but not so good. Got to 4.44Ghz and 3866c16 on the mem.
    museumman likes this.
  17. darkbastard
    darkbastard Member
    Sep 17, 2004
    491
    4.44 is still well above the curve - as is 3866 on the ram
  18. glnn_23
    glnn_23 Member
    Jan 19, 2012
    418
    Slight bump in clocks. Needed c18 for 3913Mhz on the mem.
    Would need more volts for any kind of stability though.
    MUTMAN and OJR like this.
  19. the_antipop
    the_antipop Member
    Jun 11, 2005
    1,705
    Gold Coast
    Was able to get my ram to 3200 using the Ryzen ram calculator, but started to get crashes in games, and even chrome, including the odd BSOD. I reset bios and was able to get to 3133mhz without turning on XMP, or playing with the timings - just bumped the voltage to 1.35v. I think I'll leave it there :thumbup:
  20. glnn_23
    glnn_23 Member
    Jan 19, 2012
    418
    MUTMAN likes this.
