OpenSolaris/Solaris 11 Express/ESXi : BYO Home NAS for Media and backup images etc
Discussion in 'Storage & Backup' started by davros123, Dec 14, 2009.
  1. OP
    davros123
    davros123 Member
    Jun 18, 2008
    3,006
    EDIT: I have no explanation for it but it is now working :)
    THANKYOU for the help!
    Index of /
    Below is what I had posted before I checked log files and tried again...
    Ok, Restarted.
    Code:
    apache-server    :  online (Include httpd-vhosts, proxy-html, httpd_php, httpd_phpmyadmin)
    so this is what's in the two files...
    apache.conf
    Code:
    # This is the main Apache HTTP server configuration file.  It contains the
    # configuration directives that give the server its instructions.
    # See <URL:http://httpd.apache.org/docs/2.4/> for detailed information.
    # In particular, see
    # <URL:http://httpd.apache.org/docs/2.4/mod/directives.html>
    # for a discussion of each configuration directive.
    # Do NOT simply read the instructions in here without understanding
    # what they do.  They're here only as hints or reminders.  If you are unsure
    # consult the online docs. You have been warned.
    # Configuration and logfile names: If the filenames you specify for many
    # of the server's control files begin with "/" (or "drive:/" for Win32), the
    # server will use that explicit path.  If the filenames do *not* begin
    # with "/", the value of ServerRoot is prepended -- so "logs/access_log"
    # with ServerRoot set to "/usr/local/apache2" will be interpreted by the
    # server as "/usr/local/apache2/logs/access_log", whereas "/logs/access_log"
    # will be interpreted as '/logs/access_log'.
    # ServerRoot: The top of the directory tree under which the server's
    # configuration, error, and log files are kept.
    # Do not add a slash at the end of the directory path.  If you point
    # ServerRoot at a non-local disk, be sure to specify a local disk on the
    # Mutex directive, if file-based mutexes are used.  If you wish to share the
    # same ServerRoot for multiple httpd daemons, you will need to change at
    # least PidFile.
    ServerRoot "/opt/local"
    # Mutex: Allows you to set the mutex mechanism and mutex file directory
    # for individual mutexes, or change the global defaults
    # Uncomment and change the directory if mutexes are file-based and the default
    # mutex file directory is not on a local disk or is not appropriate for some
    # other reason.
    # Mutex default:/var/run
    # Listen: Allows you to bind Apache to specific IP addresses and/or
    # ports, instead of the default. See also the <VirtualHost>
    # directive.
    # Change this to Listen on specific IP addresses as shown below to
    # prevent Apache from glomming onto all bound IP addresses.
    #Listen 12.34.56.78:80
    Listen 0.0.0.0:80
    # Dynamic Shared Object (DSO) Support
    # To be able to use the functionality of a module which was built as a DSO you
    # have to place corresponding `LoadModule' lines at this location so the
    # directives contained in it are actually available _before_ they are used.
    # Statically compiled modules (those listed by `httpd -l') do not need
    # to be loaded here.
    # Example:
    # LoadModule foo_module modules/mod_foo.so
    LoadModule mpm_prefork_module lib/httpd/mod_mpm_prefork.so
    #LoadModule mpm_prefork_module lib/httpd/mod_mpm_prefork.so
    #LoadModule mpm_worker_module lib/httpd/mod_mpm_worker.so
    LoadModule authn_file_module lib/httpd/mod_authn_file.so
    #LoadModule authn_dbm_module lib/httpd/mod_authn_dbm.so
    #LoadModule authn_anon_module lib/httpd/mod_authn_anon.so
    #LoadModule authn_dbd_module lib/httpd/mod_authn_dbd.so
    #LoadModule authn_socache_module lib/httpd/mod_authn_socache.so
    LoadModule authn_core_module lib/httpd/mod_authn_core.so
    LoadModule authz_host_module lib/httpd/mod_authz_host.so
    LoadModule authz_groupfile_module lib/httpd/mod_authz_groupfile.so
    LoadModule authz_user_module lib/httpd/mod_authz_user.so
    #LoadModule authz_dbm_module lib/httpd/mod_authz_dbm.so
    #LoadModule authz_owner_module lib/httpd/mod_authz_owner.so
    #LoadModule authz_dbd_module lib/httpd/mod_authz_dbd.so
    LoadModule authz_core_module lib/httpd/mod_authz_core.so
    #LoadModule authnz_ldap_module lib/httpd/mod_authnz_ldap.so
    LoadModule access_compat_module lib/httpd/mod_access_compat.so
    LoadModule auth_basic_module lib/httpd/mod_auth_basic.so
    #LoadModule auth_form_module lib/httpd/mod_auth_form.so
    #LoadModule auth_digest_module lib/httpd/mod_auth_digest.so
    #LoadModule allowmethods_module lib/httpd/mod_allowmethods.so
    #LoadModule file_cache_module lib/httpd/mod_file_cache.so
    #LoadModule cache_module lib/httpd/mod_cache.so
    #LoadModule cache_disk_module lib/httpd/mod_cache_disk.so
    #LoadModule cache_socache_module lib/httpd/mod_cache_socache.so
    #LoadModule socache_shmcb_module lib/httpd/mod_socache_shmcb.so
    #LoadModule socache_dbm_module lib/httpd/mod_socache_dbm.so
    #LoadModule socache_memcache_module lib/httpd/mod_socache_memcache.so
    #LoadModule watchdog_module lib/httpd/mod_watchdog.so
    #LoadModule macro_module lib/httpd/mod_macro.so
    #LoadModule dbd_module lib/httpd/mod_dbd.so
    #LoadModule dumpio_module lib/httpd/mod_dumpio.so
    #LoadModule echo_module lib/httpd/mod_echo.so
    #LoadModule buffer_module lib/httpd/mod_buffer.so
    #LoadModule data_module lib/httpd/mod_data.so
    #LoadModule ratelimit_module lib/httpd/mod_ratelimit.so
    LoadModule reqtimeout_module lib/httpd/mod_reqtimeout.so
    #LoadModule ext_filter_module lib/httpd/mod_ext_filter.so
    #LoadModule request_module lib/httpd/mod_request.so
    #LoadModule include_module lib/httpd/mod_include.so
    LoadModule filter_module lib/httpd/mod_filter.so
    #LoadModule reflector_module lib/httpd/mod_reflector.so
    #LoadModule substitute_module lib/httpd/mod_substitute.so
    #LoadModule sed_module lib/httpd/mod_sed.so
    #LoadModule charset_lite_module lib/httpd/mod_charset_lite.so
    #LoadModule deflate_module lib/httpd/mod_deflate.so
    LoadModule mime_module lib/httpd/mod_mime.so
    #LoadModule ldap_module lib/httpd/mod_ldap.so
    LoadModule log_config_module lib/httpd/mod_log_config.so
    #LoadModule log_debug_module lib/httpd/mod_log_debug.so
    #LoadModule log_forensic_module lib/httpd/mod_log_forensic.so
    #LoadModule logio_module lib/httpd/mod_logio.so
    LoadModule env_module lib/httpd/mod_env.so
    #LoadModule mime_magic_module lib/httpd/mod_mime_magic.so
    #LoadModule expires_module lib/httpd/mod_expires.so
    LoadModule headers_module lib/httpd/mod_headers.so
    #LoadModule usertrack_module lib/httpd/mod_usertrack.so
    #LoadModule unique_id_module lib/httpd/mod_unique_id.so
    LoadModule setenvif_module lib/httpd/mod_setenvif.so
    LoadModule version_module lib/httpd/mod_version.so
    #LoadModule remoteip_module lib/httpd/mod_remoteip.so
    #LoadModule proxy_module lib/httpd/mod_proxy.so
    #LoadModule proxy_connect_module lib/httpd/mod_proxy_connect.so
    #LoadModule proxy_ftp_module lib/httpd/mod_proxy_ftp.so
    #LoadModule proxy_http_module lib/httpd/mod_proxy_http.so
    #LoadModule proxy_fcgi_module lib/httpd/mod_proxy_fcgi.so
    #LoadModule proxy_scgi_module lib/httpd/mod_proxy_scgi.so
    #LoadModule proxy_fdpass_module lib/httpd/mod_proxy_fdpass.so
    #LoadModule proxy_wstunnel_module lib/httpd/mod_proxy_wstunnel.so
    #LoadModule proxy_ajp_module lib/httpd/mod_proxy_ajp.so
    #LoadModule proxy_balancer_module lib/httpd/mod_proxy_balancer.so
    #LoadModule proxy_express_module lib/httpd/mod_proxy_express.so
    #LoadModule proxy_hcheck_module lib/httpd/mod_proxy_hcheck.so
    #LoadModule session_module lib/httpd/mod_session.so
    #LoadModule session_cookie_module lib/httpd/mod_session_cookie.so
    #LoadModule session_crypto_module lib/httpd/mod_session_crypto.so
    #LoadModule session_dbd_module lib/httpd/mod_session_dbd.so
    #LoadModule slotmem_shm_module lib/httpd/mod_slotmem_shm.so
    #LoadModule slotmem_plain_module lib/httpd/mod_slotmem_plain.so
    #LoadModule ssl_module lib/httpd/mod_ssl.so
    #LoadModule dialup_module lib/httpd/mod_dialup.so
    #LoadModule http2_module lib/httpd/mod_http2.so
    #LoadModule lbmethod_byrequests_module lib/httpd/mod_lbmethod_byrequests.so
    #LoadModule lbmethod_bytraffic_module lib/httpd/mod_lbmethod_bytraffic.so
    #LoadModule lbmethod_bybusyness_module lib/httpd/mod_lbmethod_bybusyness.so
    #LoadModule lbmethod_heartbeat_module lib/httpd/mod_lbmethod_heartbeat.so
    LoadModule unixd_module lib/httpd/mod_unixd.so
    #LoadModule privileges_module lib/httpd/mod_privileges.so
    #LoadModule heartbeat_module lib/httpd/mod_heartbeat.so
    #LoadModule heartmonitor_module lib/httpd/mod_heartmonitor.so
    #LoadModule dav_module lib/httpd/mod_dav.so
    LoadModule status_module lib/httpd/mod_status.so
    LoadModule autoindex_module lib/httpd/mod_autoindex.so
    #LoadModule asis_module lib/httpd/mod_asis.so
    #LoadModule info_module lib/httpd/mod_info.so
    #LoadModule suexec_module lib/httpd/mod_suexec.so
    #LoadModule cgid_module lib/httpd/mod_cgid.so
    #LoadModule dav_fs_module lib/httpd/mod_dav_fs.so
    #LoadModule dav_lock_module lib/httpd/mod_dav_lock.so
    #LoadModule vhost_alias_module lib/httpd/mod_vhost_alias.so
    #LoadModule negotiation_module lib/httpd/mod_negotiation.so
    LoadModule dir_module lib/httpd/mod_dir.so
    #LoadModule actions_module lib/httpd/mod_actions.so
    #LoadModule speling_module lib/httpd/mod_speling.so
    #LoadModule userdir_module lib/httpd/mod_userdir.so
    LoadModule alias_module lib/httpd/mod_alias.so
    #LoadModule rewrite_module lib/httpd/mod_rewrite.so
    <IfModule unixd_module>
    # If you wish httpd to run as a different user or group, you must run
    # httpd as root initially and it will switch.
    # User/Group: The name (or #number) of the user/group to run httpd as.
    # It is usually good practice to create a dedicated user and group for
    # running httpd, as with most system services.
    User www
    Group www
    </IfModule>
    # 'Main' server configuration
    # The directives in this section set up the values used by the 'main'
    # server, which responds to any requests that aren't handled by a
    # <VirtualHost> definition.  These values also provide defaults for
    # any <VirtualHost> containers you may define later in the file.
    # All of these directives may appear inside <VirtualHost> containers,
    # in which case these default settings will be overridden for the
    # virtual host being defined.
    # ServerAdmin: Your address, where problems with the server should be
    # e-mailed.  This address appears on some server-generated pages, such
    # as error documents.  e.g. admin@your-domain.com
    ServerAdmin you@example.com
    # ServerName gives the name and port that the server uses to identify itself.
    # This can often be determined automatically, but we recommend you specify
    # it explicitly to prevent problems during startup.
    # If your host doesn't have a registered DNS name, enter its IP address here.
    #ServerName www.example.com:80
    # Deny access to the entirety of your server's filesystem. You must
    # explicitly permit access to web content directories in other
    # <Directory> blocks below.
    <Directory />
        AllowOverride none
        Require all denied
    </Directory>
    # Note that from this point forward you must specifically allow
    # particular features to be enabled - so if something's not working as
    # you might expect, make sure that you have specifically enabled it
    # below.
    # DocumentRoot: The directory out of which you will serve your
    # documents. By default, all requests are taken from this directory, but
    # symbolic links and aliases may be used to point to other locations.
    DocumentRoot "/opt/local/share/httpd/htdocs"
    <Directory "/opt/local/share/httpd/htdocs">
        # Possible values for the Options directive are "None", "All",
        # or any combination of:
        #   Indexes Includes FollowSymLinks SymLinksifOwnerMatch ExecCGI MultiViews
        # Note that "MultiViews" must be named *explicitly* --- "Options All"
        # doesn't give it to you.
        # The Options directive is both complicated and important.  Please see
        # http://httpd.apache.org/docs/2.4/mod/core.html#options
        # for more information.
        Options Indexes FollowSymLinks
        # AllowOverride controls what directives may be placed in .htaccess files.
        # It can be "All", "None", or any combination of the keywords:
        #   AllowOverride FileInfo AuthConfig Limit
        AllowOverride None
        # Controls who can get stuff from this server.
        Require all granted
    </Directory>
    # DirectoryIndex: sets the file that Apache will serve if a directory
    # is requested.
    <IfModule dir_module>
        DirectoryIndex index.html index.php
    </IfModule>
    # The following lines prevent .htaccess and .htpasswd files from being
    # viewed by Web clients.
    <Files ".ht*">
        Require all denied
    </Files>
    # ErrorLog: The location of the error log file.
    # If you do not specify an ErrorLog directive within a <VirtualHost>
    # container, error messages relating to that virtual host will be
    # logged here.  If you *do* define an error logfile for a <VirtualHost>
    # container, that host's errors will be logged there and not here.
    ErrorLog "/var/log/httpd/error_log"
    # LogLevel: Control the number of messages logged to the error_log.
    # Possible values include: debug, info, notice, warn, error, crit,
    # alert, emerg.
    LogLevel warn
    <IfModule log_config_module>
        # The following directives define some format nicknames for use with
        # a CustomLog directive (see below).
        LogFormat "%h %l %u %t \"%r\" %>s %b \"%{Referer}i\" \"%{User-Agent}i\"" combined
        LogFormat "%h %l %u %t \"%r\" %>s %b" common
        <IfModule logio_module>
          # You need to enable mod_logio.c to use %I and %O
          LogFormat "%h %l %u %t \"%r\" %>s %b \"%{Referer}i\" \"%{User-Agent}i\" %I %O" combinedio
        </IfModule>
        # The location and format of the access logfile (Common Logfile Format).
        # If you do not define any access logfiles within a <VirtualHost>
        # container, they will be logged here.  Contrariwise, if you *do*
        # define per-<VirtualHost> access logfiles, transactions will be
        # logged therein and *not* in this file.
        CustomLog "/var/log/httpd/access_log" common
        # If you prefer a logfile with access, agent, and referer information
        # (Combined Logfile Format) you can use the following directive.
        #CustomLog "/var/log/httpd/access_log" combined
    </IfModule>
    <IfModule alias_module>
        # Redirect: Allows you to tell clients about documents that used to
        # exist in your server's namespace, but do not anymore. The client
        # will make a new request for the document at its new location.
        # Example:
        # Redirect permanent /foo http://www.example.com/bar
        # Alias: Maps web paths into filesystem paths and is used to
        # access content that does not live under the DocumentRoot.
        # Example:
        # Alias /webpath /full/filesystem/path
        # If you include a trailing / on /webpath then the server will
        # require it to be present in the URL.  You will also likely
        # need to provide a <Directory> section to allow access to
        # the filesystem path.
        # ScriptAlias: This controls which directories contain server scripts.
        # ScriptAliases are essentially the same as Aliases, except that
        # documents in the target directory are treated as applications and
        # run by the server when requested rather than as documents sent to the
        # client.  The same rules about trailing "/" apply to ScriptAlias
        # directives as to Alias.
        ScriptAlias /cgi-bin/ "/opt/local/libexec/cgi-bin/"
    </IfModule>
    <IfModule cgid_module>
        # ScriptSock: On threaded servers, designate the path to the UNIX
        # socket used to communicate with the CGI daemon of mod_cgid.
        #Scriptsock cgisock
    </IfModule>
    # "/opt/local/libexec/cgi-bin" should be changed to whatever your ScriptAliased
    # CGI directory exists, if you have that configured.
    <Directory "/opt/local/libexec/cgi-bin">
        AllowOverride None
        Options None
        Require all granted
    </Directory>
    <IfModule headers_module>
        # Avoid passing HTTP_PROXY environment to CGI's on this or any proxied
        # backend servers which have lingering "httpoxy" defects.
        # 'Proxy' request header is undefined by the IETF, not listed by IANA
        RequestHeader unset Proxy early
    </IfModule>
    <IfModule mime_module>
        # TypesConfig points to the file containing the list of mappings from
        # filename extension to MIME-type.
        TypesConfig etc/httpd/mime.types
        # AddType allows you to add to or override the MIME configuration
        # file specified in TypesConfig for specific file types.
        #AddType application/x-gzip .tgz
        # AddEncoding allows you to have certain browsers uncompress
        # information on the fly. Note: Not all browsers support this.
        #AddEncoding x-compress .Z
        #AddEncoding x-gzip .gz .tgz
        # If the AddEncoding directives above are commented-out, then you
        # probably should define those extensions to indicate media types:
        AddType application/x-compress .Z
        AddType application/x-gzip .gz .tgz
        # AddHandler allows you to map certain file extensions to "handlers":
        # actions unrelated to filetype. These can be either built into the server
        # or added with the Action directive (see below)
        # To use CGI scripts outside of ScriptAliased directories:
        # (You will also need to add "ExecCGI" to the "Options" directive.)
        #AddHandler cgi-script .cgi
        # For type maps (negotiated resources):
        #AddHandler type-map var
        # Filters allow you to process content before it is sent to the client.
        # To parse .shtml files for server-side includes (SSI):
        # (You will also need to add "Includes" to the "Options" directive.)
        #AddType text/html .shtml
        #AddOutputFilter INCLUDES .shtml
    </IfModule>
    # The mod_mime_magic module allows the server to use various hints from the
    # contents of the file itself to determine its type.  The MIMEMagicFile
    # directive tells the module where the hint definitions are located.
    #MIMEMagicFile etc/httpd/magic
    # Customizable error responses come in three flavors:
    # 1) plain text 2) local redirects 3) external redirects
    # Some examples:
    #ErrorDocument 500 "The server made a boo boo."
    #ErrorDocument 404 /missing.html
    #ErrorDocument 404 "/cgi-bin/missing_handler.pl"
    #ErrorDocument 402 http://www.example.com/subscription_info.html
    # MaxRanges: Maximum number of Ranges in a request before
    # returning the entire resource, or one of the special
    # values 'default', 'none' or 'unlimited'.
    # Default setting is to accept 200 Ranges.
    #MaxRanges unlimited
    # EnableMMAP and EnableSendfile: On systems that support it,
    # memory-mapping or the sendfile syscall may be used to deliver
    # files.  This usually improves server performance, but must
    # be turned off when serving from networked-mounted
    # filesystems or if support for these functions is otherwise
    # broken on your system.
    # Defaults: EnableMMAP On, EnableSendfile Off
    #EnableMMAP off
    #EnableSendfile on
    # Supplemental configuration
    # The configuration files in the etc/httpd/extra/ directory can be
    # included to add extra features or to modify the default configuration of
    # the server, or you may simply copy their contents here and change as
    # necessary.
    # Server-pool management (MPM specific)
    #Include etc/httpd/httpd-mpm.conf
    # Multi-language error messages
    #Include etc/httpd/httpd-multilang-errordoc.conf
    # Fancy directory listings
    #Include etc/httpd/httpd-autoindex.conf
    # Language settings
    #Include etc/httpd/httpd-languages.conf
    # User home directories
    #Include etc/httpd/httpd-userdir.conf
    # Real-time info on requests and configuration
    #Include etc/httpd/httpd-info.conf
    # Virtual hosts
    Include /opt/local/etc/httpd/httpd-vhosts.conf
    # Local access to the Apache HTTP Server Manual
    #Include etc/httpd/httpd-manual.conf
    # Distributed authoring and versioning (WebDAV)
    #Include etc/httpd/httpd-dav.conf
    # Various default settings
    #Include etc/httpd/httpd-default.conf
    # Configure mod_proxy_html to understand HTML4/XHTML1
    <IfModule proxy_html_module>
    Include etc/httpd/proxy-html.conf
    </IfModule>
    # Secure (SSL/TLS) connections
    #Include etc/httpd/httpd-ssl.conf
    # Note: The following must must be present to support
    #       starting without SSL on platforms with no /dev/random equivalent
    #       but a statically compiled-in mod_ssl.
    <IfModule ssl_module>
    SSLRandomSeed startup builtin
    SSLRandomSeed connect builtin
    </IfModule>
    # add php specific settings
    Include /opt/local/etc/httpd/httpd_php.conf
    # add this to make phpmyadmin accessible through http://www.domain.com/phpmyadmin/
    Include /opt/local/etc/httpd/httpd_phpmyadmin.conf
    This is in httpd.conf
    Code:
    # Virtual Hosts
    # Required modules: mod_log_config
    # If you want to maintain multiple domains/hostnames on your
    # machine you can setup VirtualHost containers for them. Most configurations
    # use only name-based virtual hosts so the server doesn't need to worry about
    # IP addresses. This is indicated by the asterisks in the directives below.
    # Please see the documentation at
    # <URL:http://httpd.apache.org/docs/2.4/vhosts/>
    # for further details before you try to setup virtual hosts.
    # You may use the command line option '-S' to verify your virtual host
    # configuration.
    # VirtualHost example:
    # Almost any Apache directive may go into a VirtualHost container.
    # The first VirtualHost section is used for all requests that do not
    # match a ServerName or ServerAlias in any <VirtualHost> block.
    # This file is autogenerated from zfslib.pl module zfslib_update_www
    # do not edit manually, edit in napp-it menu zfs folder
    ################# vhost: /cloud/testcifs ##################
    Listen 192.168.0.1:80
    <VirtualHost 192.168.0.1:80>
    DocumentRoot "/cloud/testcifs"
    ErrorLog "/cloud/testcifs/_wwwlog/error_log"
    CustomLog "/cloud/testcifs/_wwwlog/access_log" common
    ServerName www.thisdomain.com
    ServerAdmin webmaster@thisdomain.com
    DirectoryIndex index.php index.html
    # Directory options "/pool/zfs/_wwwroot"
    <Directory "/cloud/testcifs">
    Require all granted
    AllowOverride None
    Order allow,deny
    Allow from all
    </Directory>
    # ScriptAlias ex /cgi-bin/ "/pool/zfs/wwwroot/cgi-bin/"
    ScriptAlias /cgi-bin/ "/cloud/testcifs/cgi-bin/"
    #Directory options "/cloud/testcifs/_wwwroot/cgi-bin"
    <Directory "/cloud/testcifs/cgi-bin">
    Require all granted
    AllowOverride None
    Options +ExecCGI
    Order allow,deny
    Allow from all
    </Directory>
    </VirtualHost>
  2. gea
    gea Member
    May 22, 2011
    211
    napp-it Z-Raid vCluster v.2
    I am on the way to finish my Z-Raid Cluster in a Box solution.
    In the past a Cluster in a Box consists of two servers with a common pool of mpio SAS disks. One of the servers builds a pool from the disks and offers services like NFS or SMB. On a failure or for maintenance you can switch over to the second server within a few seconds. Management is done for example with RSF-1 from high-availability. SuperMicro offers special cases that can hold two mainboards
    Such solutions are expensive and management is quite complex but offers high performance and high availability. To reduce costs, my solution is based on ESXi (any license) to virtualize the two nodes and a control instance. It uses the shared controller/ shared raw disk options of ESXi so my solution does not need multipath SAS but can work with any disks.
    Setup see http://www.napp-it.org/doc/downloads/z-raid.pdf
    If you want to try the preview state that allows a manual failover within 20s, you can update napp-it to the free 18.02 preview (or 18.12dev).
    davros123 likes this.
  3. gea
    gea Member
    May 22, 2011
    211
    vCluster Beta2 is available (napp-it 18.12g dev)
    Current state:
    Manual Failover between nodes working for NFS and SMB
    For SMB it supports failover for local user and AD users connected to the share during failover.
    Todo
    auto-failover (on tests)
    Expect vCluster to next Pro (Jan 2019)
  4. downforce
    downforce Member
    Jun 11, 2007
    1,202
    Thornlie, WA
    Hey all,
    So I tried to update my Solaris ESX Guest VM (that has a HBA passed through) and it seems stuck on an old version of Solaris 11.3 (0.5.11-0.175.3.1.0.5.3). This VM is only used as ZFS storage with a bunch of NFS and SMB shares off the pools.
    I can't seem to upgrade to 11.4 as there is a broken dependency, so apparently need to get to RU27 first, but I can't seem to figure that out either, the repos don't seem available and I don't have any support contracts.
    I'm wondering if Solaris is still the best way to go, is Linux suitable replacement now? Or should I look at replacing it with one of the "applications" listed here, like NAPP-IT etc? It's been a few years since I looked into this so need to basically start again with this research. From memory, if I create a new VM, I can present the disks and import the pools, right?
    Any guidance/assistance would be appreciated! I'll still continue to do my Googling.
  5. grs1961
    grs1961 Member
    Jan 21, 2005
    524
    Short answer is that unless you can get your S11.3 system up to 27 or greater (some say 35) there is no upgrade path to 11.4.
    But S11.4 is a nice advance on 11.3, I will be updating my storage system by replacing the boot mirror disks and installing 11.4, the real data is on a separate ZFS pool, and transferring passwd/groups and the like takes bugger all time (but then I've had several decades of practice in updating UNIX systems in-place).
  6. downforce
    downforce Member
    Jun 11, 2007
    1,202
    Thornlie, WA
    So if i did a fresh install of 11.4 on a new root zpool, then I can just import the other zpool?
    Being a VM, I just can detach the disk and add a new one, if it all goes pear shape, just re-add the original disk back in.
    In terms of users/passwd/grps etc, somehow all my linux and Solaris boxes got out of sync in terms of uid/gid's so I'm actually happy to redo the Solaris perms and even look at using adding a GUI overlay (napp-it etc).
  7. gea
    gea Member
    May 22, 2011
    211
    For an update from 11.3 to 11.4 (without support contract) you need to
    - install Solaris 11.4
    - import the former datapool (and update ZFS to v.44 to get the new features)
    To maintain napp-it settings
    - save and restore /var/web-gui/_log ex with WinSCP
    With napp-it Pro you can run a backup job and restore via menu Users > Restore
    To maintain users
    add the former users with the same uid/gid or
    save/restore /etc/passwd, /etc/shadow, /etc/user_attr and /var/smb/* (SMB passwords)
    otherwise on SMB
    reset permissions ex from Windows when connected via SMB as root
    about napp-it
    napp-it is a management tool to make a full featured webmanaged storage appliance
    out of a default setup of Oracle Solaris or one of the free Solaris forks OpenIndiana (successor of OpenSolaris), see https://napp-it.org/manuals/index_en.html
    about ESXi and Storage VM
    There are two trouble free options
    - use an LSI HBA in pass-through mode.
    The storage VM has full native access to HBA and disks
    - use an LSI HBA and attach to ESXi (no pass-through)
    You can then attach single SAS or Sata disks to a VM (menu VM properties, add disk > raw disk). This gives the VM physical disk access as well
    For Solaris 11.4 you should use ESXi 6.7U1 as the genuine vmware tools support Solaris 11.4 then, https://forums.servethehome.com/index.php?threads/oracle-solaris-11-4.18133/
    or OmniOS (minimalistic OS for production storage use)
    https://www.openindiana.org/
    https://omniosce.org/
    downforce likes this.
  8. downforce
    downforce Member
    Jun 11, 2007
    1,202
    Thornlie, WA
    Awesome summary, thank you!
    - I don't currently use napp-it or any GUI, done everything via cli, so a GUI would be an enhancement;
    - Only have 1 user atm but want to change that to multiple
    - That's exactly what I do with a LSI HBA in passthrough mode;
    - It's currently running 5.5 but I'm in the process of testing the upgrade process from 5.5 -> 6.0 -> 6.7, esp now the ESXUI is included;
    - I'll definitely look at OmniOS as I really am only using for "home production" storage.
    davros123
    davros123 Member
    Jun 18, 2008
    3,006
    downforce. I am a diehard solaris to napp-it convert. Do it. I like OI over OmniOS as it has a GUI.
    Only issue is you need a new set of disks as the zpool/zfs versions are not transportable
  10. grs1961
    grs1961 Member
    Jan 21, 2005
    524
    Yes.
    If your original system was on rpool, you can use "zpool import old_rpool_id newpoolname".
    If you are going to replace Solaris with OmniOS, you may not be able to import things, I am not sure if OmniOS has kept up with zfs and zpool versions. (That's not a dig at OmniOS, it takes time and effort to reverse engineer these things.)
    davros123
    davros123 Member
    Jun 18, 2008
    3,006
    correct, sadly, you can not import to OmniOS from anything near recent Solaris.
  12. chook
    chook Member
    Apr 9, 2002
    3,789
    davros123
    davros123 Member
    Jun 18, 2008
    3,006
    Lol. Love it.
    In truth, I was always an Open Solaris devotee and Open Indianna is just going back to my roots. Praise be to the server gods.
  14. gea
    gea Member
    May 22, 2011
    211
  15. gea
    gea Member
    May 22, 2011
    211
  16. gea
    gea Member
    May 22, 2011
    211
  17. gea
    gea Member
    May 22, 2011
    211
  18. gea
    gea Member
    May 22, 2011
    211
    OpenIndiana Hipster 2019.05 is out
    Release notes: 2019.05 Release notes - OpenIndiana - OpenIndiana Wiki
    Editions:
    GUI/live for server and desktop use with a Mate 1.22 desktop
    Text (prefer this this for server use)
    Minimal (minimal Ilumos)
    about OpenIndiana.
    OpenIndiana is always based on the most current Illumos (the common development platform for all Illumos based distributions) with quite a huge repository including many server and desktop apps. This is different to the new OmniOS 151030 LTS (long term stable) from may 2019 that is a freeze of the current Illumos state for the next 2 years with only security and bug fixes. Beside extras like LX zones and Bhyve OmniOS 151030 is quite similar to OpenIndiana 2019.05 text.
  19. gea
    gea Member
    May 22, 2011
    211
  20. gea
    gea Member
    May 22, 2011
    211
    OmniOS bloody 151031 now supports native ZFS encryption
    napp-it 19.dev from today (jul 04) supports encryption
    in menu ZFS filesystem (create, lock, unlock)
