OLED's OLED's OLED's!
Discussion in 'Audio Visual' started by aokman, Oct 3, 2018.
  1. TheWatcher
    TheWatcher Member
    May 14, 2014
    750
    When sorting out the settings for Xbox and PS, is it the same for both or you need to do it separately for each HDMI port/device? (On C1)
  2. power
    68,180
    on an LG you can set everything up and tell it to apply to all ports.
    MUTMAN and TheWatcher like this.
  3. TheWatcher
    TheWatcher Member
    May 14, 2014
    750
    But, in terms of actual best settings, is there a difference in what the settings should be for the Xbox and for the PS?
  4. power
    68,180
    pretty sure Vincent from HDTV Test did some nice setting up vids. Personally I would setup probably the xbox and then apply it to the ports and see what i thought. they are fairly similar.
    actually if it was me i'd just setup youtube watch vincent for a day and then do it. bear in mind the LG firmware gets updated frequently.
    lol
    fun C1 "hack" you can bind any app to a long press of the number keys!
  5. TheWatcher
    TheWatcher Member
    May 14, 2014
    750
    Does the firmware update reset the saved settings each time?
  6. MR CHILLED
    MR CHILLED D'oh!
    Jan 2, 2002
    161,695
    Omicron Persei 8
    So far so good, no firmware updates have changed any of my settings.
  7. power
    68,180
    i've never had the firmware change any settings personally.
  8. Johnbu
    Johnbu Member
    Jul 14, 2005
    3,315
    SE Melbourne
    Yes rare.
    At the start of the year when they were around $8k or so, I said to myself I'll pull the trigger at around $6.5k. Couldn't say no.
    I must admit that the 77inch at $4.7k is much better value but didn't want the regret.
    Not sure what to do with my wall bracket.
    Use existing TV wall bracket or get a new ball bracket.
  9. MR CHILLED
    MR CHILLED D'oh!
    Jan 2, 2002
    161,695
    Omicron Persei 8
    Certainly for me the 77" is starting to get to a price where I might even be entertaining the thought of changing from the 65".
  10. nico6
    nico6 Member
    Sep 9, 2005
    1,756
    melb.vic.au
    You may need to move it, as the mounting points are in the lower half of the screen
  11. TheBear21
    TheBear21 Member
    Aug 2, 2007
    2,521
    Central QLD
    I've decided a 65" Sony A80J is what I am after. But my local store doesn't seem to want to move much on price. Anyone buy one recently and get a good price? They were $3495 until a couple of weeks ago there went up to $3795 so they could be discounted back down for the sales to $3495. The best I am getting is $3395.
  12. Johnbu
    Johnbu Member
    Jul 14, 2005
    3,315
    SE Melbourne
    Very good point.
    If I have to move the wall bracket, I'll get a new bracket.
    The existing bracket will stay with the TV wherever it will be installed.
  13. MUTMAN
    MUTMAN Member
    10,931
    4109
    Why not just save 500 bucks and get the of c1 ??
  14. MR CHILLED
    MR CHILLED D'oh!
    Jan 2, 2002
    161,695
    Omicron Persei 8
  15. Elmf
    Elmf Member
    Jan 6, 2007
    2,620
    From memory it didn't do full speed hdmi 2.1, 28Gbps Max? Not sure it makes a difference. It does have dp1.4 though which is nice
    MUTMAN and MR CHILLED like this.
  16. jjjc_93
    jjjc_93 Member
    Jul 3, 2009
    3,861
    Not as bright as the C1 in SDR or HDR mode. Lacks some of the firmware protections LG have implemented for image retention. No Dolby vision, etc.
    No reason to get one over a C1 unless you lack a setup with hdmi 2.1 imo.
    https://www.techspot.com/review/2345-gigabyte-aorus-fo48u-oled/
    mikezilla2, MR CHILLED and MUTMAN like this.
  17. Elmf
    Elmf Member
    Jan 6, 2007
    2,620
    Now have my 55" OLED mounted in my office. Office is now a games and movie room too haha
    mikezilla2, MUTMAN and boneburner like this.
  18. MUTMAN
    MUTMAN Member
    10,931
    4109
    Pic or I'm believing you bought a 36" TCL ....
    :lol:
    Elmf likes this.
  19. Elmf
    Elmf Member
    Jan 6, 2007
    2,620
    Let me clean it up first then I will share the ridiculousness that is a 55" mounted above a 27 and 24" work setup on a desk that's only 600mm deep lmfao
  20. Elmf
    Elmf Member
    Jan 6, 2007
    2,620
    Here ya go fellas. I ain't no fraud :p
    Only other thing I wanna do is run one final hdmi to it to hook up my ps4 pro. Atm it's got xbox series X and my pc on it.
    https://imgur.com/a/QR54uS2
    All monitors and TV are wall mounted with mounting dream brackets off amazon into wall studs. All cables through wall to behind monitors then just up to the TV cos you can't see them anyway.
    15degree tilt on the TV according to m. Dream.
    power, WishBone17, nico6 and 2 others like this.
